Question about Brother IntelliFax-2820 Laser Fax
FSending and receiving faxes on legal size paper.
How do you send and receive faxes using legal size paper. The machine is a Brother Intellifax 2820 with one tray.
    Sniper:
  • 71 Answers
Press Menu/Set, 1, 3 Press up or down arrow to select Letter, A4, A5, A6, B5, B6 or Executive Press Menu/Set Press Stop/Exit :o)
Posted on Aug 14, 2007
Why is my Brother Intellifax 4100e error says check paper size?
your paper error message means you probably received a document that wasn't the size of paper in the paper tray ,try legal sized paper,to dump the job stuck in your faxes memory ,this
problem happens a lot, theres reall nothing wrong with the fax/printer
Aug 13, 2014 | Brother IntelliFax-4100e Fax
How do I set the machine to receive automatic instead of manually
go to initial set up , receive mode, change it to fax only
May 24, 2010 | Brother IntelliFax-2820 Laser Fax
Hi. i hope you can give a suggestion with our brother intellifax 2820. Whenever printing a received fax, the machine prints out a blank page in between each received page. so, for example, we receive pg1,...
press "menu/set, 1, then 3. you should see "paper size" on display. select "letter" if thats what you are using, and press "menu/set" again, then "stop/exit" to back out. next, make sure your "fax" button below display is green, then press "menu/set, 2, 1, then 5.using your arrow keys, select "on". press "menu/set" then "stop/exit". that should do it.
hth,
razors
Mar 15, 2010 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax-2820, will not print incoming faxes. It rings, says it's receiving data and thats it. Yes I have paper in tray. Sends and copies fine.
You need to make sure that your machine is set to "FAX" mode,not"PHONE"mode and that it is in "AUTO"receive, not "MANUAL"receive mode.
Oct 04, 2009 | Brother IntelliFax-2820 Laser Fax
Redued size of legal contracts on receiving fax sent to
HELLO! THE PROBLEM IS NOY ON YOUR END, THE MACHINE AT THE OTHER END HAS TO BE SET UO FOR LEGAL PAGES.SOME PEOPLE HAVE TRAY FOR LEGAL AND ONE FOR LETTER, THEN THE MACHINE WILL CHOOSE IT AUTOMATICLY. GOOD LUCK BROTHER TECH
Jan 29, 2009 | Brother IntelliFax-4100e Fax
Whenever I send a fax on my brother intellifax 2820 it feeds crooked, I can not get it to go in straight. Therefore, the receiver only gets half the fax.
what you will need to do is go to a hardware store and purchase some isoprophyl alcahol. put some on a rag and clean the paper feed rollers if that fails there must be some in side that area like a peice of paper, try cutting a file folder to 8x11 in manually force feed thru a the paper feed section. good luck brother tech
Jan 13, 2009 | Brother IntelliFax-2820 Laser Fax
There should not be a problem with TX on LGL paper. If you want to configure the machine to recieve LGL on a regular basis: Press "MENU" 1-3. Then use the up/down arrows to select LGL. "MENU", "EXIT". That should do it. Good luck!
Apr 20, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
292 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
