Question about Rowenta Irons
The burst of steam button sticks on my Rowenta steam iron
I've disassembled it and cleaned the rubber plunger and cylinder. They didn't appear dirty; nor was the rubber plunger stiff or aged. I lubricated the surfaces with a dab of vaseline--it worked for awhile but soon the trouble reappeared. If I push the button down, it sticks and only slowly comes back up, and that's after several minutes. Is there a lubricating high temperature grease I can purchase?
kenm9@yahoo.com
4 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: ROWENTA PROFESSIONAL
Try to check the wire connecting to the switch from the steam unit,.,,
Posted on Jun 07, 2008
  • 23 Answers
SOURCE: Cleaning a Rowenta steam iron
According to the manual, you should use regular tap water as long as it is not above 12 grains of hardness. Never use 100% pure distilled water, Rowenta recommends using inexpensive bottled spring water.
Posted on Jul 19, 2010
SOURCE: Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Posted on Jul 25, 2010
The tank in my rowenta iron is producing steam but the iron is not producing steam
Yes the iron needs to be cleaned. They do have a descaler to clean. the Steam valve with a electronic switch is broken, that is what opens and lets the steam out of the iron when you press the button.
Google Rowenta repair Centers.
Jun 30, 2014 | Rowenta DG5030 Iron
Jun 07, 2008 | Rowenta Professional DX8900 Iron
Rowenta DM-880 steam button sticks. Spray button works fine. Any ideas? Thanks.
It is possible that there is dirt that has accumulated into the stem of the steam button and is sticking the button. It is better to remove the lid and make a good cleaning to free the movement. use good spray of jet air, use WD40 to remove dirt and free
This will work for sure.
Aug 21, 2010 | Rowenta Professional DE880 Iron
It is sticky and looks like glue.It looks gooey
Hello :
Here I'm going to tell you the basics of cleaning your Rowenta iron :
Things You'll Need:1:Rowenta Soleplate Cleaning Kit
2: Ironing board
3:Clean, dry cloth
4:Two cotton terry cloths, such as washcloths
Now to the cleaning :
1:Pour out any water from the iron. Turn the steam iron on to the "Cotton" setting, which is the one with three dots on the settings dial.
2:Cover an area of the ironing board with a clean, dry cloth. Fold one washcloth or other piece of cotton terry cloth in half and place it onto the cloth on the ironing board.
3:Dispense a 2-inch long daub of cleaning solution onto the terry cloth. Run the heated iron over the cloth directly on the cleaning solution. Move the steam iron in a circular motion over the cleaner on the cloth for a minute or two.
4:Remove the steam iron from the cloth. Carefully wipe any remaining cleaning solution from the soleplate using the second terry cloth.
5:Add water to the steam iron. Turn on the "Steam" or "Burst of Steam" feature. Run the iron over the clean, dry cloth on the ironing board to ensure the cleaning product is entirely gone from the soleplate.
PLEASE RATE !
Apr 20, 2010 | Rowenta DX6700 Iron
Apr 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
What happens if I use CLR in my steam iron? I have an expensive European style iron which is no longer producing steam. I have bought an iron descaler/cleaner and have repeated its use. I tried the...
The steam tank may not be heating because of mineral deposits in the tank. But also do this check first. Open up the tank reservoir cold, and drain all water out, (is it clean inside there when you shine flashlight in there? Rinse with clear filtered water only (low minerals).
Do not use CLR or anything agressive in there. You should have the main unit in full steam mode and the iron control also in full steam mode. Leave one tablespoon of water in the tank, put back together and let the pressure build. Put a clean towel on your ironing board and when iron is at full pressure and heat, hit the burst of steam and look at what comes out of the sole plate. If you see lots of white deposits look at the sole plate and see if the white chunks are coming out steam holes.
When using iron, run it till steam/water tanks are dry, the burst of steam is used in this case to clean the iron of all standing water. Pull the reservoir and allow to cool...once tank is cool drain it as well. Doing this several times should help purge unit of the heavy mineral deposits.
If you need parts, here is the Rowenta repair facility....
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Mar 12, 2010 | Rowenta DG-980 Iron
Rowenta Professional Iron - steam button suddenly stopped working
Have you tried descaling it? It may well be blocked up with limescale. Personally I only ever buy cheap irons and bin them when they go wrong! As you say-they are generally too expensive to repair.
Jun 11, 2009 | Rowenta Professional DX8900 Iron
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Mar 21, 2009 | Rowenta Powerglide DE013 Iron
Steam button not working
I had the same problem. I found the trigger button at SmallAppliances.com. You'll have to pry off the rubber grip, and unscrew one or two screws on the handle, bu the trigger inserts neatly into the space. Screw it back together, snap on the rubber grip and it will work like new. Below is the part number & price.
Rowenta DG0123 Knob Trigger, Blue $9.99 (plus shipping)
Watch out, the next thing that will go is the on/off switch. Once it starts getting difficult to turn the unit on or off, just plug and unplug it until you get the new part, or you will be stuck one day and need the iron and go to turn it on and it wont start.
The part is $20, and the same site has it available.
Aug 29, 2008 | Rowenta DG-980 Iron
Steam button wont push down
take down and clean the parts where the steam button is the spring could be dead and needs to e replaced.good luck
Sep 10, 2006 | Rowenta Professional DE880 Iron
Irons Logo
83 people viewed this question
Top Rowenta Irons Experts
Steve Allison
Steve Allison
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
