FixYa.com
Tags:
SanDisk Sansa e260  MP3 Player
It wont turn on (by 2 users)
posted by chave on Apr 20, 2007
Hi my sansa e260 isnt working. When I turn it on it shows the sandisk thing but then it just says load main image failed switch to recovery mode. how do i switch to recovery mode? what can i do to fix it?
Comment by chave, posted on Apr 22, 2007
thanks it really workred!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by eMoNM, posted on Jun 03, 2008
when i tried what u said, a window came up as," No valid device appears to be connected. Please connect a valid device. WARNING: Please connect your e200 series MP3 player in MSC mode. To go to "MSC" mode, in your device, go to "settings"> "USB Mode"> "MSC". i can't get to my settings to do that so what do i do next?!
Best Solution
posted on Apr 20, 2007
FixYa! (100)
Syd_
Rank:Wiz Wiz
Rating: 92%, 433 votes
I would like to offer this solution, but this solution is only meant for the "Standard" E200 players (there are 2 types of E200 players -- the Standard E200 and the "Rhapsody" players, indicated with an "r" after the E200 such as "E260r". I'm hoping you have the standard E260.
Switch your Sansa E260 to its Recovery Mode:
1. Make sure the player is powered off
2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface
3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button.
4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode"
5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above)
6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6.
Next, Apply the firmware for the E260 (your player should be connected to your PC at this time):
Step 1:
Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop":
http://www.sandisk.com/Assets/File/Downl...
Step 2:
Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the "Load Main Image Failed" notification in the first place.
Step 3:
When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch
Step 4:
Power up your E260 and 90-99% of the time, it would boot up successfully.
Step 5:
Enjoy using your Sansa E260, just like I do. (I love this player)
Comment by Syd_, posted on Apr 23, 2007
If your player displays a "Low Battery", then go ahead and re-charge it first on your computer's USB port before performing the steps I outlined earlier.
For best results, charge the player for 2-3 hours (this is the time it takes to fully charge the player after the battery has drained out)
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 26, 2007
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Solution #3 tahnk u so very much it worked like magic!!!!!!!
Solution #3
FixYa! (100)
Guest
Guest
Rating: 0%, 0 votes
My Sansa e260 was restarting (rebooting) repeatedly. I followed the instructions above and it worked like a charm. Thanks.
Solution #4
posted on Jul 25, 2008
Not Rated (0)
sansae260sux
Rating: 0%, 0 votes
HEY SYD
THX I OWE U 1
Solution #5
posted on Nov 15, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
THANX!!!! I own you ;)
Solution #6
posted on May 30, 2007
Not Rated (0)
Boostyasir
Rating: 0%, 0 votes
i had this problem, when i tried to add music to my player it showed that was an error in the file or something, then when i was trying to erase something it showed " device is disconnected" so this worked for me =] thanks syd! by the way youre so preety =] and i would like to know why this problem happens?
Can you Help with these MP3 and Digital Media Players problems?
SanDisk Sansa e260 (4 GB) MP3 Player
'Hold' button problem
With my hold switch toggled to... Answer This...
Synching AVI files
I tried to synch and avi file... Answer This...
radcon10@yahoo.com
The wheel started to stick so i... Answer This...
sansa mp3 e260
new to the mp3 technology-... Answer This...
sansa e260
I need a replacement case for... Answer This...
Repair Service
Find MP3 and Dig. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
