Question about Sta Rite Maxi Therm 400k Btu Propane Heater
My sta rite heaters power up, start the flow of propane, but dont
They dont ignite. they are getting elcetricity, but hey dont ignite and start heating. they were working fine last week and now they are not working.
Is there any way to get them to ignite?
  • kb80900 Dec 27, 2008
    where is the heating element?
    Genius:
  • 1,550 Answers
The heating element is not working properly . The element can get coated with certain minerals .You need to clean the heating element with a brush.
Posted on Dec 27, 2008
Max e therm heater makes loud noise at start up and does not stay on? What could it be?
Water flow might be the issue. Check the Thermal Reg or any other external by-pass.
Jul 24, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Heater will not ignite' service light is on?
I suggest that Sta-Rite technical support would be the best ones to help you determine what the problem is. I hope this helps.
Aug 09, 2011 | Sta Rite Sta-Rite Max-E-Therm High...
I have a starite propane heater i turn it on it calls for heat it will start heating then a couple minutes later the filtration lines and heater give a loud banging noise and service heater light comes on...
This is either one of two thing.
Either you pump is clogged, or failing and not providing adequate flow, or the heat exchanger has a hole in it. I would hope that it is just a flow issue as the exchangers are very expensive.
Check the pump first, and also make sure there is no leaking water from the heater
Nov 14, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
What does R* mean
Where is this "R" if it is the one in the model SR400LP That is Rite, SR Sta-Rite, 400 is btu's in thousands, LP is liquid petrouliem or propane.
Jun 24, 2010 | Sta Rite SR400LP Max E Therm Pool Spa...
So how do I fix this problem "sta rite 400na gives error code 05 after about 30 seconds?"
if it starts check your stack sensor its the one the exaust ----- And if it dont start change your ignition plug
Jun 19, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
When power to heater turned on r3 is displayed
Sounds like low water flow. Is there a manual bypass that may be open? If not, thermal regulator may be bad, or worst case scenario, heat exchanger is blocked due to imbalance of ph/alkalinity in pool water. Good luck.
Jun 15, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
Sta-rite gas heater won't ignite
I am not sure if either of these issues have been solved, but with the AGS light on, you will need to check the flow of water first. If it is below what is needed for the heater, this will light up. If the water flow is fine, then check the water temp on the display panel. If it is readin higher than that of the ACTUAL pool water temp, you need to replace the Thermister.
If the water temp displayed is about that of the pool water, then the Automatic Gas Shutoff will be the next thing to check and replace.
You can tell IF a Sta-Rite heater has been converted by the model number. The Convesion Kit is supposed to come with a sticker stating that the heater has been converted, but there are two options for the kit and the one without the sticker is cheaper.
If you take off the top two halves of the heater, on the Junction Box there should be a Tri-fold card there. Unfold it, if the model number ends with NA it is a Natural Gas Heater, LP would be Propane.
Apr 04, 2009 | Sta Rite Sta-Rite Max-E-Therm High...
AGS code
AGS switch wiring may be bad. Jumper the switch at the molex connector on the board using a paper clip, with the plug still plugged on. Restore power.
Dec 04, 2008 | Sta Rite Sta-Rite Max-E-Therm High...
Sta Rite Maxi Therm 400k Btu Propane Heater  Logo
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
