We can't connect to the on a new computer with your adapter.
We have a new computer in another part of the house. We installed the new wireless adapter and went through the CD installation process. When we click internet to go on the web, it's asking us which program we want to go through, all of which we are denied acess to. Also, in the Control Panel/Network Connections part, there is nothing on that screen and it should show LAN or High-Speed Internet and there is nothing there.
  • 1 more comment
  • dtsnipes Dec 27, 2008
    PCI-G802
    I just gave the adapter name; that was not accepting a solution since I still don't have one.
    The router is an Airl Link 101 11G Wireless Router
    Genius:
  • 1,124 Answers
1) First check that the new computer has installed the wireless card o has one available
Then On the new computer do this:
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
Posted on Dec 27, 2008
  • 837 Answers
What OS? What kind of wireless router do you have?
I don't have my user name and password for my wireless network and need it to connect a wireless printer
If you have the CD that comes with the adapter then you can try uninstall Linksys software and install only the drivers of the adapter.
Remove the Linksys Adapter and un-install the Linksys Software from Programs menu. To re-install the Drivers insert the Linksys Setup CD into your CD-ROM drive. When the Welcome screen appears click Exit. Connect your USB adapter to the computer. When the Found new Hardware Wizard window appears, click Install the software automatically (Recommended) then click Next. Click Finish when the installation is complete.Try to connect to the wireless network again. See if that works. You can also download the latest drivers from Linksys website on any other computer. Save it on a Flash drive and transfer the drivers on your computer.
Oct 10, 2011 | Linksys 2.4 GHz 802.11b Wireless - B...
Tip
Do you have a Tivo Premier and are you experiencing wireless communication...
Recenty, I discovered that devices were dropping off of my wireless network (Netgear N300 wireless N with DSL modem). After trial and error, the solution to the wireless communication problems was to create a wireless N bridge using the Tivo Wireless N adapters.
To use this feature, you will need two Tivo wireless N adapters. One wireless N adapter should be set to bridge and plugged into an available ethernet port into your router. The second adapter should be set to client and plugged into the ethernet port in the back of the Tivo Premier. Once the power has been applied to both wireless adapters and the Wireless adapter (connected to the router) has connected to an available address on your router, press and hold the button (on top of each adapter) to establish a secure wireless connection between both adapters.
Once each adapter has established communication, you will have a separate 5Ghz Wi Fi signal (as well as a channel )dedicated to you Tivo devices throughout the house. Each Tivo Premier added to the house should have the wireless N adapter and connected using the secure connection to the wireless bridge by pressing the button on each adapter (the one on the router as well as the one on the Tivo to install).
If sucessfully installed, you should be able to connect to all Tivos on the network for management as well as streaming. If communication between the Tivos isn't successful, you will have to restart each Tivo and establish a new connection to the Tivo service.
Another suggestion when using the wireless N adapters is to setup a static IP address on each Tivo that is higher than the IP address assigned to the wireless adapter. Each Tivo utilized two IP addresses for each device (one for the adapter and one for the Tivo). You may have to check the router administration screen to determine the IP addresses used for the wireless adapters before establishing a static IP address for the Tivos. If you assign static IP addresses to each Tivo, you will have to restart each Tivo and reconnect them to the Tivo service to establish proper network mapping.
With this wireless network configuration, you will ensure that your Tivos are connected to the service using high speed, dedicated wireless N communication for streaming purposes between the services offered while not impacting other computers, servers, video game machines, and tablets that are connected into your house.
Since the Roamio uses a built in wireless adapter, you may not have success in adding a Roamio to the wireless bridge created on your router unless you disable the built in wireless adapter and purchase the external wireless N model from Tivo.
Instructions on setting up wireless bridge can be found at this location:
http://support.tivo.com/app/answers/detail/a_id/1590/kw/wireless%20n%20adapter
on Oct 02, 2013 | Tivo Premiere 4
I want to get the TIVO AG0100 wireless adapter. I do not have wifi in my house so will it still work? I'm not planning on getting wireless for my computer.
Dear,
Since it's an adapter and not a router, it will not work if you don't have a previously installed wireless network.
You might buy a wireless router and connect it to your computer and use Tivo at the same time.
Jul 22, 2011 | Tivo AG0100 Wireless G USB Network Adapter
How to install an wirless adapter to mi desktop
Install a wireless network adapterIn areas that are served by a wireless network, you can connect to a computer network without using a cable, and surf the Internet or connect with other computers. To connect to a wireless network, your computer needs a wireless network adapter.
Many new computers-especially laptops-come with wireless adapters. Before using your computer, check to see if it already has a wireless network adapter.
If your computer doesn't have a wireless network adapter, you can install one.
Install a wireless USB network adapter. Most people prefer this type of adapter for any type of computer, because it's easy to install.
Install a wireless CardBus or CF network adapter. For portable computers, this type of adapter (also called a PCMCIA or PC Card) is easier to travel with than a USB adapter, because it is often smaller and fits securely in the PC Card slot on the side of the computer.
Install a wireless internal network adapter. If you have a desktop computer, you may prefer an internal adapter so that you can use the USB port to connect another accessory.
The type of adapter you install depends on your computer and your level of expertise.
How to determine if you already have a wireless network adapterMany portable computers manufactured after 2000 have wireless networking built in. However, because the antenna is hidden inside the computer, it's not easy to see.
To see which network adapters are currently installed in your computer
1.
Click Start, and then click Control Panel.
69010-click-control-panel.gif 2.
Click Network and Internet Connections.
69010-click-network-and-internet-connections.gif 3.
Under or pick a Control Panel icon, click Network Connections.
69010-click-network-connections.gif 4.
Microsoft Windows XP displays your network adapters. Wireless network adapters are labeled Wireless Network Connection. If an adapter displays a red X, it is disconnected. If the Network Connections window is blank, your computer doesn't yet have a wired or wireless network adapter.
Nov 12, 2010 | Computers & Internet
We have roadrunner with wireless in our home. I
it could be, maybe you can try on other versions of xp, maybe try another xp service pack, and of course it should be genuine. non-genuine os' specially xp, have edited or modified databases often leading to some hardware issues. try browsing also, microsof knowledge base and see if there are any hotfixes for your problem.
Jun 03, 2010 | NetGear WG111 802.11g/b Wireless Adapter
The ploblem is In need the solution of wire less network to build in the big house.
I presume you need Internet access in this house using a wireless network.
The best place to locate the wireless router is in a spot centrally located where the radio signals can reach the rooms where the computers are located. The DSL or cable modem/connection would also need to be in this area so it can connect to the wireless router.
If the wireless router is in a multi-storey house and the floor slab and walls are concrete and/or brick, then the radio signals will be impeded and the signal strength to some rooms will be weak.
In such circumstances, it maybe better to install network cables from these rooms to the wireless router, or install wireless access point repeaters to increase wireless coverage.
If you are not sure how to setup and install this network, then I suggest you get help from a computer savy friend or from your computer friendly shop.
Nov 04, 2009 | Adapters.com Computers & Internet
My computer will not install the wireless USB software. I need help. I get through the first couple of prompts and then it just looks like it keeps loading but does not.
What is the operating system on your computer. If it is windows XP or VISTA, then try to install the adapter using the found new hardware wizard.
Do not run the disc that comes with the wireless adapter. connect the adapter to the computer first. you will get the message found new hardware.
if you do not get the message that means the adapter is detected by the computer or the software might be installed already. uninstall the software and then connect he adapter.
If you get the found new hard ware message then it will ask you can windows connect ....
select = no not at this time and click next.
on the next window select the option install software automatically and insert the disc that comes with the adapter. it will install the software .
after that you will need to connect to the network.
Click Here for more info
Oct 06, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
D-Link WUA-2340 RangeBooster G USB Adapter Installation Issue
http://support.dlink.com/products/view.asp?productid=WUA-2340
Mar 07, 2009 | D-Link Rangebooster G USB Adapter...
Can't connect To internet w/ Wireless
try uninstalling it and re-installing it. the problem may be with its drivers.
Jan 24, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
How can I install a wireless usb adapter WG1111....
First put in the cd that came with the wireless USB adapter. Close the auto setup page(we will use windows wireless network manager which works better with windows firewall . Plug in the wireless adapter and the laptop will automatically install the driver. If for some strange reason it asks you to install new found hardware, follow the promts and install manually and select cd and the directory the WG1111 drivers are located. Press ok and wait for install. Restart the computer.
After restart the computer will come up with a caption New Wireless Networks found. Double click on the wireless Icon in the bottom left hand corner. It will open a seperate screen with all wireless connections avaliable to you. Might be 1 or more networks, depending on whether your neighbours have wireless networks. Anyway find your specific wireless network could be for example NetGear, Dlink, or my home network. Click on connect your wireless connection. Another smaller screen will appear with Key in your password twice( WEP key or WPA key)
Key in your key or password twice and apply or ok. It will connect and close screen.
Restart computer!
After restart the computer will pick up your connection automatically and your ready to go on line. If you move your mouse down to the icon with wireless network in bottom left hand corner it will show your wireless connection in a caption stating the connection name and how strogn signal is. Connection complete.
NOTE: YOU MUST HAVE A WIRELESS MODEM OR WIRELESS HUB CONNECTED TO YOU MODEM TO USE THE WIRELESS WG1111. THANKS!
Aug 02, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
