Question about RCA P46812BL 46" Rear Projection Television
Cant realign the color on my tv
RCA Model P46813BL Chas PTK195AA I moved into my new home plug in my tv and it worked fine for about two weeks and when I went to turn it on one day the colrs on the set were seperate Red Green Blue there use to be a convergence adjust option in the menue but it's no longer there can you help me I have been searching convergence boards but I'm having no luck
  • puterguy May 20, 2008
    I have the same problem three seperate colors. Did you fix yours?
    Scholar:
  • 77 Answers
It is probably the convergence Power supply usually mounted above the main boards below. Most of them use a STK730-010 amp that is usually the problem, if not some used a little FET instead. It seems that PCB is available probably listed as a power supply rather than a convergence bd though
Posted on Apr 21, 2007
    Problem Solver:
  • 4 Answers
Joshtv poster that the problem was probably the convergence board power supply. I tried what he said by first checking if I had that component in my tv - which I did. I looked on ebay for that part number - and bought the part for $1.30us. There were 11 pins on the power supply (had to desolder it then remove it and place the new part in it's place and solder each of the 11 pins - always be careful not to overheat the leads as you solder them - use a heat sink if you can to avoid damaging the power supply). The tv worked fine after that.
Posted on Jan 12, 2009
I have a panisonice t v but cant get any color on it every thing else is fine.help
  • pcricket2 Jan 12, 2009
    every thing works fine except i cant get color
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
I have a RCA Home Theatre TV Model# P46813BL and we are having trouble congiguring the screen. We had a fuse blow, and have replaced it, but now our picture is off. We have used the TV remote to pull up...
If the color are separated then you need a new convergence board, or have it repair. If the controls are not working correctly then the processor could have some garbage in it, do to a small power surge, and you will need to leave the set unplug from the wall for 40Min. and it will reset back to normal.
Mar 08, 2011 | RCA P46924 46" Rear Projection Television
Have a projection tv...RCA model 61830BL. Had
Hi the green cross it cant move that the reference for red and blue adjustement ;just try to put the red and blue cross over the green pattern then quit/
if that doesnt work you probly have the stk-xxx ic
who control the color alignment ,are blow/
you will have to replaced and make the convergence
check if you have an auto adjustement for that most projection tv have one...
hope that help..
Mar 28, 2010 | RCA P61830BL 61" Rear Projection...
Rca hdtv rear projectiontv.how to adjust focus
You will want to use a funtion called either convergence or auto convergence. It realigns the 3 colors to the correct possition on the screen.
Feb 28, 2010 | RCA R52WH76 Television
Color convergence out of wack
A professional tv technician can realign convergence or you can try to manually realign it yourself via little knobs under one of the tvs panels near the lamps.
Jun 27, 2009 | RCA P52926 52" Rear Projection Television
Stretched screen
Try the menu under setup, find convergence, it realigns the colors,, you are suposed 2 do that periodicly,, or when u move the tv,, should help you ,, ive got that same tv,,
Oct 05, 2008 | RCA P61940 61" Rear Projection Television
No Power
Try removing the Green CRt PC voard that is on the bottom of the green Picture tube which is the center one. Then replace the fuse and see if your set powers up if it does you need a new gree tube. Just be sure the crt board doesnt touch anything while you try it. then let me know what happened, if you need a tube they arent available new any longer but I have a source for good used picture tubes,
May 22, 2008 | RCA P46812BL 46" Rear Projection...
T.V. problems
  • do not worry.
  • just put it on for the whole day till you are at home.if any moisture is there it will dry out.
  • it may give you problem two or three times but it will be ok.
  • good luck.
Oct 12, 2007 | RCA TruFlat 27F520T 27" TV
RCA 27"
I suggest you check your Direct TV box. It may be off frequency. Stargazer
Jan 05, 2007 | RCA 27F650T 27" TV
Televison & Video Logo
303 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
