Question about Maytag SkyBox MBV1976A Beverage Dispenser
Skybox won't dispense. Door lights on, but no button lights at al
When I push any button on my skybox unit, it doesn't dispense. It makes no noise, and the red button lights don't light up or flash or anything. The flourescent door lights are on though. Looking for some help with what part might help fix this problem.
  • 700 Answers
Check the unit out to see if its frozen up. there is also sensors that corrode on them due to condensation. if it is frozen just unplug it and let it thaw out.
Posted on Dec 27, 2008
  • 2 more comments
  • Todd Born
    Todd Born Dec 27, 2008
    check the unit out to see if its frozen up. there is also sensors that corrode on them due to condensation. if it is frozen just unplug it and let it thaw out.
  • Todd Born
  • Todd Born
  • Todd Born
My skybox will not dispense. When a button is pushed, all indicator lights flash. All conpartments are full. I have removed all cans from the machine to check for jams in each individual compartment and...
I had this exact same problem and it was the door sensor for the flipper where they come out. I used a door alarm contact and it fixed the issue. $5 to fix it and get it up and running again.
Sep 12, 2010 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox beverage dispenser. will dispense one can
I had the same problem. Found the cover where the beverages dispense to be rusted and not resetting. After the can dispenses, just push the cover back into position and this should help.
Jun 09, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag skybox 1976AAB wont dispence
I had the same problem. The hinge pin on the dispensing door was rusted and this kept the door from closing completly. The door sensor magnet was not making contact with the door sensor and this caused the error. I removed the pin, sanded it down and it before reinstalling. It works fine now.
Apr 05, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox is freezing and making a humming noice.
The temperature in the SkyBox is controlled by the thermostat located within the beverage compartment. If set too high, product can feeze. In addition ice will build up behind the dispenser assembly. The ice buildup can eventually make contact with the circulating fan blade and cause a constant noise.
You should hear the compressor stop running as you turn down the cold control, but prior to reaching the "off" position. Select a lower setting for the cold control, and unplug the unit for 24 hours with door open to thaw out the ice build up. Reconnect power to resume normal operation.
Apr 04, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
3/4 buttons work
mine did the same thing. apparently, if the internal unit gets too cold, it freezes operation in some of the buttons. try turning up the temp to let it thaw, then try the button again. the downside is that when you turn down the temp again, you are likely going to face the same problem.
Jun 06, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Another Dispensing Problem
what is your email i will send you the manual so you can troubleshoot it better
May 15, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Beer won't dispense, last one furthest to the right.
Have you checked the child-lock buttons?  They are located on the right side of the machine and are accessible only when the door is opened.
Sep 10, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox Flashing Lights
I had that problem too, in addition to a backwards cooling fan and the wrong thermostat. I needed to replace a sensor wire in the door, condensation had caused some rust on it.
Al
Aug 26, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
MBV1976AAP
I have the same problem with my skybox. Will not dispense. I found a web site that has the part to fix the problem.Have not fixed it my self yet but this should do the trick.(repair clinic.com)Item#1066720. (board,pcb flipper door)The sensor burns out do to condestation.The sensor is in the door next to the flipper door.Removing this should be no problem with any kind of skill level.Good luck.
Apr 17, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
226 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal De
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
