I HAVE PROBLEM WITH MY SOUND
I CAN'T HEAR THE SOUND
  • Thomas F. Schneider May 11, 2010
    Have you never heard sound? Does it have on board speakers or external? Have you reinstalled installed the sound card software and drivers?
  • 76 Answers
It is probably your speakers. check the wire inputs. make sure all are plugged in. turn the sound up on both your speakers and on you computer. this should show up on your desktop. did you try restarting your computer? you might have a small virus. make sure your computer isnt muted.
Posted on Dec 27, 2008
How can i fix my audio suon
Method 1: Restart the computer Restart the computer at least one time after you install a Windows Vista service pack to verify that all processes related to the installation are complete.
After you restart the computer, determine whether you can hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 2. uparrow.gifBack to the top Method 2: Try another sound deviceIf it is possible, try plugging a different sound device into the computer. For example, if you were using speakers, try a different pair of speakers or a set of headphones to make sure that the problem is not related to the sound device.
Determine whether you can hear sound. If you can hear sound, there is a problem with the original sound device and the issue is resolved. If you cannot hear sound, plug the original sound device back into the computer, and then go to Method 3. uparrow.gifBack to the top Method 3: Unplug the computer speakersUnplug the computer speakers or other sound devices that you may be using, such as headphones, from the computer and then plug them back in to the same port. Most sound cards that are compatible with Windows Vista include a feature that detects sound devices plugged into the audio jack. This procedure may prompt the audio detection feature to detect and configure the sound device to make sound.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 4. uparrow.gifBack to the top Method 4: Verify that the default sound device is set correctlyAfter you install a Windows Vista service pack, you may find that the default sound device, also known as the playback device, was changed. You may also find that the sound quality has changed. Make sure that the default sound device is set correctly for the sound device that you are using. To set the default device, follow these steps:
  1. Click Start vistastartbutton.jpg, type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device. For most users, the default device is Speakers. Make sure that your audio settings are configured as expected. Follow these steps:
    1. On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect. When you finish, close this window to return to the previous window.
    2. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
    If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
  4. Select the sound device that you want as the default sound device, and then click Set Default.
  5. Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5. uparrow.gifBack to the top Method 5: Verify that a sound driver is installedWithout a sound driver, you will not hear sound. Make sure that a sound driver is installed. To do this, follow these steps:
  1. Click Start vistastartbutton.jpg, type Device Manager in the Start Search box, and then press ENTER.
  2. In the Device Manager dialog box, expand Sound, video, and game controllers.
    If there is a speaker icon next to the sound driver, the driver is installed. If there is a yellow question mark next to the sound driver, the driver is not present or will not load.
Go to method 6 to reload the current sound driver and test for sound. uparrow.gifBack to the top Method 6: Reload the current sound driver If you discovered in method 5 that the sound driver was not installed, or if you discovered that the sound driver was installed but is not working, try to reload the sound driver. To do this, follow these steps:
  3. Locate the audio device that was included with the computer.
  4. Right-click the device, and then click Properties.
  5. Click the Driver tab, and then click Uninstall.
  6. Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
  7. In the Device Manager dialog box, click the Action menu, and then click Scan for hardware changes.
    You receive a message that states that a hardware device is being installed, and then the uninstalled audio device appears in Device Manager.
  8. Close the Device Manager dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If the current sound driver did not reload or if it did reload, but you cannot hear sound, try method 7. uparrow.gifBack to the top Method 7: Update the current sound driver If the current sound driver does not seem to be working, see whether there is an updated sound driver that you can install. To request an updated sound driver, contact the manufacturer of the sound driver.
For information about how to contact hardware and software vendors, visit the following Microsoft Web site: http://support.microsoft.com/gp/vendors/en-usNote In some cases, the manufacturer may instruct you to uninstall the current sound driver and to delete the driver files. To do this, follow the steps in method 5, but at step 6, click to select the Delete the Driver Software for this device check box.
Dec 12, 2010 | Toshiba Satellite M35X-S114 Notebook
My mobile is nokia 3110classic.suddenly i got a sound problem.i cn't hear sounds outside.but am ble hear them through ear phones.i.e am unable hear songs as wells am not able to hear my ring tone...
The problem is with your "Ringer" (the bigger speaker). If you can hear the sound through your ear piece, then replacing the Ringer/Speaker will definitely fix your problem. I would suggest to get it done from a service center or from a mobile repairing shop.
Good luck.
Thanks for using FixYa.
Jun 25, 2010 | Nokia 3110 Cellular Phone
I don"t hear any sound from my speaker i connected to my pc all my setting are correct
hi
I read your problem.
your problem is that you don't hear any sound from your speaker when you connect to your pc and you also say your setting are correct.
but again you check your setting in my way
  1. Go to control panel
  2. than go in your sound option
  3. than check your speaker wire pin is connected properly if not than connect it properly
  4. is your computer show your speaker are connected properly
  5. than there is a option to test or check your speaker means it when you click your left speaker create sound than right
  6. if you hear sound means it is correct or your hear only one side than check your volume option
  7. if you don't hear any sound it means your speaker is dead.And also connect nearby computer shop.
Apr 02, 2010 | Computers & Internet
Centre speaker no sound. I can hear the surrounding sounds but no dialogs! checked connections and speakers: everything seems ok. Reset to factory settings, still same prob. I think the centre channelk is...
Well, maybe the center speaker is burned.Can you hear any sound from the middle speaker !?
If you can't hear anything from it, replace the speaker with the new ones.
If you can hear a minor sound or scratch, then the sound board inside the tv set is damaged.
Dec 09, 2009 | Televison & Video
No hear the sound in ACER 4520
First you just play the songs in VLC player.If sounds comes then ok,otherwise cheack below that i have written......
I think either the (XP)sound drivers doesn't match or the problem in your sound device. So it's better to go to the nearest service station and cheak your laptop. If it is OK then, search for proper sound drivers from them or in google.
Mar 14, 2009 | Acer Aspire 4520-5582 Notebook
Cant hear sound on mp3 player
Are you sure your headphones are good? Test them on a different sound source,
Nov 05, 2008 | Edirol UA-4FX External Sound System
I can't hear the recorded video!
At first, when you were not able to hear sound in playback on Camera LCD view, it was problem of Built-in Speaker defect. Now you can't hear sound on TV as well, it means Sound Processor IC is defective. You need to contact Sony Service Center for proper repair.
Aug 17, 2008 | Sony Handycam DCR-TRV25 Mini DV Digital...
IBM T-20 THINKPAD LIQUID WS=AS SPILLED ON KEYBOARD CONNECTED EXTERNAL KEYBOARD BUT I CANT HEAR ANY SOUND NOE
ok
u r lose your laptop sound drivr reinstall your laptop sound driver
i hope ur problem will solve
Mar 07, 2008 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
35 people viewed this question
Alun Cox
David Payne
David Payne
