Question about Pyle Dryver PLAD213 Car Audio Amplifier
Amp problem help
I have a vibe mono box 4 i was drivin down the road the other day and my amp switched off i turned the ignition off and it came on but it was making a pulsing noice ive tried it in my mates car and it does the same please help me!
    Novelist:
    Champion:
  • 219 Answers
Sounds like a fried output MOSFET is very possible.
Posted on Apr 23, 2007
Your problem is in instalation of car moust driver your service car end fixed the problem of conection
Posted on Apr 22, 2007
SOURCE:
No power to diagnostic port or fuel or ignition or starter pulse 03 vibe any ideas
All these have different fuses, except a main fuse that supplies power to the different fuses. Check those first. Check power from the battery to the fuse panel. Could be a bad fuse panel. If you check voltage with a volt meter, does it show any voltage at the fuses? If 0, then look to the wires first. If they show varying voltage(like2,3,4.5,or 6) suspect the fuse panel. The voltage should be 0 or battery voltage.
Dec 18, 2016 | 2003 Pontiac Vibe
I have a 2003 roadstar.I have no power at all. I had battery checked and they said was good. Any suggestion? What amps should I be pushing out from battery?
Hi, Phillip #10 is jumping up and down waving a "PICK ME" sign otherwise the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Re No electrical power Road Star Forum Yamaha Road Star
http://www.starbikeforums.com/forums/14-royal-star/23673-no-electrical-power-when-key-turned.html
Yamaha XV17ATMV Road Star Owner Manual
OEM parts for Yamaha
Yamaha XV1700PCRC Service Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 06, 2016 | Yamaha Royal Star XVZ 1300 A Motorcycles
1996 Camry was running fine yesterday.This morning it wont start.
1996 Toyota Camry WONT START PLEASE HElp!!! - YouTube
? 3:18
https://www.youtube.com/watch?v=kgChwyign1M
Jan 2, 2013 - Uploaded by Jabali Black
My car problem started 3 days ago, it started with my Toyota security light blinking red, then a key like symbol on ...
96 Camry won't start / drivin me crazy - Toyota Nation Forum ...
www.toyotanation.com/...1996.../273708-96-camry-won-t-start-drivin-...
Nov 10, 2008 - 15 posts - ‎4 authors
I took my 96 4cyl Camry to the shop due to working nightshift for now and ... (1992-1996 & 1997-2001) > 96 Camry won't start / drivin me crazy ... camry wont start or crank on one click sound
Mar 5, 2011
94 Camry Won't Start after Timing Belt Replacement
Nov 20, 2010
93' Camry 4 cylinder, Cranks but won't start up
Sep 15, 2007
1992 Camry 2.2 Turns over Won't start
Feb 27, 2004
More results from www.toyotanation.com
Jan 15, 2016 | Cars & Trucks
Not starting? I have a 98 Kawasaki Ninja ZX 9r the headlight went out the other night still road in a couple more times started right up next morning nothing no neutral light just the tail light what
30 amp fuse is ignition ,incorperating the starter motos as well ,so its the other box ,also clean all conections some times these corode ,spray with wd40 or simular .
Apr 03, 2017 | Motorcycles
2002 Honda VT 750 C2 Shadow no lights come on when the ignition switch is turned on
Hi, Gary if some or all of your instrument cluster goes dark/blank immediately upon startup or a few minutes later riding down the road the usual suspects are:
1. Blown instrument fuse.
2. A bad ground in the instrument circuit.
3. Faulty wiring before or after the fuse.
4. Faulty wiring or connector between the fuse and the instrument cluster.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
VT 750 has no electrical power
Honda shadow fuse box
Honda 1998 VT750C Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
Nov 10, 2011 | 2002 Honda VT 750 C2 Shadow
On my 2005 Pontiac Vibe the heater fan does not work all the time
If it works some times then it is probably the switch.
Jan 25, 2010 | 2005 Pontiac Vibe
04 Pontiac Vibe bad gas mileage without a code and then the p0420
that code is from having the plugs wires reversed as you did and the o2 senors regrsitered the overload on gas emmions once you remove the battery cables for about 5 minutes and then recconect and run the engine it should be okay
Jan 19, 2010 | 2004 Pontiac Vibe
Amp goes into protect when turned up.
that amp is only stable 2 about 4 omhs mono the powersupply shut dowm drawing t much current it supposed 2 2 fix this u need a 4omh load mono change speaker config so u get 4 omh or buy amp stable down 2 1omh can be expensive
Aug 28, 2009 | Sony XM-2002GTR Car Audio Amplifier
Knocking noise with my kicker compvr 15"
comp VR 15s are rated @ 500W RMS 1000Peak.
The lanzar vibe amplifier is 2 x 600W RMS at 4 OHMS 2 x 1200W MAX at 4 OHMS 1 x 2400W MAX at 4 OHMS Bridged 2 x 1000W at 2 OHMS RMS.
Your subs are single 4 ohm subs.
If your subs are wired stereo, they both are seeing 600W. (more than the rated RMS)
Chances are, you have them wired parallel to a 2 ohm mono load - of which that amplifier is not rated. In theory, it will produce about 2000W @ 2 ohm mono for a short period of time.
Your amplifier is too powerful for your subs. Turn down the gain setting to 3/4 or purchase better subs. Also be sur the subs are inthe proper enclosure. It sounds as if they are excurting past their linear x-max and colliding with the rear bump plate. This will cause damage down the road if left as is.
Nov 26, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
Lanzar Vibe 1200D protection light
You will need to show it to a service technician as it seems the output section has blown so it remains in protect mode. One reason (could be) that the input to the amp was high and may have been clipping for some time before the amp decided it could take it no more
Jan 14, 2008 | Lanzar Vibe 1200D Car Audio Amplifier
Pyle Dryver PLAD213 Car Audio Amplifier Logo
63 people viewed this question
Top Pyle Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
