Question about GE Profile 30" Slide-In Gas Range - Stainless-Steel
Spilt hot liquid on the oven controls, only clock working,
GE profile slide in gas range -non of the controls do anything except that the clear/off beeps when touched. The oven is no longer hot. What should I do?
  • sunny4 Dec 27, 2008
    Is there any thing that I can check (eg fuses) to see if it will work?
  • sunny4 Dec 28, 2008
    Turning off power to appliance and restarting it worked.
  • 71 Answers
Let it dry hopefully they will work again.
Posted on Dec 27, 2008
Getting error code F0 during oven cool down. During F0 keypad does not respond to clear error, however after waiting several hours error can be cleared. Next use is fine but error reoccurs during cool...
F0
Stuck touch pad Usually means that either the touch pad or the oven control
(also called clock or ERC) is defective and needs to be replaced. If this fault
code cannot be cancelled, replace the oven control (also called clock or ERC),
touch pad, or both.
Jan 31, 2011 | GE Profile JGS968 Gas Kitchen Range
My GE profile gas range jgbp79wewiww the clock blinks f-2 and i have to light the burners with a match tks for any help
Hi There
I have found the code for and hope this helps you.let me know how it goes.
F2 During Bake Control senses oven temp above 590 degrees F High resistance connection in oven temperature sensor circuit. Check Electronic Range Control (ERC) - Welded bake relay contactsThank you for writing to fix ya.
Best Regards Richard
Mar 20, 2010 | GE Profile JGBP79 Gas Kitchen Range
Error code 'F7'. I presume is a burnt out fuse.
Shorted keypad. Could be any key except clear/off
check the membrane switch or the erc. An FO error is that clear/off key shorted by the way.
I have the exact repair manual. Would you like a copy?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Electronic control touch pad not working
This is your electronic control board that needs to be repalced on this unit. GE Profile is a great brand and it is easy to repair, also.
We provide part removal/installation instructions for our customers when you purchase your parts from us.We also ship parts overnight to assure that you get your oven repaired right away.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 9 PM CST. We look forward to getting you cooking again soon.
Thanks, Ella
Nov 17, 2009 | GE Profile JGS968 Gas Kitchen Range
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
GE gas oven not working
You have a stuck or shorted keypad. Replace the clock control.
Jul 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Error code F7 and controls will not work
I think it have  F7 error not just F...
F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Thanks
May 02, 2009 | GE Profile 30" Self-Cleaning Freestanding...
Buttons won't work
Try unplugging the oven let it sit for thirty seconds and plug it back in. Worked for me.
Mar 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Buttons on Control Panel not working for my GE Profile Gas Range
Anyone has any information as to how to fix my describe problem with GE Profile Gas Range I have.
Thanks
Mar 14, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
GE Profile 30" Slide-In Gas Range - Stainless-Steel Logo
166 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
