Question about GE JKS05 Electric Single Oven
I want to know if my wall oven is 110 or 220 .
It had three wires the colors of this wires are black,white and red and i would like to know about it . I want to thanks if you have an answer .
  • 405 Answers
Almost all electric oven are two twenty, but a voltage tester is a good idea, look at the breaker for it, if it is a double pool it probably is the red and white should both have 110 to the white wire, I hope this helps, God Bless.
Posted on Dec 27, 2008
  • David Johnson
    David Johnson Dec 27, 2008
    sorry red and black to white
    double pole
2 Suggested Answers
larryyb
  • 291 Answers
SOURCE: New Wall Oven wiring
on a 220v unit you dont use the 110 ,,, connect the red and black as power and the white as ground / larry
Posted on Dec 12, 2008
How to hardwire a 3 wire wall to a 4 wire oven
Simply put, it won't work. New oven=white is neutral, black and red are power but not on the same "leg", and green is ground. If you use a meter, black and red should give you 208-230 or so volts. Wires from wall=White is neutral, blank is voltage (probably 120 or so volts) and bare copper is ground. The dual voltage plug can be used for either 125 or 250 volts, not both as required by the new oven. Need an new circuit pulled and wire/breaker matched to new oven power requirements.
Oct 08, 2017 | Ovens
How to hook up electrical? 220v single phase? What color wires on which connections of the plug?
Identify the prongs. If you have wired a 110-volt fixture or plug, then you are aware that the different prongs connect to different colors of wires. The same principle holds true for 220-volt plugs, and this is very important to keep from tripping the circuit breaker. A three-prong plug will connect to two colored wires that each supply 110 volts and a bare copper wire which is the ground. One of these colored wires will be black, while the other one should be red, white, or blue. The four-prong plugs connect to a black and a red wire that each supply 110 volts, a white neutral wire, and a bare copper ground wire.
Read more : http://www.ehow.com/how_6830969_wire-220_volt-ac-plug.html
How to Wire 220 Volt AC Plug eHow
Dec 16, 2015 | Ovens
What is the ground & neutral wire for a JPK15 GE Oven?
Assuming this is in the USA there are 3 wires normally in a 240 volt circuit. A black, red and white. Sometimes there is a bare ground wire. The white wire and bare ground wire are basically the same.They connect to the same place in the electrical box. The red and black are your power wires. They would connect top the outside connectors and the white and bare wire (if supplied) would connect to the center connector.
Mar 22, 2015 | GE JKP15 Electric Single Oven
I have a wall oven with terminals L, N and PE . Assume wires are connected in order red, black and green/yellow
Line, Neutral,Ground 120 volt system Neutral wire should be white in color black and red wire would indicate 28/240 volts
Feb 16, 2015 | Ovens
I removed an old wall oven, and the wires coming out of the wall are black, red, pink, and ground. the new oven has black, red, WHITE , and ground. Does pink go to white?
It should go to white. but to double check you should use meter to check if you have 110 Volts between the pink and the Black and 110 Volts between the pink and the red. and 220 between Black and Red
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Dec 27, 2011 | Ovens
I have white, black and ground out of wall, i have red, black, white and ground from oven, how do i connect
Unfortunately you can't. Your wall outlet is a 110V circuit (B-110V; W- common) and your oven needs 220V circuit to operate. Red - 110V; Black - 110V; White - Common.
You will need to installed a 220V, 30 AMP (10-3/w ground) homerun from your circuit breaker panel to the oven
Jun 21, 2011 | Whirlpool RBS305PR Electric Single Oven
JTP56 Electric Double Oven Dead after self-clean. Power Pigtail comes into back of top control enclosure in flex conduit. The three red,black,white conductors are spliced to 2 molex connectors. I am...
I doubt there is a fuse on the pigtail, it sounds like your black wire is grounded somewhere. Check black to red, if you get 120 or close to it, your black is shorted to ground.
Jun 07, 2011 | GE Profile JTP56 Electric Double Oven
Hi just wondering about 240 volt.What is the black wire and what is the red one and green and yellow....Which one is L1- N- E
The black wire is Half of the 240 volts. Both the black and red wires carry 120 volts to make 240 volts. The green wire is going to be your grounding wire. The yellow wir is more than likely your neutral wire (although that goes against the electrical code). Tie in L1 to either black or red. Attach the yellow to n. I hae no idea what the E stands for. What color and how many wire are coming from the oven?
May 08, 2011 | Ovens
What distance does the back and sides of the wall oven need to be from the other kitchen cabinets and drywall? What is the voltage and wattage of wall oven? What do the five colors, blue, black, green,...
the installation instructions are in the user manual and the wiring must be done by an accredited , qualified electrician
do anything yourself and the warranty is void
Aug 14, 2017 | Ovens
I have a jenn-air wall oven it has a red wire a black wire a white wire and a copper wire but coming out of my wall is only a red/black and copper what dose the white wire go to please help thank you
IF you nhave a 3 wire feed fronm the house for your range, you connect the red and black for the power and then use the copper wire from the wall to connect to the white and copper wires from the range. All new construction must have a 4 wire feed to a range and dryer.
Oct 26, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
GE JKS05 Electric Single Oven Logo
1,397 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
