Question about Pioneer CDJ-800 Turntable
CDJ 800 not working due to Voltage Selector?
I was having trouble recording a set on my computer - too much feedback and distortion which seemed to happen with no real reason. So I though I would change the voltage to see if the input to my computer would make a difference. Well, I unplugged to cord as it says to do, switched the voltage over and tried turning it back on once I had plugged it in again. Now it doesn't work on either of the voltages?! Can someone please help me?
  • 515 Answers
What do you mean you changed the voltage? Why would you think this would work? What were the voltage settings originally, and what did you change them to?
If you had too much feedback or distortion, your gain was probably too high, or you had the recording volume on your PC set too high. This has NOTHING to do with voltage. The voltage setting on these units is strictly for 120V or 220V use. Meaning, it can be uses just about anywhere. If your unit is not working, it's because you probably fried the power on it. Are you in Europe, and you tried to set it down to 110/120V? If so, you surely fried it.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Apr 30, 2009
CDJ-800 Mk1 No sound output!!!
Not true! CD channels don't require a pre-amp and the cartridge for a turntable does. I suspect that when the power went off the mixer was still on, so that when power was restored it came back on. However this resulted in a surge inside the unit. Magnetic cartridge pre-amps are often very sensitive to this kind of thing and will sometimes fail, while everything else works fine. This would result in no sound from the record decks, but sound from CD players etc.
Apr 13, 2013 | Pioneer CDJ-800 Turntable
Power problem, CDJ wont turn on propperly as it is from the US and i live in Birmingham UK
The step down adapter should work fine as long it supplies the voltage and any other ratings shown on the turntable power supply indication pannel. However the problem might already have happened. If the fuses were before the power entered the mains transformer of the unit, then if they were set to blow above the USA voltage then things could be OK. However if the the fuses were in the secondary output from the transformer then the mains will have caused possible damage to the transformer. Maybe even elsewhere.
Jan 15, 2013 | Pioneer CDJ-800 Turntable
My touch release is turned to the fastest setting yet when I release the cd to start it drags for the first second then plays normal
I believe you are trying to play a record rather than a CD. It is slipping on the mat when you start playing. Your other CDJ hasa better "grip"
Sep 30, 2012 | Pioneer CDJ-800 Turntable
I want to purchase a pair of pioneer CDJ 850 players, however in my country the power supplied is 110 volts at 50hz. I have had problems using electronic devices that only specify 60hz. The CDJ 800's...
The 850's should work fine on 50Hz. They are spec'ed at 120/60. with your lower voltage the transformer in the power supply should NOT have a problem. There is nothing syncronized to line frequency so it should work fine.
Jun 01, 2011 | Pioneer CDJ-850 CD PLAYER
Not reading cd's
First clean the laser head with a Qtip and alcohol. It gotta be perfectly clean, so wipe with fresh brand name qtip and make sure there is not a single dust particle on it. You gotta remove the cabinet with star screwdriver. Your beam might be tired. First try with the clean up! You can get a replacement unit, here http://1200s.com/Store/PARTS-PIONEER-CDJ-800/c271_461_491/p320015/Pioneer_-_CDJ800_CD_Mechanism_w/Pick-up_Assembly/product_info.html
You might want to bring this to a pro sound shop for repair. I'd order the part by myself and bring everything at the repair shop...
Oct 10, 2009 | Pioneer CDJ-800 Turntable
Hi I have a Pioneer cdj 800 mk1 and the cue button is stuck
i had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do PIONNER CDJ REPAIRS AND SERVICING
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
Sep 28, 2009 | Pioneer CDJ-800 Turntable
Jog wheel hesitates when i release it
in dj mode they are ment to act like turntables give a little push in the right direction when you release.
Feb 24, 2009 | Pioneer CDJ-800 Turntable
How do I connect CDJ 800 to work on mixer AND surround speakers?
you did not mention that you have a power amplifier to drive your Speakers. well you need to have one unless you have a powered speaker. the sugnal comes from the mixer main output goes to the input of your amp. or powered speaker.
Feb 03, 2009 | Pioneer CDJ-800 Turntable
Round lcd?
Unfortinetly i cant recommend to you a quick fix or a quick check as the fault seems to be intermittent,
i would suggest taking the player to your cdj pioneer dealer.
email: info@audiovisualservices.info for all your dj equipment repairs.
Thanks.
Aug 16, 2008 | Pioneer CDJ-800 Turntable
No sound from CDJ-800 MK2
Are you getting error messages? Running in thru LINE? Is not on mute? The possiblity of both not playing would lead to process of elimination.
Keep me posted.
Oct 19, 2007 | Pioneer CDJ-800 Turntable
Pioneer CDJ-800 Turntable Logo
211 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
