Can't reboot Compaq/Presario desktop, (power supply is working)
The fan is working, screen stop at Compaq . I tried both, the screen says loading boot menu... and stop right there.
Tried System Recovery DVD, it doesn't work.
Can you help? Thanks in advance...
Spec:
Compaq/Presario SR1220NX
80G 7200 RPM Ultra DMA hard drive
340 intel celeron D processor
512 MB DDR SDRAM
  • L711 Jan 30, 2009
    I HAVE SAME PRIBLEM IM TRYING TO REBOOT MY COMPUTER IS A COMPAQ PRESARIO V2000. IT IS STUCK ON BLUE SCREEN F1 TO RESUME F2 TO SET UP. I TRYED DISCONECTING POWER CORD. TURNING ON AND F2 WONT DO ANYTHING.
  • sylhetboy Apr 26, 2009
    i can't reboot the computer
    Habit-Forming:
  • 51 Answers
First can you try to disconnect power and IDE cable cd-rom,cd-rw,dvd-rw and floopy disk then see can boot up no stop in the screen says loading boot menu... and stop right there.make sure HDD is conected
second try disconect you HDD only other can connected to see can boot up no stop in the screen says loading boot menu... and stop right there
if solution one is ok means you dvd go problem.if second solution ok meand you HDD faulty.can you try put you RAM in diferrent slot
Posted on Dec 27, 2008
    President:
  • 2,692 Answers
If the system recovery disk doesn't work it usually mans that the hard drive is bad. I would change the hard drive and use the system recovery disk on it after replacement.
  • DaemonKrog Feb 28, 2011
    I've noticed that the heat sink for the north side bus could also come loose or off completely. It's held on by a small loop that's soldered in. Check that if none of the other solutions work for you. If this is the problem and one of those clips has come off, you should be able to find a thermal paste that also works as a glue. That should fix the problem.
Will not boot up after hard power down / reboot bsod unmountable boot volume stop error screen STOP 0X000000ED do not have SR1030NX compaq pc RECOVERY CDs thinking of ordering fm hp /...
From the sounds of it you may have to just reinstall windows. If you do not have the recovery disk you can purchase them from HP for 5.oo USD.
Dec 27, 2010 | HP Compaq Presario SR2030NX PC Desktop
The compaq will not boot up
try loading your OS cd but it will wipe out all the files on your drive. if this wont still work, then it might be prob with the hard drive itself. replace hard drive.
Mar 31, 2010 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Presario sr1130nx desktop, lost power, won't start up now
there is problem with u'r SMPS. repare it or change a new one
Nov 03, 2009 | HP Remanufactured Compaq Presario SR1130NX...
Compaq presario sr215onx wont boot up
Go to bootdisk.com and download boot files for your operating system (ex. Windows XP). There are software for floppy disk which is the easier way to get your boot files. If you do not have a floopy you will have to get the CD files, there you have all the instructions how to get the CD. Once you get the files, insert the floopy or the CD and reboot your computer. The filse should be installed automatically, if not do it manually and reboot computer again.
Oct 29, 2009 | HP Compaq Presario SR2150NX PC Desktop
Compaq presario 5000 desktop won't boot!
oh that means you have a power failure so you have to take it for a repair
Sep 24, 2009 | Compaq Presario 5000 PC Desktop
HP Compaq Presario SR1820NX will not turn on
i worked for hp and compaq it is well known issue to reslove this issue
1#turn off the computer and uplug the power cable from the computer and then hold the power button for 20 second then turn on the computer and the momment you back to desktop screen
go to download driver from hp site and here is the web site http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-43507-1&lc=en&dlc=en&cc=ca&lang=en&os=228&product=1841849 and restart the computer .
Apr 15, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
Computer won't boot up
Check the heat sink connected on your processor and its cooling fan is working or not
Apr 09, 2009 | HP COMPAQ Presario SR5410F Pentium...
Wont start up
my wife has a presario that had a similar problem - it would boot up, then immediately shut down. I took off the side plate and blew off some of the dust inside. that worked for a couple of days then the symptoms returned. I took it apart again but this time I removed the cpu fan and the cpu heat sink. I cleaned all the **** off the fan and the heat sink and replaced it. this time it stayed on. I checked out the power supply. compaq installed a very cheap power supply - only 250 watts. a replacement power supply for the same machine but with an output of 300 watts is available. as soon as I can scrape up the change, I'm gonna change the PS
Jun 11, 2008 | Compaq Presario 5000 PC Desktop
Presario 6350CA won't boot
I don't know that I'm going to be a great deal of help, but here is the link to the support site for you Presario:
http://h10025.www1.hp.com/ewfrf/wc/product?product=390426&lc=en&cc=us&dlc=en&lang=en&cc=us
Here's a link to another page on the Compaq site that specifically talks about power supply problems:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&dlc=en&product=390426&lang=en#N514
They discuss a flashing power led on this site, but I believe they are referring to an led on the power supply itself. Perhaps the led on the keyboard and the led on the power supply are both flashing...
Good luck. I hope this helps.
Dec 22, 2007 | Compaq Presario S6300NX PC Desktop
Computers & Internet Logo
431 people viewed this question
Alun Cox
David Payne
David Payne
