Question about Kenmore 63942 Dryer
Function clothes will not dry, no heat
Machine starts, engine rolls, but there is no heat
  • 61 Answers
Hello, A dryer can have no heat for a few reasons, the first thing to check are the breakers or the fuses in the fuse panel. If one fuse is open the motor will run but there will be no heat. If this is not the problem I need more details (make, model# etc.) Thanks good luck
Posted on Dec 27, 2008
Nordmende washer dryer not drying
Check that the heating element is functioning. Check thermostatic cut-out
May 11, 2014 | Equator EZ 3612 CEE Front Load...
Tip
How to Troubleshoot a Clothes Dryer
<span>Instructions</span> <ol> If the Dryer Won't Start <li>Check the plug and reset the circuit breaker. It could simply mean that there's no power getting to the machine.<br /> </li> <li> Make sure the door is closer and the the latch isn't obstructed by any articles of clothing.<br /> </li> <li> Call a professional if these don't solve the problem. More extreme culprits for a dyer that won't start are a bad door switch, a failed drive belt, a failed motor or a bad thermal fuse (protects the motor).<br /> </li> If the Dryer Dries Slowly <li>Clean the lint filter. Remove the lint and clean it with hot water and a toothbrush. A clogged filter can cause slow drying.<br /> </li> <li> Clean the exhaust duct. A clog here can also prevent the drying from drying.<br /> </li> <li> Straighten out an kinks in the exhaust duct.<br /> </li> <li> Remove some clothes from a heavy load. Overloading puts undo stress on the machine creating an eternity to retrieve dry clothes.<br /> </li> <li> Replace the door gasket if it's gone bad.<br /> </li> <li> If the dryer simply won't heat, call a professional. Most causes of this--gas-supply problems, bad igniters, defective thermostat, failed heating coil, et al--can only be fixed by a dryer mechanic.<br /> </li> If the Dryer Squeals or Rumbles When Running <li> Replace the driver-belt idler pulley. Usually a professional is needed.<br /> </li> <li> Lubricate or replace the rollers that support the drum. Can be done on your own, but best fixed by a professional.<br /> </li> <li> Clean out lint from the blower wheel. A clogged vacuum blower is a noisemaker.<br /> </li></ol> jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
on Dec 29, 2010 | Dryers
My Zanussi TCE7124W is not running cycles properly and the clothes are still wet at the end of a run
The filters are clogged.
• The condenser is clogged.
• The water reservoir is full.
• The selected cycle is not suitable for the laundry.
• Insufficient drying time.
• The laundry has not been spun properly.
• The low-temperature function selected.
• Excessive laundry load.
• The dryer is not correctly installed.
Also, check the heater elements.
For the movement, check the drive belt has become worn or snapped. To test your tumble dryer's drive belt, we recommend you manually spin the drum. If it is stiff and difficult to move, the drive belt is ok, if it is easy to move, there's a good chance the drive belt is the fault.
Nov 02, 2017 | Zanussi Washing Machines
Whirlpool Duet Steam is heating up to dry any clothes
Sounds like the heating matrix/element has failed, or some other internal component has failed. If you can return it under warranty, do so. Otherwise you'll have to pay an appliance repair engineer to repair it for you.
Jan 21, 2014 | Washing Machines
Washer is plugged in and it won't start or open?
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring the contents up-either an agitator in the middle of a top- load machine or a rolling drum in a front-loading machine.
Gazebo, Patio Heaters,Heated Towel Rails
May 09, 2012 | Washing Machines
My dryer is not heating the air clothes are rolling and air seems to be blowing but the clothes are damp when cycle ends and they are not warm. what do i need to fix this?
if the clothes are damp then I would disconnect the vent tube, and dry a load of clothes. If they are dry then the vent needs to cleaned. Hope this helps Tim
Feb 06, 2011 | Fisher and Paykel DEGX1 Electric Dryer
The machine fills with water during drying cycle and does not fill for the wash cycle
First, did you know that this machine steam dries clothes? The first thing it does on the dry cycle is to wet the clothes which it then heats to dry with condensation. There are better answers regarding this feature on fixya. But assuming that the dry cycle is working as well as it ever does, it appears that your wash cycle is not functioning properly. I would need more info to figure out why it is not filling with water / working at all.
Mar 31, 2010 | Malber WD1000 Front Load Washer/Dryer
MODEL PBSR353EWOWW. Dryer is functioning but...in
One or more of your heating elements is probably out.
I have a repair album with photos and a manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 14, 2010 | Dryers
Dryer will not heat-up, clothes stay wet even after hours of drying! gas is on, gas bill payed,turning needlessly, no drying.
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Nov 13, 2009 | Frigidaire FEX831CS Top Load Stacked...
Dryer blowing & rolling but no heat
There should be a little white plug on the front of the dryer. (lower left) Take that out and start the dryer. IF your ignitor is working you will be able to see it turn red through the whole. If you dont change the ignitor. then it will light the burner.
Nov 18, 2008 | Whirlpool Dryers
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
