Question about Canon Speedlite 540EZ TTL Flash
Canon Speedlite 580 EX II
Using the 580 as a master and the 430 EX as the slave, I cannot get the units to sync at the same time.  there is a delay with the slave.  any suggestions?
  • Anonymous Jan 04, 2009
    same !!!
Is your master flash set on a camera? The EX II has something that makes it have a 1 second delay when using sync mode, unless the master flash is set on the camera.
Posted on Jun 02, 2009
The flash ratio between a master unit mounted on my Canon 5D Mark II and slave doesn't work properly. A couple of shots are fine but then all of sudden the slave unit fires ar full power, then a few week...
If you had the ATG Gold MG8k Flash Kim X3, then your 430EX II or 580EX II can transforms into wireless radio ATG ETTL II.
If you are using the outdated wireless IR ETTL with a 580EX II as a Master. Then you have to set the Slave (ATG/580EX II/430EX II) body facing close to the Master.
atdlee@netzero.com
May 20, 2014 | Canon Speedlite 580EX II TTL Flash
Can i use a Canon Speedlite 580 EX II for a canon 550D?
Yes. The 580EX II will work with any Canon digital SLR.
Nov 12, 2012 | Canon Speedlite 540EZ TTL Flash
Canon Speedlite 580 EX (mark 1) 6 years of continuous use - single flash, multiple flash & continuous burst - with rechargeable batteries. All is well, until recently. Now recharge time has quickly...
The capacitor (neck) is no longer hold a charge or charging circuit is going out on a extended breaks.
Save your money and buy ATG's Godox TT685c.
If you buys two, then you got ATG wireless radio ETTL II flashes.
It would cost over $1,000.00+ USD to buy two Canon 600EX II-RT just to do the same with two ATG's.
Apr 25, 2017 | Canon SPEEDLITE 580EX TTL Flash
My xti fell with the 430 ex II attached now it
The hot shoe was bent slightly causing the flash contacts to not touch those of the camera. By using a socket from a socket wrench set, place it over the grids of the hot shoe and tap firmly with a hammer to straighten it.
Jan 02, 2010 | Canon Speedlite 430EX TTL Flash
Iam having a problem getting the two flash units to sink. I have set the parameters by the book for the master and the second the slave. They are both on the same channel. They are both on the ETTL mode....
Make sure the slave is far enough in fornt of the master flash to see it. If the two flashes are next to each other then the slave is not seeing the master signals.
Oct 16, 2009 | Canon Speedlite 580EX II TTL Flash
I have a Canon Speedlite 580EX, the flash will not go off.
Perhaps the unit is set to master/slave mode. Look into that.
hint: Press and hold on the zoom button to get into the master/slave menu
Dec 04, 2008 | Canon Speedlite 580EX II TTL Flash
Amperege of 580 EX-II
Interesting Question!
The rating in milliamps is a matter of battery capacity and charging rates. The higher the better as you will get more flashes per charge as long as you have the correct charger to match the batteries’ capacity and use the correct charging times. Aside from this issue of duty cycle between charges- this has no effect on the power of the flash unit as to output. This cant burn out or damage the circuitry.
The issue here is VOLTAGE. Most AA alkaline batteries provide 1.5 volts. Most rechargeable AAs provide 1.2 volts. We are looking at a voltage differential of 1.2 volts (a 20% deficit) if 4 batteries are required. This MAY cause slower recycling times in order to attain a full charge for each shot. In SOME units that can cause a bit if overheating due to strain on the step up circuitry.
It so best to check with the manufacture or distributor of you flash unit before purchasing you rechargeable batteries and charger. If you units have a built in charging circuit this can definitely be problems if there is a mismatch in charging rates and voltage. If this is the case be sire to check your manual or with the manufacturer or distributor- there must be a list of compatible batteries.
Ed
Jul 08, 2008 | Canon SPEEDLITE 580EX TTL Flash
Canon speed lite 580ex 11
I just got the 580 and had trouble with it blinking all the time, the bounce card was out about a mm and I did not realize it, once that was pushed all the way back--voila.
Jun 30, 2008 | Canon SPEEDLITE 580EX TTL Flash
Off camera flash
Here's how I did it with my Canon 430 EX II. The only other Canon flash that can act as a wireless trigger for off camera flash would be the 580 EX II and that is why I love it so much.
The only other way is Pocket Wizards or the Canon wireless thingy, which noone recommends....
Check out the NEW Pocket Wizard Mini TTi it truly does amazing things! And only 199.00!
God luck and let us know how it goes.
Nov 21, 2007 | Canon Cameras
if u set the 580ex on master and the 430 EX on slave it works :) u dont need STE2 for this simple task.
Oct 18, 2007 | Canon SPEEDLITE 580EX TTL Flash
Open Questions:
Canon Speedlite 540EZ TTL Flash Logo
525 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
