Question about RCA Lyra RD2850 20 GB MP3 Player
Doesn't turn on correctly
When I turn it on it says " Failed to load files! Reset unit to resume operation.
Update LyraHD system files if problem persitsts.
What should I do about this
  • 76 Answers
You should reset it immediatly. you should see in an instruction maual how to do so.
Posted on Dec 27, 2008
Garmin 1340T boot loop issue. The unit
Unfortunately, there isn't an easy solution for the Nuvi owner as it requires a custom piece of firmware to flash the unit to make it at least boot. This problem is often caused during a failed firmware and/or map update.
It sounds like a file was corrupted. Sometimes it is better to connect the unit up to a PC, delete the old map and then proceed to install the new one. There are so many issues with memory space causing failed downloads and corrupted files.
If the map file is missing, the unit will boot-up OK, it will just say "Map data unavailable" but if the map file or associated map files are corrupted, it can cause the unit to crash. Your PC won't recognize the Nuvi because you have the reach the main screen before the data communication mode routines are accessed.
We've had some success in restoring some of these units by flashing a "fix" firmware in "pre-boot mode" that doesn't try to load the map or map associated files. This should then allow the unit to boot. Once the unit boots, Windows will recognize it and then you can copy a map over to it from the PC. Reboot the unit and then flash it with the standard firmware.
- Jim
Feb 23, 2012 | GPS
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here http://www.sansa.com/support/sansa_e200/faqs says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
  1. Windows XP, Vista
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  1. Turn off the player.
  2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
  3. Press and hold the REC button and connect the device to the computer.
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
  5. Release the REC button.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
The problem is...
DId u figure out how to solve it ?
Nov 07, 2007 | RCA Lyra RD2854 40 GB MP3 Player
Failed to load system files...How can I reset?
To reset you need to have MP3 switched on, THEN hold the off switch for 10 seconds.If this fails to reset.You may have some corrupted music files sitting on the harddrive.email strongjonn@aol.com if you still have problems as i had the same issue and found a workaround.
Apr 22, 2007 | Thomson Lyra PDP2842U MP3 Player
RCA RD2820
you are going to need the Drivers for it I had the same problem then I got the Drivers and it works great just go to http://support.rcaaudiovideo.com/downloads.aspx?product=104 and download the two drivers and you should not have any problems
Jul 20, 2006 | RCA Lyra RD2820 20 GB MP3 Player
Failed to Load Files
I was able to access the play list using Windows Media Player. I was trying to get the computer to recognize the player, and it wouldn't do it. I even downloaded the Lyra Personal Audio Player updater... that didn't work or recognize the player.
Try the programs that are on your computer for playing MP3's.
Jun 12, 2006 | RCA Lyra RD2854 40 GB MP3 Player
Cannot turn on
You can reset your Lyra player at any time by depressing and continually holding the power button for a minimum of 10 seconds. Upon releasing of the power button, the unit should reset. If it does not, we recommend that you try again by depressing and holding the power button for up to 20 seconds. Constant pressure is required to depress the button for this duration. Second, download the latest firmware for your player. As for the unit freezing I figured out that it has to do with WMA files. try to re-coded your WMA's to MP3. I think it just has to do with the firmware not liking WMA very much. Use MP3 format only and I think you will be fine.
Jan 13, 2006 | RCA RD2826 MP3 Player
Error message "Not Enough Memory".
The update process failed because the updated GWES.EXE file is in use by the operating system. To correct the situation: 1. Double Tap "OK" to clear the error message. 2. Double Tap "OK" to complete the update process. 3. Double Tap "My Computer". 4. Double Tap "Program File" folder. 5. Single Tap "GWES" ICON while holding down the "ALT" key. 6. Single Tap "Delete". 7. Single Tap "Yes". 8. Perform a "Soft" reset.
Sep 15, 2005 | NEC MobilePro 800
Tried to install the update file MP77_UPDATE.CAB twice and got the error message "Not Enough Memory"
Sep 15, 2005 | NEC MobilePro 770
RCA Lyra RD2850 20 GB MP3 Player Logo
106 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
