Question about Dryers
Replace the ingniter Asm for a Ge gas dryer
How do I disassamble or gain access to the ignitor Asm. for GE DBXR463G dryer
I continued to search the internet and found a site that offered the info needed to open up the dryer to gain access to get to the ignitor. Buy removing 2 screws in the top of the door opening to remove the top and removing 2 screws at the top inside wall panel it removed the whole front.
Posted on Dec 27, 2008
Need some help to open a GE GFDS350 dryer to gain access to the gas valve to convert it to LP
Hi
Please check this video; though it is for gas valve coil replacement however, it gives you step by step instructions on how to access the valve:
Hope this helps...please post back for further assistance.
Daniel
Jun 30, 2011 | GE GFDS350GLWW Dryer
I have ge jgp337 . My gas stove started ingniting without turning the burners on and all flame started coming out from all 4 burners. i switched off the electric switch now even after 2...
I've seen this problem before. It happens when spillage get's into the ignitor switches. The switches are mounted on top of the gas turn-on valves. You have to replace all the ignitor switches because they are connected into wire harness. Rich
Aug 15, 2010 | GE 30 in. JGP337 Gas Cooktop
GE Profile gas dryer tumbles but NO HEAT, not ignitor
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 30, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Have a GE gas dryer and I just replaced the ignighter. The dryer worked twice before it stoped glowing. How can I test the coils to see if this is the problem.
You'll need a circuit tester which is able to reach the ignitor. Check the circuit to ensure adequate amps reach ignitor coil. If the tester indicates a fault or short any new ignitor will simply fail after a use or 2. Also check the gas line were it enters the dryer. Many have an auto shutoff which cuts the gas off if it detects a problem. Some models also cut power as well.
Feb 19, 2010 | GE Dryers
GE Dryer DDG7580B does not heat. vents are clear, dryer tumbles, just no gas ignition. Other gas appliances working well. Help!
Replace the ceramic ignitor WE4X444. An easy fix. Nut is on the gas valve (not the line) to remove the burner assembly to replace the ignitor.
Good luck..
Jan 31, 2010 | GE Dryers
GE Gas Dryer (Model DQSR 483) Drum works but does not heat
There are three things besides what you aleady checked:
1. Open the small access door in front of the dryer and start the heat cycle. The ignitor must glow a bright orange so that it is hot enough to light the gas. If there is no orange glow, then the ignior needs replacement.
2. If it glows then cuts off, then glows, again and cuts off, the thermocouple sensor wire is out of position. It needs to be very, very close to the ignitor. This thermocouple sends a temperature signal when it senses that the ignitor is hot enough to ignite the gas. Unplug the dryer. Re-position the thermocouple wire mount so that the thermocouple wire is almost touching the ignitor. You may also "bend" the wire. Plug power back on and heat.
3. If it still does not heat, then the automatic gas valve that is controlled by the thermocouple sending unit is broken. The automatic gas valve cannot be safely "fixed" and must be replaced.
Hope it's just the thermocouple wire.
Oct 01, 2009 | GE DBXR463EBWW Electric Dryer
Model DBSR453GB1WW bought around 2004/2005 - Dryer runs but will not heat up?
This model uses an ignitor, you can replace the ignitor for about $80
May 12, 2009 | GE DBSR453GBWW Gas Dryer
My ge gas range will not heat up
Inspect the ignitor for a crack or break in the continuity of a ceramic ignitor. If you can't visually discern a failure, then a multi-meter is need to check for resistance through the ignitor.
Jan 05, 2008 | GE JGBP26 Gas Kitchen Range
GE Profile Gas oven igniters
  If it is also a round ignitor it's the same.
Oct 24, 2007 | GE Spectra JGBP30 Gas Kitchen Range
Dryers Logo
90 people viewed this question
Top Dryers Experts
Marvin
Marvin
