Question about KDS SONY -R50XBR1 (SONKDSR50XBR1) PC Notebook
Can not adjust the color, color is geen
Can not adjust the color, every thing has a green tint to it
  • 741 Answers
Try right-clicking on your desktop. That will bring up the Display properties. Click on the tab that allows you to set the colors. Set it to the highest amount possible. Reboot and your colors should be fine.
Posted on Dec 27, 2008
57 inch hdmi rear projection no green or red in picture
how do i press tint on remote dont know how to get in
Apr 15, 2013 | Televison & Video
Green tint on picture. Cant adjust with tint or color from menu
My rear projection was doing the same thing. I have a mitsubishi and went into the video/audio set up. When I clicked on video it brought up brightness, tint, color, etc... Not sure if yours is set up the same.
Jan 18, 2011 | Zenith E44W46LCD 44" Rear Projection...
Green picture
Possible needs color tracking adjustment done by shop.
Apr 18, 2010 | Samsung HLN437W 43" Rear Projection HDTV
I can't seem to correct a tint problem. The tv turns on and the tint doesn't change. A friend says it could be a vidoe card?
Go to menue on controller, then Picture, then adjust Color and Tint to you taste. The color ajusts Blue and Green move left more blue move the slider right more green. The Tint controlls red. More red move right less left. Also chech Color temp setting.
Nov 08, 2009 | Akai PDP4225M 42 in. Plasma Television
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Samsung txh1970 tv screen has green tint
I encountered the same problem with a color computer monitor several years ago. Everything went green. The repair techies told me that's a sign that the power supply is going bad. You will not be able to adjust the color. You will have to either fix it or replace it. Hope this isn't a common problem with this model Samsung TV.
Dec 01, 2008 | Samsung TXH1970 TV
RED TINT OVERPOWERS COLOR
You're probably missing one of the other colors, green most likely or blue.
There are adjustments that can be made to bring things back into balance but you need to know what you're doing.
First, I'd have a look and make sure all your tubes are working correctly.
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Zenith Model SY2551S 1996 27" - Green Tint
The core problem with the green tint is the aging of the picture tube, and can be compensated a bit by using either the green drive control usually located on a printed circuit board on the neck of the picture tube or on the main chassis. There will be 3 main controls which will adjust the red and blue as well. If these controls are not present then you will need to get into the service menu and adjust it from there. Don't adjust anything else as you can make the set much worse. Also remember that in order to make these internal adjustments while watching a black and white picture (turn the color all the way down) you will have your hands and arms near live circuits that could shock you and cause injury to yourself as well as break parts inside the set when you pull back after being zapped (voice of experience here) Of course if you can do all this by the service menu then you won't even have to remove the back of the TV.
Sep 08, 2008 | Zenith C27A24T 27" TV
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Computers & Internet Logo
109 people viewed this question
Top KDS Computers & Internet Experts
Denise
ray
Level 1 Expert
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
