Question about Sony Handycam DCR-TRV19 Mini DV Digital Camcorder
Sony DCR-PC107E I have had this camcorder for a few years and has always worked well. Having not used it for a couple of months I switched it on and the display - both on the LCD and through the viewer is just distorted colored lines. light is distinguishable but barely. Does anyone have any ideas as to what may be wrong and if it is fixable by a novice ie me thanks
    Sergeant:
    Champion:
  • 326 Answers
Hi there. There is no way you can fix this by yourself. Please contact the nearest Authorized Sony Service or the technician with best references. Best regards, Arpi
Posted on Apr 22, 2007
Error c:04:00
have you ever replaced the batteries? if yes then make sure if it is compatible with the camcorder
Apr 07, 2012 | Sony DCR-TRV38E MiniDV Handycam Camcorder...
WHEN i SWITCH ON THE CAMCORDER IT SAYS SET CLOCK, BUT THE SCREEN DOES NOT MOVE ANS STAYS PUT IN THE YEAR. ITS A DCR-HC 40E
-set the year as first shown using or by touching the up or down arrow in the lcd screen then press ok to switch to month.
-do the same thing with the day( always use the up or down arrow located in the lcd screen to change the numbers then touch ok to confirm.
Jun 05, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
DCR-HC32 NTSC the touch screen that controls the playback suddenly stopped working...help!
I've had this problem with my HC32 touch screen for a year and a half.
The fix was to buy a new camcorder which is working out great -- but every 6 months or so I have to get this one back out to use as my analog to digital video pass thru device.
To get the touch screen to work:
- I put it in the charger dock and turn it on AND LEAVE IT ON so the screen is displaying something (anything).
- within 12 to 24 to 36 hours it starts to work on it's own. At first it will only let you make a single menu choice and lock up again but a few hours later it will be perfectly normal for at least a few days (maybe forever if you use it regularly).
I've done this three or four times now and it has worked each time. It seems that after it sits a few months and the battery discharges the problem occurs.
Feb 22, 2011 | Sony DCR-HC32E DV Digital Camcorder
Camcorder shows eject sign when i put a tape in it
A couple of things can cause this, loss of drum rotation (or loss of the sense of drum rotation) or loss of reel pulses. Remove the casette door and see if the drum spins when you try to load a tape. If not, you have a bad drum. No easy fixes for this problem, sorry!
Oct 19, 2008 | Sony Handycam CCD-TRV12 Camcorder
Sony dcr-trv 265e handy camproblem
stop bying sony camcorders, I had a problem and its was my second sony camcorder that failed to function properly after just one year (just after waranty expierd) the first I took to shop to repare **** after two weeks it was broken again, this while I diden't even realy used it; my very first camcorder: a canon, functioned more than 6 years and if I wanted I could still repare it **** it's analog. so go Canon, even sanyo is better these days than a f#^îng sony
Sep 29, 2008 | Sony Handycam DCR-TRV265E Digital...
Trouble shooting for Sony Cam coder DCR-TRV285E
It sounds to me like its definetely broken. There must be an actual part of the switch which has been physically worn out and makes the camera remain at the ON position. You can open the camera and find this switch. You may be able to glue the part together. However, this types of repair are only temporary and you may have to do it all over in a few months. I recommend buying a used camera on Amazon, which will cost you about $50.
Aug 06, 2008 | Sony Handycam CCD-TRV107E Camcorder
HOW DO I SET DATE & TIME-ALSO GO FROM SP TO SLP
There is a built-in rechargeable battery in the camera and after approx 3 months it will be completely discharged if the camcorder is not used. To recharge: Connect camcorder to wall outlet using the supplied AC Adapter with the power switch turned OFF for more than 24 hours. (To keep the internal batter charged, try to plug the camera in every couple of months or attach a fully charged external battery for at least 24hrs). To set the clock: Set the power switch to CAMERA and then press MENU. Turn the dial to select CLOCK SET, scroll to the toolbox looking icon -it may say DEMO MODE next to it. Then press the dial. Turn the dial to select the desired year, month, day and then pressing the dial to set each as you go. For the tape speed go to Menu settings scroll to find Tape settings (TAPE SET), select REC MODE and from there you can change the tape speed from SP to LP. Hope this helps. I have the Sony Digital 8 Handycam DCR-TRV250 I purchased about 3 or 4 years ago (700x digital zoom etc).
May 21, 2008 | Sony Handycam DCR-TR7000 Digital Camcorder
Black lcd
Previous 1 2 3 4 5 Next Notice to Owners of Sony Camcorder October 3, 2005
Thank you for your support and patronage of Sony Camcorders.
It has recently come to our attention that a limited number of Sony Camcorders that incorporate an image sensor device, CCD Chip, manufactured from October 2002 through March 2004 may exhibit the following condition:
When the Camcorder is used in camera mode, the LCD panel and/or electronic viewfinder will show either a distorted image or no image.
We have determined that this condition only occurs to a limited number of units.
In its effort to ensure customer satisfaction, Sony has elected to offer a free repair to the owners of applicable Camcorders if the image sensor device, CCD chip, causes one of the above-mentioned conditions. Accordingly, customers who have a Sony Camcorder as outlined below and if such Sony Camcorder exhibits the above-mentioned condition caused by the image sensor device, CCD chip, may contact the special call center number below for free repair:
CCD-TRV108E
CCD-TRV208E
CCD-TRV218E
CCD-TRV228E
CCD-TRV418E
CCD-TRV428E
DCR-DVD100E
DCR-DVD101E
DCR-DVD200E
DCR-DVD91E
DCR-HC14E
DCR-HC15E
DCR-HC16E
DCR-HC18E
DCR-HC20E
DCR-HC30E
DCR-IP45E
DCR-IP55E
DCR-IP5E
DCR-IP7E
DCR-PC101E
DCR-PC103E
DCR-PC104E
DCR-PC105E
DCR-PC106E
DCR-PC107E
DCR-PC115E
DCR-PC120E
DCR-TRV12E
DCR-TRV145E
DCR-TRV147E
DCR-TRV14E
DCR-TRV16E
DCR-TRV18E
DCR-TRV19E
DCR-TRV22E
DCR-TRV238E
DCR-TRV239E
DCR-TRV240E
DCR-TRV245E
DCR-TRV24E
DCR-TRV250E
DCR-TRV255E
DCR-TRV25E
DCR-TRV265E
DCR-TRV27E
DCR-TRV33E
DCR-TRV340E
DCR-TRV40E
DCR-TRV460E
DCR-TRV50E
DCR-TRV738E
DCR-TRV740E
DCR-TRV940E
DCR-TRV950E
DCR-VX2000E
DCR-VX2100E
Please Call
UK - 08705 143480
Eire - 021 434 8993
Note: If the fault is not the CCD chip, then normal Sony Central Services charges apply (please call for details).
We apologise for any inconvenience caused and we thank you for your understanding of this situation.
Sincerely,
Sony
Private information control policy
Personal information, such as your name and/or mailing address, provided to the contact above will be kept and used only for the free repair service. The information will be strictly controlled and will not be used for any other purposes.
May 16, 2007 | Sony Handycam DCR-HC30 Mini DV Digital...
Sony Handycam DCR-TRV19 Mini DV Digital Camcorder Logo
87 people viewed this question
Top Sony Video Cameras Experts
Parshiv Luthra
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
