Question about Thomson 26943GE1 Cordless Expansion Handset
Model 29265 trimline phone handset falls from cradle
The handset will not remain in the cradle when placed on the wall. How do you remove the handset hook to turn it over?
Push the handset hook up and out with your thumb,turn it 180 degrees,and replace it in the slot on the base. Bridrijo D. Howell,Bermuda
Posted on Mar 14, 2009
I need to turn the ringer OFF on my AT&T 210/Lucent TrimLine.....sounds like a fire alarm...!!!
Search Results
FAQs - AT&T® Telephone Store
https://telephones.att.com/product-support/faqs/symptom/1591/89 Tip 1 of 8. If the phone does not ring at all, you may have the ringer turned off. The handset and base have independent ringer programming. To adjust the handset ringer volume: Step 1: Press MENU/SELECT on the handset when it is not in use. Step 2: Press ?DIR or ?CID to display Ringers, then press MENU/SELECT. Missing: lucent
[PDF]TRIMLINE® Memory Telephone 210 - Amazon S3
s3.amazonaws.com/szmanuals/62619bc8d4792f47b6654ed48c3548a3 AT&T and the globe symbol are registered trademarks of AT&T Corp. licensed to Advanced American .... Ringer Volume. The RINGER volume switch allows you to turn the telephone ringer OFF, or set it to ring at LO or HI volume. You can dial or answer calls normally when the ringer is off. Other telephones in your home will.
How to change the ringer tone on the AT&T Trimline 210 - YouTube
? 2:58
https://www.youtube.com/watch?v=xZxexCm7xtk
Apr 30, 2016 - Uploaded by kmbfanofpacman
I just figured out how that works after the day I got the phone and its pretty cool to be honest.Missing: my ‎lucent
[PDF]AT&T 210 User manual - Multi-Link Inc.
https://multi-link.net/wp-content/uploads/ATT-ATT210-Manual.pdf Make sure the ringer volume switch is not set to OFF. You may have inadvertently turned off the ringer. Press. ,. , , . If there are several other phones on the same ... 11. 12. For Customer Service Or Product. Information, Visit Our Website At www.telephones.att.com. User's manual. Part 2. TRIMLINE. Memory telephone 210. Missing: my ‎lucent
Lucent AT&T Trimline 210 Corded Phone Ring tone - Questions (with ...
www.fixya.com > ... > Lucent > Lucent AT&T Trimline 210 Corded Phone
Lucent AT&T Trimline 210 Corded Phone, ring tone related issues. ... If the ringer volume has been turned off, the handset will not ring ? ... ...ring tone im receieveing the voice ring tone but prefer the volume how can i change my ringtone When the phone is sitting in its normal mode hitting the "flash" button toggles through ...
Apr 07, 2018 | AT&T Lands Phones
My V-TECH CS6229-3 phone base does not register the base phone but i can change another phone on this three phone set and it is registered and the phone
Is the handset you are trying to register de-registered? if not it will not register to another base until it is.first de-registered.
To de-register the handset do the following-
With a charged battery in the handset Enter *331734# then without pause Press and Release the Menu Select Button. You will hear a Beep. Handset would then be De-registered..
Then place the handset on the Main Base cradle and follow the instruction that come up on the handset display.if the handset still does not register then most likely the base memory is full and will have to be re-set .
To re-reset the Base:- Remove any handset from the main base cradle. Then Press and Hold the Locator or find HS or handset Locator button until the IN USE light comes on and begin to flash then release it and immediately with out pause press and release it again. That will re-set the base memory. All your handset will then be de-registered and will to be re-registered. Place each handset to be re-registered on the Main Base cradle and follow the instructions on the the handset display and they will register.
Sep 06, 2016 | Lands Phones
Battery charged displaye no link to base
Many models of cordless phones that have multiple handsets require the handset to be cradled in the base unit for identification and link. As long as the handset maintains a charge, the identification remains valid. If you remove the battery or drain the handset to a point where the handset ID is lost, then you may have to re-cradle the handset in the base unit to reestablish link.
Mar 19, 2015 | Lands Phones
When the Talk button is depressed on one of our two handsets the screen reads: "No link to base. Move closer to base and try again." The other handsets performs as it always has.
Hi Jim.
About the problem with the answer received, you should write to premium.support@fixya.com. They usually reply within next working day.
About the system, if you have not sent the system for repair yet, you should do a full system power reset. This is done performing the following, simply disconnecting the power adapter won't be enough:
  • Disconnect all power adapter cables from wallsockets.
  • Remove all handsets from cradles.
  • Remove all battery from cradles.
  • Fit back the batteries in their handsets.
  • Place back handsets in their cradles.
  • Connect power cables.
The procedure above will reset the system and will re-sync handsets to cradles. If that does not work, then some of the units in the system is defective.
I wanted to remind that the feedback given to the expert does not afftect refund procedure, and do not affect your status. In some case I get negative feedback while trying to help dissatisfied
askers in troubles with Fixya service. That is not really nice and pleasant. :)
All the best.
Ginko.
Jan 10, 2011 | Panasonic GigaRange KX-TG5240M Cordless...
We purchased this phone and on the box it claims that it can be mounted on the wall. It CAN NOT be mounted on the wall as the receiver falls off it's hook. There were not installation instructions about...
Often there is a handset catch near the top of the cradle that must be reversed to allow the handset to hang in the cradle when installed as a wallphone. Typically the phone is initially setup as a desk phone, if this catch piece was reversed it would interfere with lifting the handset. Some models have a screw holding this piece in place, some just slide into cradle.
Dec 10, 2010 | Emerson EM-2646 Corded Phone
I cannot use the cordless part of my panasonic KX-TC1221BXB. The following message is shown ''No link to base. Place on cradle and try again'' But even after placing back on the cradle, the same message is...
I couldn't find the exact manual for your phone but I would try to re-register the phone. Following are some instructions for similar models of your phone.
*To do this on a non-expandable cordless phone:
  • Press and hold the LOCATOR/INTERCOM button on the Base until a beep sounds.
  • Press and hold the FLASH/CALL WAIT button on the Handset until a beep is heard.
  • When registration is complete, a beep sounds from the handset.
  • Wait for 20 seconds after registration is complete to allow the handset to establish communications with the base.
If this fails to help: Remove the AC Adapter from the phone base or wall outlet for a few seconds and reconnect. It may also be necessary to remove the battery from the handset for a brief moment.
Mar 06, 2010 | Lands Phones
Philips Dect 215 phone continually bleeping.
Remove all handset batteries and leave for 10 minutes.
Unplug main cradle and reconnect after 30 Seconds.
Replace all handset batteries and place handsets back on cradles.
Oct 06, 2009 | Philips Lands Phones
HOW DO I REGISTER THE PHONE
I had this problem - just found the solution. The two charging stands aren't the same. One is a base (that plugs into the wall) and the other a charging cradle. I think that each handset needs to be placed in the base to "register" it.
So, here's what I did: place the unregistered handset in the base & both should work.
May 04, 2008 | GE 25952 Cordless Phone
GE Model 29265 Trimline Memory Phone
I just purchased the Trimline Model 29265 phone and in the instructions it says that it can be wall mounted if you reverse the handset hook in the base? Where is the handset hook and how do you reverse it. Nothing in the instructions tells you where it is nor how to fix it.
Mar 19, 2008 | Thomson 26943GE1 Cordless Expansion...
2nd handset doesn't work
Hi Rayfatz,
I think your problem might be that the second handset is not registered with the base station. Take the second phone out of it's cradle and place it in the base station (where the first phone is), and leave it there for 20 seconds. Place it back in it's own cradle, and it should start working. Hope this helps! Hal
May 27, 2007 | GE 26938GE1 Cordless Phone
Thomson 26943GE1 Cordless Expansion Handset Logo
301 people viewed this question
Top Thomson Lands Phones Experts
David Burbee
David Burbee
Are you a Thomson Lands Phone Expert? Answer questions, earn points and help others
