TV wont turn on. When I press the power button, the Timer/Stand By light flashes 11 times then shuts...
(More)
TV wont turn on. When I press the power button, the Timer/Stand By light flashes 11 times then shuts off
KP 41T15 Sony Projection set. The timer light flases constantly . As you power up the tv..you can...
(More)
KP 41T15 Sony Projection set. The timer light flases constantly . As you power up the tv..you can here it click on then you have the flashing light. You can shut it off and it will power off. Power it up..cliks shuts down...power it up ..cliks shuts down..power it up it cliks and timer flashes constantly. No sound or video.
Vertical line in middle of screen. Half screen is ok. The right half shows color washou All...
(More)
Vertical line in middle of screen. Half screen is ok. The right half shows color washou All indications point to Light Engine But what about a cold solder joint in this subsystem
I have two Philips PTV. Model#50P8341A when powered up...The power button will flash 5 times pause,...
(More)
I have two Philips PTV. Model#50P8341A when powered up...The power button will flash 5 times pause, flash 5 times pause etc. The other Model#55P8341 when powered up will flash 4 times and pause, flash 4 times and pause etc. What is the code for the flashes and the board that needs worked?
