Question about Cameras
Vertical Pinkish Lines on Bright Areas of LCD Screen
I have a HP Photosmart R967 that has given me problems since I first opened the box. While the camera is pointed toward bright areas (particularily sunlight through a window and christmas tree lights) I get pinkish vertical lines on the LCD screen. They don't show up on playback except recently they now show up for videos. I've had this problem ever since I purchased the camera, HP service has not been helpful for this problem and don't seen to want to deal with it. My father's first photosmart camera also had the same problem; but his second one as well as my daughter's seem to work just fine. I'm currently having the same problem on my new Canon PowerShot SD 990IS (even the one I just exchanged). Canon service also has not been helpful--they contend this is normal. Could all of these problems be related to defective CCD sensors?
  • 365 Answers
This may not be a problem ,this will be only a result of the high density light to which you have focused the camera.it is heard that focusing to high intensity light may damage the lens and so it is not good to do so.thank you
Posted on Dec 27, 2008
    Genius:
  • 1,550 Answers
Yes you are right this problem is due to defective ccd sensors .
You need to take to local repair shop to get it repaired .
TV suddenly has pinkish red vertical dotted lines running down it that comes and goes randomly.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Apr 16, 2015 | Televison & Video
My R967 got a little moisture on my last fishing trip to canada, so I took the battery out and memory card and blew it with a blow dryer, it had blue stips in the monitor and I kept it on the charger for a...
actually the moisture must have entered the leads of the display...
the leads should be removed and then it should be dried so take the moisture off..
better take it to a service centre..it is risk to manually operate the sensitive parts inside and you could end up damaging the display
Jun 26, 2008 | Cameras
Hi, I'm having trouble with a samsung 46" led tv. A few seconds after being turned on, colored vertical lines appear in front of whatever show is on. These lines will appear in different areas at...
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Screen-shots to defective LCD are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent. Line faults to LCD TVs too are given with illustrations.
Jul 22, 2014 | Televison & Video
Spots in the photos (HP Photosmart R967)
Do you see it on the screen as well as on the computer? Then there is something in the camera; dust or debris, and it needs a cleaning. If it is just on the camera screen, there could be a defect on the LCD.
Apr 14, 2014 | Cameras
Samsung lcd tv series 3 330
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Aug 29, 2017 | Samsung Televison & Video
White vertical lines like jail bars
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 26, 2017 | Samsung HLN5065W 50" Rear Projection...
I have problem with my laptop one bright vertical line on leftside and light vertical line on the right sude
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical lines. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Jan 07, 2011 | HP Pavilion dv6000z Notebook
Tv picture is pink with vertical lines sony bravia 32 inch XBR
it sounds like a bad t-con board. this board my not be sold without geting the whole screen. the t-con borad is at the top of the screen and connects to your main board
Apr 15, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Vertical Lines in Monitor
Definitely ask HP support. They should be familiar with this wierd problem.
Apr 13, 2008 | HP Pavillion ZV6000 Notebook
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Cameras Logo
14 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
