Question about GPX ML648B MP3 Player
Unit doesn't link with pc
Cannot get my gpx mp3 player to link to pc.model # ml648b.tried several things. Bad usb cord?
  • Rattly Dec 27, 2008
    I had a similar problem. If you are going by what the sheet that comes in the package, it is completely ambigous as how to install the software to be able to connect it to your PC. Without Media player running. connect the device using the suppied USB highspped port. when you do it shoud power up, and it shows a little monitor and USB icon on the display. At this moment your computer is trying to recognize it as a portable media player, However when you press and hold the power button you will see a small blue sqare appear in the lower corner of the scren. If you can see it, is say USB mode. That means that the mode between Mass Storage drive, and portable media player is toggled by holding and releasing the power button just long enough to swith modes, but I found if you hold the button down a little too long, you will see the small blue square, appear and dissappear again. With a little practice you will be able to get the mode to swich and the blue USB square will stay on the screen of the device, At which time you are in MSC mode. You should be able to open "My Computer" and look at all of the available devices, odds are that you will notice the portable device named GPX just dissappeared and doesn't seem to come back. But look a little higher and you will see a new unknown mass storage device, and here is the real trick. There will also be a Disc drive that looks like a virtual CD drive. It should be named tools. Open that disc, and its folder and you will find the setup.exe application. Once you run that and it installs its applications and drivers. Disconnect the device,open your Media Player program you are hoping to sync with reconnect the usb cable and it should be right there for you.
  • 8,596 Answers
1. Connect your ML648B to your computer with Windows XP or later.
2. By default your computer will recognize ML648B as GPX MTP Device. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as MTP Device.)
3. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B. (Wait for few seconds to a minute allowing your Windows computer to recognize and install necessary drivers for the device for first time as USB device.)
4. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
5. Double click & open Tools, and run Setup.exe to start installing Video Conversion Software tool.
6. Select defaults options and finish the installation by clicking on Close or Finish.
7. If asked, click on Continue Anyway on Windows XP or Install this driver software anyway on Windows Vista.
Posted on Feb 15, 2009
A friend gave me his gpx do i need software to install on pc?
I don't think you should require anything. When you plug it in via the USB cord it should automatically install the necessary drivers. You will need Windows Media Player 10 or higher to load songs onto it though.
Jun 23, 2010 | GPX ML648B MP3 Player
DELETE SONG AND SHOW ALL ON MP3 PLAYER
Plug the device into your computer with your USB cord. Double click the Computer icon on your Desktop. Then double click on GPX Device and double click again on Removable Storage and double click the Music folder. You should now be able to see all the files you've loaded onto your MP3 player. Simply select the ones you no longer want and hit the Delete key on your keyboard.
May 25, 2010 | GPX ML648B MP3 Player
NEED A USB CABLE
The item can be purchased through the GPX website.
Here is a direct link, $5, if the link doesn't work go to GPX.com, go to MP3 players, go to ML648B, under the picture click accessories, and click USB cable.
Thank you for using FixYA! Happy Holidays!
Dec 10, 2009 | GPX ML648B MP3 Player
My gpx ml648b won't turn on I have the usb cord plugged in and I don't know if it's charging or not.
try to barrow to your friends other battery dsame model of your phone and din insert it din try to charge and on...if your phone charging that mains your battery problem... or use other charger
Jul 04, 2009 | GPX ML648B MP3 Player
GPX ML648B Will not hold charge
The Player gets it's charge from the USB port. I would recommend plugging your Player in and leave your computer on overnight.
If your player still does not retain a charge, I would contact the manufacturer.
Feb 18, 2009 | GPX ML648B MP3 Player
Not enough disk space on GPX ML648B
If this problem occurs then your ML648B needs to be formatted.
2. By default your computer will recognize ML648B as GPX MTP Device. Press the POWER button from top of your ML648B, to change it to USB mode connection. You will also see USB on the screen of ML648B.
3. ML648B will now mount 2 drives, one as Tools (as CD-Drive) and second as Removable Disk (Drive) – under My Computer on your Windows Desktop.
4. Right click your mouse and then select the Format option. When the Format Removable Disk window appears select the Start button to start formatting your MP3 player.
-Tha Mp3 Doctor
Jan 29, 2009 | GPX ML648B MP3 Player
I try to sync songs on to my mp3 player and it says that i have no mb remaining...the thing is that i dont have any songs on my mp3 player
Jan 07, 2009 | GPX ML648B MP3 Player
Having trouble synching with gpx ml638b...
Jan 05, 2009 | GPX ML648B MP3 Player
My grandson got a GPX ML648b mp3 player for Christmas. On Christmas day we tried to download songs. After 24 songs it would not loan any more. So I deleted the songs and tried again. It would only download...
Dec 30, 2008 | GPX ML648B MP3 Player
Charging my gpx ML638B
It will if it is a mini-USB plug. The mp3 has the mini-USB cord bundled, and can be used with anything with a mini-USB port. My cell has the same port, so I can charge it on the PC like the mp3, and can use the wall socket charger for the phone on the mp3.
Dec 18, 2008 | GPX ML648B MP3 Player
GPX ML648B  MP3 Player Logo
234 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
