Question about EliteGroup P4M800PRO-M Motherboard
Elitegroup P4M800 motherboard boot-up problem
I recently bought an elitegroup P4M800 motherboard, I've got 1024mg of ddr333 memory. When I turn it on it'll get as far as recognizing the hard drive and cd-roms, and it would hang for a few seconds and then shut down. It wouldn't start up again unless I cleared c-mos, and then it would do the same thing. I tried it with an ATI Radeon 9800 video card, and also with the onboard video with the same results. Any help would be greatly appreciated! Thanks, Dave. I'm not able to get into BIOS so I can't check anything there.
    President:
  • 2,961 Answers
I am assuming you read my other post, so did you notice in the same menu it recognises the hard disk, does the system count all of the memory, if so the memory is ok, remember it will count it in kilobytes so don't look for 1024mb. You know it's not the graphics, although you should be able to get into the bios to check the settings because the post to check drives appear and the proceedure for getting into the bios is before this power on self test.
Posted on Apr 21, 2007
Can not boot from CD
see that the boot sequence is proper first u should keep cd//dvd then hdd
May 17, 2010 | EliteGroup P4M800-M7 Motherboard
P4m800-m7 Rev:3.1 RAM PROBLEM!
the problem is with the new ram.
its phsically damged.
may be little bit that you cant see it.
try checking the other 1GB ram.
Nov 08, 2008 | EliteGroup P4M800-M7 Motherboard
Upgrade ECS FSB800 memory from 1 GB to 2 GB wont work
This board will support up to 2gb as shown below extacted from the website product page.Don't forget that if you have ddr 333 memory installed originally, you can only add the same clock speed memory, i.e. ddr 333. If you add ddr333 and ddr400 you will have problems as the clock speeds do not match. If you are matching clock speeds, the try bootin the system with the new piece of memory on its own to see if there is a problem with that stick, trial an error of both sticks individually, will give a positive result
MEMORY ecs_buttom_03.gif Single-channel DDR memory architecture ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333 DDR SDRAM
Nov 02, 2008 | EliteGroup ECS P4M800-M Socket...
Is P4M800-M7 mobo can support the pc333 sdram memory? Thank you.
Yes, according to the specs that I read the P4M800-M7 (socket 775?) is designed to support pc333.
Only one time I had a problem with an ECS motherboard, I had the correct memory, but the board had a different voltage requirement. Did not cause any issues, other than it didn't work. I don't think that this would be a problem for you though.
Oct 14, 2008 | EliteGroup P4M800-M7 Motherboard
Motherboard
inspect careful, it doesn't mean that any move there is no responses by the computer. If not checks the memory, the memory is responsible for booting also plus the connection of each components. . . .try it
Sep 18, 2008 | EliteGroup ECS P4M800-M Socket...
Compatibility of p4m800-M socket and ddr pc266
The motherboard supports DDR400/333 DDR SDRAM only according to their website. So most likely not..
Jun 26, 2008 | EliteGroup ECS P4M800-M Socket...
P4M800-M7 presumed memory problem
I have never had a problem with Mobo's supporting 2 GB of memory.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=548&DetailName=Specification&MenuID=44&LanID=0
As per the website your mobo supports 2 GB memory.
Dec 25, 2007 | EliteGroup P4M800-M7 Motherboard
C1 led post code
try changing your RAM with new one
Nov 08, 2007 | EliteGroup ECS P4M800-M Socket...
Boot-up problem with elitegroup P4M800 motherboard
It could be a memory incompatabilty problem, especially if you only get one beep from the board when booting. You say 1024MB of memory, if this is in the form of 2 x 512MB try one on it's own and make sur that you have purchased single channel memory. Also go to the bios (F2 or Del) on start up and in the standard cmos settings you may need to let the motherboard auto identify your HDD, normally by pressing F12 or similair, look in the menu. Another thing to check while in the std cmos settings is a line normally underneath all the identified drives saying 'Halt on all errors', see if this can be dissabled as it will continue to boot if there are problems without stopping it. If you have a floppy disc fitted it may be looking for that also and havibg trouble, again you can tell the bios not to look for a floop disc. As well a clearing the cmos leave out the battery for 10 minutes or so. Sorry theres a lot to check, but it is difficult to diagnose when it's not in front of you.
Apr 20, 2007 | EliteGroup P4M800PRO-M Motherboard
EliteGroup P4M800PRO-M Motherboard Logo
69 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Matson Kurian
Matson Kurian
Joe Negus
Joe Negus
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
