Question about Linksys Wireless-G WRT54G Router
How do I know what my key or pass phrase is
I would like to connect to using a new lap top
  • 565 Answers
If u havent changed the router admin password log in it and change the wireless passprhase if u also forgot it but u think u didnt change it use the manual u can find it here
Posted on Dec 27, 2008
Wireless pass key view
LOST WIFI SECURITY KEY WORD
If you have lost your WEP/WAP wifi key phrase there is no way to recover it except go into the router administration settings and see if it is in plain text there. If not then you will have to make up a new key phase and apply it to ALL your connected devices.
In future, write the key phrase down on a piece of tape and apply it to the bottom of your router. You can use a hint instead of the actual phrase.
I use the memo function of my cell phone to keep all my passwords and keys.
Apr 11, 2014 | Microsoft XP Computers & Internet
Setup 64bit pass phrase on Belkin router. All wireless devices say,
Do your other devices support 64bit wep, and are you selecting that as your encryption type on each device. For example I know on my cellphone I have to specify the type of encryption that is used. You might also log into the router, just to double check the encryption type and the pass phrase (even if you are spelling it right).
Jan 31, 2012 | Belkin Computers & Internet
I recently bought asus lap top (N53JN-SX098V) could not connect to the internet thriugh wirless, I have Netgear router could ypu please let me know how to fixed
- first make sure the driver is properly installed by right clicking my computer > manage > device manager > look under network adapter
- second make sure the wireless is turned on (there should be a small light below the touchpad with a antenna symbol.)
- third check which utility is used to connect to the wireless network (if the computer is using the built it one to windows or a third party wireless utility. you can usually check this by checking the icons on the bottom left hand corner of the screen. if you have more than one icon for the wireless network that usually means you have a utility that is controlling the wireless)
- try to connect to the wireless network using the wireless utility (you need to know the SSID or network name and if the network is secured you will also need the pass key or pass phrase.
- If you dont know the wireless key and SSID you can check the router itself by hardwiring to the netgear > opening a browser > on the address bar type in the gateway address (you can check this by opening a command prompt window start>run>type cmd and typing in the command ipconfig in the command prompt window, the default gateway will be listed),
Mar 29, 2011 | ASUS Computers & Internet
Just got a new router with secure password , but having no luck connecting ps3 to net , going through the set up and entering password , but it wont connect
I have noticed on the new modem/routers that the pass key is WPA/WPA2 and its a 26 character pass phrase and is case sensitive. You can change it to a WEP setting and make your own pass phrase if you know how to get into the modem configuration via your PC.
Feb 10, 2011 | Sony Playstation 3 (PS3) Console
DONT KNOW THE NETWORK KEY AND CANT GET ON THE NETWORK
You can use a pass-phrase scanner which will find and display the network pass-phrase and key. Or if its a small network then you can reset the router to factory defaults and use the default password to re-setup the network.. Sometimes its easier to reset to factory defaults but you have to have all your ducks in a row. You need to know the WAN details and any printer specifics and open port details etc.
..and you will have to setup every machine on the network to use the new passphrase/key. ..ooorrrr get a network scanner to reveal the pass phrase/key
Jan 18, 2011 | Computers & Internet
I have the Linksy router set up fir my lap top. I just purchased a kindle and want to conect to the wirelss using the router. It appears on the wirelss set up on the kindle - when I enter the password and...
Recheckyour password at the router. start your browser on the laptop and type 192.168.1.1 into the address bar. A pop up window should appear for you to "log into" your router. IF you have never done this then leave the user name blank and type "admin" in the password. Once your connected to the router, choose "wireless" from the top menu and go to wireless security. Make sure your security settings are set and what the "pass phrase" is. maybe reset a pass phrase and choose WPA for the settings.
Dec 31, 2010 | Linksys Wireless-G WRT54G Router
What is wpa pass phrase while setting wireless printer
WPA with a Pre-Shared Key (PSK), also known as personal. PSK is entered as a pass phrase between 8 to 63 alphanumeric characters in the ASCII format at both ends of the wireless connection. Although PSK accepts a minimum of eight characters, for proper security, it is a good idea to use ample length and should not use a commonly known phrase. This phrase is used to generate session keys that are unique for each wireless client.
WPA pass phrase is a password for the wireless network to make it secured. You can obtain the WPA pass phrase when you access your router. Check the manual of your router for the address, username and password of your router. Go to wireless settings, you will see ther the SSID or Network Name, Network Key or the Pass Phrase and Authentication (WPA/WPA2/WEP). You can personalize the SSID,Network Key and Authentication. Remeber that for you to connect wirelessly the Authentication and Network Key on the router should match the Network Key and Authentication of the Printer or Computer.
Thanks for using Fixya,
Aug 06, 2010 | Computers & Internet
Connection
go to 192.168.1.1 or 192.168.0.1 login as admin. there is no password, along the top you should see something like an administrator tab or something, play around inside there and set it up.
Oct 04, 2008 | D-Link AirPlus G DWL-G122 802.11g/b...
My hard drive got damged and has bean replaced with a new one, I cant get operating system to work more than 30 days. I have installed vista using a reboot disk that came with lap top. The lap top worked...
I AM CURENTLY AWITING ANOTHER REBOOT DISK AS THE MANUFACTUERS OF THE LAP TOP SAID IT MIGHT NEAD THE FULL INSTAL OF VISTA HOME BASIC AND NOT JUST THE REBBOT PROGRAM VERSION I GOT WITH THE PC. AS THIS DOES NOT INCLUDE THE START UP SETINGS THAT CONFIGS THE BIOS TO USE VISTA. ( I DIDNT UNDERSTAND THIS TILL I ACTURLY GOT INTO THE BIOS) THE NEW DISK WILL ASLO INCLUDE A NEW PRODUCT KEY THAT DOES NOT NEAD TO BE CONFIRMD VIA INTERNET TO USE AS IT IS JUST THE BASIC VISTA PROGRAM THAT SHOLD ALOW ME TO INSTAL MY UTILITIS AND DRIVERS TO INSTAL THE MODEMS AND OTHER SYSTEM FILES. WHEN I ORIGANLY GOT THE LAP TOP IN 2007 THE REBOOT &RECOVERY DISKS ONLY HAD THE SET UP PROGRAMS THIS ALOWS YOU TO INSTAL VISTA OPERATING SYSTEM BUT NOT ALL THE PROGRAMS WILL WORK AS YOU NEAD TO DOWNLOAD THE FULL SYSTEM SETINGS. SO JUST TO LET OTHERS KNOW IF YOU GOT A LAP TOP OR PC THAT ONLY HAD A REBOOT DISK TO CHEK THAT IT IS THE FULL VERSION ( NEW VISTA RECOVERY 2008 ) AND NOT THE 2007 ONE
I WIL LET YOU KNOW HOW I DID IT IF THIS WORKS
THANKS FOR THE OFFER
LIL ANDY
Jun 28, 2008 | Computers & Internet
Can't remember security phrase for netopia 3347 nwg to add another computer
Are you talking about your wireless pass key, if nessesary connect a PC directly to your Netopia and reset the pass phrase through the routers control panel/gui, remember you will need to reset all pc conections to the new phrase. If you haven't made any IP changes to the netopia, the default settings are likely to be 192.168.1.254, just use your explorer to browse to this address
Jun 24, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
183 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
