Question about Dishwashers
My Kenmore Dishwasher has suddenly not responded to any commands on the command board. The model # is 665 #158957791 Please help.... Roger
  • ellisrs Dec 27, 2008
    Huum - You have given no other option to try.
  • 750 Answers
I do not know what happened??
we were in the middle of the chat and I lost you!!???
I lost you suddenly
Posted on Dec 27, 2008
  • 3 more comments
  • Neil Golan
    Neil Golan Dec 27, 2008
    Hold tight I'll get back to you in a few moments we can do it this way!
  • Neil Golan
    I'm working on it.
  • Neil Golan
    Did you double check the sticker in the dishwasher for why there is more than 11 numbers in the model number?
    I'm sorry about the technical difficulty with the chat. It cut me off and I do not know how to get it back!
    Send me the model number after you checked it and i'll find your solution anyway like this!
  • Neil Golan
    There was an extra 1 on the end of the model number 665.1589579
    i'll get back with some answers in a few. There is still no power or lights at all. Is this correct?????????
  • Neil Golan
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    st1\:*{behavior:url(#ieooui) }
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    Hello Roger,
    Your dishwasher does
    not work at all.
    So I put together a
    list of four common problems for the total shut down of your Kenmore
    dishwasher.
    Burnt or broken
    wires
    Check for burnt or broken wires. This would include the
    wires on the timer and door switch. Also check the wiring connection where the
    main power connects to the machine.
    Defective Timer
    The timer is a series of switches that controls all machine
    functions. If one of the contacts in the timer is defective, the machine will
    lose that function. knowledge of the the use of a vol/tohmmeter is essential to
    testing the timer as well as the ability to read the timer sequence chart that
    is supplied with the machine. In most cases this requires a professional
    technician.
    Door switch
    The door switch is wired in series with all components on
    the machine. If the door switch is defective, the machine will do nothing.
    Check the door switch for continuity.
    No Electrical
    power
    Ensure that the proper voltage is being supplied to the
    appliance. Check the breakers or fuses that are supplying the power to the
    appliance electrical outlet. You can use a voltmeter to test for voltage at the
    electrical outlet.
    Control panel may
    be shorting out and need to be replaced
    Unfortunately at this
    point it will need hands on service with a on location diagnostic to determine
    which of these four problems exist.
    I want to apologize again
    for the crash of our chat this evening!
    I forwarded a report
    and complaint to fixya.com of this occurrence!
    Sincerely, Huuum
    Feel free to request
    me and or contact me any time!
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
Can't turn on TV not on standby
Hi Dave,
You have not mentioned anything about the brand and model of your tv. Anyway, If your remote control is working and your tv is not turning on means either the main board is not supplying "power on" command to the power supply section or the power supply is receiving this command but not responding to it. Please consult some local TV tech to solve your problem.
Good luck.
May 24, 2015 | Televison & Video
I just installed a Kenmore Elite Dishwasher. The Dishwasher will not run and is not responding toany commands. I checked the powersource and water supply to the Dishwasher and everything is working fine....
If there is an assembly manual, check it! There are sometimes hold downs and protective strips placed on the machine at the factory to prevent tampering. There is probably one that is stopping the power from reaching the control panel. It may even be in the control panel!
Dec 31, 2012 | KitchenAid KUDD03STSS Stainless Steel 23...
Am having problems with a 347002k, we have this recycler for some time and have replaced even the compressor. I think we need the digital control board with the input command (where you input the steps)....
You may did something wrong with your machine! Please try the following: 1# Switch ON the main power.2# Re-set (booth) circuit breaker (press booth breaker at the same time) & see if the screen is appear.3# If the screen is not appear after re-setting circuit breaker then you have to replace new control module.Hope this will help you.
Feb 18, 2010 | Robinair Cool Tech 34700Z Recovery,...
My A920 has stopped responding to my print command
go into the control panel into the printers icon. Make sure your a920 printer is set as the default printer.
Jan 25, 2009 | Dell A920 InkJet Printer
Kenmore Model 587 -- Will not run - Power lights come on/wontrun
Hello I am V- Mari and i own a Kenmore dishwasher model Number 587.1574590 and it doesn't work at all. The power light comes on and it seems to make noise, but it does nothing. Is there a recall for these models or free fix help please respond to miss_vmari@netzero.net. I would like to solve my dishwasher problems as soon as possible. Thank you!
Dec 12, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Sony MW24FM1 either won't respond to DVD commands, or turn-off
Sounds like a bad power board. They have random meltdowns all too often. Usually the cause is an overheated transformer caused by power transistor short outs. Possibly sell it. Could get over $100 for it if sold online.
Nov 14, 2008 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Dishwashers Logo
241 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
