Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Wont come on green light comes on three times
Green power light comes on three times each time i hear a winney noise after three times it wont come back on for one min. i have changed the flyback transformer, cp150, cp114. still doing the same thing. please help
  • RCA Master
  • 5,138 Answers
Check hori output Transistor if it is shorted set will not come on Part # NTE2324 if it is ok CK second ribbon connector on the deflection board going to board on right. make sure it is in good if it isnt set will make noise and not come on,
Posted on Dec 27, 2008
Samsung hlp6163w dlp tv not working, new lamp, new ballast, still three blinking lights
If color wheel does not run lamp will not fire----with lamp removed have you looked at the wheel----if not running it will cause almost instant shutdown of lamp and the set.
If the DMD board is bad time for a new set as it is well over 500 .
Mar 28, 2012 | Samsung HLP6163W 61" Rear Projection...
My 1995 rca model p5275at wount come on i push the on button and hear some buss like noise it does it three times and doesnt come on
This is a pretty old set-----if possible listen when you try to turn on---a brief moment of hissing or a frying sound may mean the High voltage splitter in the set has failed.
Mar 12, 2012 | Televison & Video
Hi, our samsung sp43h3ht tv has been switching itself off and red light flashing, you hear a ping noise and it wont switch back on, left and switched back on after ( cooling ) did this about 5 times over a...
first of all replace all the three crt base socket of ur tv's three crt guns. also check the line output transformer (LOT). my be its insulation have some problem that's why you hear a noise. noise of the high voltage leakage . if so u have to replace the LOT.
Jan 06, 2011 | Samsung SP55W3HF 55" Television
Rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Won't power on
my d52w19 chassis itc222 as posted most of the time wont turn on and the green light flashes three times every time it makes a small noise. sometimes it does turn on and you hear a little pop and the tv fires up.  latley there is a really high pitch noise that will slightly change pitch if you move the tv or put slight pressure on the top or botttom rear part of the chassis. thanks for the help as I have seen that this has been posted before without mention of the high pitch noise.
Aug 23, 2008 | RCA D52W19 52" Rear Projection Television
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Tv wont come on
Check the horizontal output and regulator transistors. If you ould like the service manual let me know I can post a link where you can purchase it and have it emailedto you along with free help to elp you diagnose and repair your set.
Feb 19, 2008 | Mitsubishi VS-50605 50" Rear Projection...
NO picture no sound
blinks three times?, do you hear any clicking?
Dec 05, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
You most likely got water in the high voltage circuits which caused an arc somewhere and burned the circuit board which caused a short. Stargazer
Aug 20, 2007 | Philips Magnavox 27MS343S 27" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
