Question about Alpine MRP-M350 Car Audio Amplifier
Weak rear left amp output?
Hello..I installed a new head unit,alpine cda 9886 with two rear alpine 5.25 in a jeep wranglers roll bar.I bridged the speakers with an alpine mrp-250.the right speaker sounds great,but the left barely has anything emmitting from it.I double checked all the connections and even flipped the speaker connections with the same result...any suggestions..crutchfield thinks i have a bad amp...
  • 3 Answers
Hey whats up bud i got an ALPINE V-POWER MRP-M350 these amps are great go to a walmart od any music shop buy a set of R.C.A cables that plug into your amp than that Ys off to a single connection its a male cable that run a set from the back of your cd player heres the trick ONLY PLUG YOUR BLACK COLORED RCA INTO HEAD UNIT MAKE SURE YOU RAP THE RED ONE WITH TAPE OR GET A RUBBER CAP TO PUT OVER IT SO YOU DONT GET ANY STATIC FREQUENCIES COMING OUT OF THE RED ONE THAN RUN THAT SET TO YOUR AMPLIFIER AND AGAIN ONLY TIE INTO THE LEFT CHANNEL OF YOUR AMPLIFIER.... Hope you know wnat i mean by that Y adapter ther is 2 prongs that tie into amplifier than it splits into 1 were your rca cables will plug into just that one thats how you bridge these confusing amps.... TRUST ME BOTH SUBS WILL SLAM HARD I RUN 2 JL AUDIO OFF OF MINE NO PROBLEM.... WRITE BACK TO ME IF YOU HAVE ANY PROBLEMS OR WHEN YOU GET IT HOOKED UP MY EMAIL ADDRESS IS gordo8785@yahoo.com hope to hear from you soon...
Posted on Jan 10, 2009
Poor reception with Alpine cda 7892
I found the manual at Alpine.com.http://vault.alpine-usa.com/products/documents/OM_CDA-7892.PDF
Apr 15, 2012 | Alpine CDA-7892 CD Player
Replace my citreon c4 head unit
what year is your car?newer cars 1999 and up the radio wiring harness goes thru the ecm (electronic control module).if that head unit is not supported it wont work correctly.in a bad case senario the head unit could damage the ecm.
Nov 03, 2007 | Alpine CDA-9847 CD Player
What does it mean when the rear of a head unit is
you probably have a bad output ic inside the deck.
Jun 16, 2010 | Alpine CDA-9811 CD Player
I would like know whether a sony xplod subwoofer can be connected to my alpine car audio system! xplod sub woofer is 1100 watts.
Deffinitely but wired directly would be pointless, the Alpine's internal amp is way to weak to get the best out of the sub. You need an amp, minimum 300w and bridge the outputs to give all the power to sub preferably switched to low-pass (most amps will have a high / low pass switch)
Dec 07, 2009 | Alpine CDA-7892 CD Player
Volume issue with Alpine CDA-7839 and Soundstream Continuum
Interesting that you have a Soundstream "The Continuum" amplifier. This is limited edition of the Reference 705 amp produced with a polished aluminum (not chrome) case. You have a very hi quality - Old School - amp.
Properly installed this amp should produce more than ample volume levels and certainly far more than a stock unit.
Because the Alpine head unit provides sufficient voltage to drive the amp, it is likely either the wiring, or, the way you have it set up.
The amp has a large internal capacitor bank and for proper operation, this amp must be connected directly to your car battery, prefereably with 4 AWG. (The amp is made with 4 AWG power connections.) Use high quality speaker wire run directly from each speaker to the amp.
If you have done the above, then it is probably the way you have it set up. The amp is sophisticated with many configuration options. Do not change any switch settings while the amp is playing. Ensure you have the appropriate inputs and crossover selected. Check the gain settings.
Jul 12, 2009 | Alpine Car Audio & Video
Alpine cda-9811 is not accepting amp as external amplifier?
The signal should go from the head unit to the amp to the subs. Someone must not have wired the subs correctly through the amp, or amp to the cd player..
Jul 08, 2008 | Alpine CDA-9811 CD Player
Alpine CDA-7873 (Same as CDA-7876 basically)
the blue line from the radio harness does not have power when the cd or aux are being used and the amp is not turning on-wire the remote line from the amp to the red line and your amp will stay on and you will get sound
Mar 27, 2008 | Alpine CDA-7876RB CD Player
How to wire a stereo system
Connect the 2 gage to the battery thru at least s 50 amp fuse, then connect the capacitor in line before the amps. Then run the 2 gage to a connector/splitter block and run 4 gage leads to each amp. You also will need at least 4 gage ground leads from each amp to a body grounded bolt or screw. You need to run a quality set of speaker leads from the head unit to the amps. The speakers will need separate leads from the amp to each speaker.You will need to try some different combinations to get the sound and bass you want. You want to be able to fade from front to rear and control everything thru the head unit.
Use a hole saw to cut a 2 to 3 inch diameter hole in the side of the speaker box for a port to get a better punch from the sub.
Hope this helps some....
Nov 03, 2007 | Alpine CDA-7863 CD Player
Alpine cda-7892 Head unit overheating
Certainly, the output IC might need to be replaced, also check to see if there is a factory amp somewhere in the car. Additionally, double-checking the wiring is a must. How long does it take for the unit to heat up?
Mar 28, 2006 | Alpine CDA-7892 CD Player
Alpine MRP-M350 Car Audio Amplifier Logo
178 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
