Question about SanDisk Sansa E280 MP3 Player
Connecting to my PC
My OS is XP, which has been updated. When I connected my new e280 via the USB cable to the computer the MP3 player noted the connection but XP doesn't see it.
  • Eric Tobias Dec 27, 2008
    Can you clarify your suggestion? It does not appear that the e280 has a usb mode under settings.
  • Eric Tobias Dec 28, 2008
    I solved the problem, which can be helpful to other users. It worked when I connected the MP3 player directly to the Computer's USB port instead of connecting it via a divider (i.e., one connection to the computer resulting in four additional USB ports). My son said he had the same problem a while back where his MP3 player was only recognized by the computer if connected directly to the computer. I am not sure why but it does seem to be the case.
    Problem Solver:
  • 6 Answers
Change the usb mode in the settings menu to msc. if u hav trans. files to it thru win media alredy, delete the music' but NOT THE MUSIC FOLDER SYSTEM WILL NOT BOOT IF NO FILE.
Posted on Dec 27, 2008
The device can not be detected in my computer
Hi there.... You can try other computer if they can detect the Sony Walkman that you have, if not being detected, have the device physically check.... if being detected by other computer, try updating the driver or software for that Sony device..
Thank For Using Fixya
Jun 03, 2011 | Sony Walkman NWZ-B135 MP3 Player
My desktop (XP Pro SP3) does not recognize my Sansa e280
Try to unplug/replug the player or better try to connect it on a different USB port then after that restart the computer that should do the trick..
Hope that helps.....
Sep 04, 2008 | SanDisk Sansa E280 MP3 Player
What leds do i need to hook up to my pc
Usually almost all MP3 players can be connected to a computer via USB connection , using the usb cable or by directly connecting the unit to the computer USB port and from that you can do the transferring of songs from computer to the MP3 player.
May 28, 2011 | Audio Players & Recorders
Hi, my pc don't read the mp34 audio player =( help!!!
Why is my mp3 and mp4 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see mp3 and mp4 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the mp3 and mp4 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: mp3 and mp4 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 and mp4 Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for mp3 and mp4 Players when used with Windows OS.
The mp3 and mp4 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
May 05, 2011 | Digital Audio NAP256 MP3 Player
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
4. Power issue.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
STEP 1 - Connect the Sansa player to the PC
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
My mp3 player does not recognized by computer, i want to load some music. how do i solve it?
4. Power issue.
- Run the hotfix.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS.
The Sansa player will show up on Device Manager's right pane as:
Instructions to connect in Forced MSC mode are listed here:
http://kb.sandisk.com/app/answers/detail/a_id/61
Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware
NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode.
If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
for more answers at:
http://www.doremisoft.net/Sansa-Video-Converter-Mac/
or http://kb.sandisk.com/app/answers/list/
Mar 03, 2010 | SanDisk Sansa e250 MP3 Player
Computer does not recagnize MP3 player when connected
4. Power issue.
- Run the hotfix.
if u want more help u can go with these site:
http://www.doremisoft.net/Sansa-articles/Convert-video-to-Sansa-on-mac-osx/
wish above can help u solve your problems.
Jan 06, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
Mp3 not recognized by the computer
try re installing the cd program of ur mp3 or if you dont have any... try this. (for windows computer only)
1- plug your mp3 in the computer using your usb.
2- go to my computer.... in the left task pane. click view systems information.
3-the system properties dialogue box will appear.
4-click the hardware tab then click the device manager.
5-the device manager tab will appear.
6- click the portable devices then you will see the name of your device.
7-click the name of your device .
8- you will see in the general tab in the dialogue box that will appear 'device usage'
9- enable it.
thats all..
Jun 07, 2009 | SanDisk Sansa E280 MP3 Player
Sansa e280 will only charge when connected to my computer
Get the Vista compatible software from Sandisk's website
Sep 07, 2008 | SanDisk Sansa e200 MP3 Player
USB Connection
try to contact any of your local electronic shop like best buy or staples, you can also order one at sandik.com or at macally.com for accessories.
Dec 12, 2007 | SanDisk Sansa E280 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
