Question about Belkin N1 Wireless USB 2.0 Network Adapter (S6359026)
I have a belkin g router pn 78022072--model f5d7230-4v9 installed. I installed it once before and it worked for one night, then quit working. I disconnected it and connected it again. While it says it is connected and ready for use, it still won't connect to the internet. I have unplugged it and plugged it back up, and nothing happens. I also unplugged the power to the modem, and once again, nothing happened. I don't know if I have a bad router or not. It seems others have the same problem. I would appreciate your help. I am considering getting a different type, but I don't want to unless it is absolutely necessary.
  • 258 Answers
Try setting a static IP address solution and instructions are here:
http://www.howtofixanything.co.uk/howto-282.html
Posted on Feb 21, 2009
Hello, I do not know much about troubleshooting internet connections. I just rely on Microsoft's "Diagnose Problem" option and most often than not, it works. But when I replaced our old...
Thank you for using fixya.
Being that your other computers in the network are working properly, you should switch the ip settings on your comnputer to automatically detect. That way your computer does all the routing and ip setting,
After you have set that back. Remove the power of your router, remove the power of your modem, and restart your computer.
Once your computer is back up, turn on modem, then the router.
It sounds very simple, but in most cases, it solves the problem.
Hope this information is helpful
Jul 18, 2011 | Belkin Basic Wireless Router
Something happened to where my computer unistalled my belkin router, and ive lost the cd to reinstall. is there anyway i can instal it without the disk?
Go to www.belkin.com/support
Select your product model
You can find the latest firmware and software for the Unit
Belkin router works without the software also
Dec 11, 2010 | Belkin Basic Wireless Router
Belkin wireless g router working perfect last night today will only work if patched direct to router why has it stopped working wireless saying limited or no conectivity
Hi Ok lets resolve your problem
the problem you have with your connection is wireless issues:
  1. go to setup page Belkin 192.168.2.1 in browser Explorer
  2. change your security mode to 64bit WEP
  3. if your security mode is allready 64bit WEP change again your SSID and passwird
Ok that is the solution for this problem.
Any questions etme know.
please rate me techbelkin.
Oct 29, 2010 | Belkin (F5D7230-4) Router (587009)
I configured the belkin router Belkin wireless-n
if the router is still under warranty or you have an existing ISP,you can try to contact them since they are the only one who knows how to configure that,theres a possiblity that they will reset everything
Jun 28, 2010 | Computers & Internet
Installing belkin wireless router
1. First, Begin by resetting your modem, the reset button can be found on the back of the modem, underneath the power button.
2. Once the modem is reset, do this for your router, and when you are finished connect the cable from your Modem into the "internet" or "modem" port on the back of your router.
3. Now run a cable from port number 1 on your router, to the back of your originial computer. Give this a moment to sync.
4. Now open your web browser and type in 192.168.2.1 and hit enter, it should prompt you for a username and password, enter "admin" in the username, and leave the password blank. You will now see the router's status page.
5. Now configure the Router according to your ISP setting.
Jul 29, 2009 | Belkin (F5D7231-4) Wireless Router
Drops the internet connection and has to be rebooted at least once a day.
Try to reduce the MTU of the router. If you're on DSL, set the MTU size to 1492, for Cable connection size is 1400 or 1463. You can do it on the router's admin page http://192.168.1.1
May 11, 2009 | Belkin (F5D7230-4) Router (587009)
G model F5D7230-4 plays music in middle of night! What's up?
Hi Iam wireless router technician
To fix this issue all you have to do is, Make sure that noise is coming from the router first..(If "yes")..Reset the router and re- configure it, Still if you hear the noise..
Confirm the model number( starts with F5D) & version (starts with VER) of your router and cal belkin technical support (toll free number) Explain them the same and you will get free replacement.
Hope this Information helpful for you all
Apr 09, 2009 | Belkin (F5D7230-4) Router (587009)
Belkin wireless G router-2.4Ghz-802.11g ,i,m not getting the internet conection via router .pls help or give me tel no to contact u..i've been using the router for more than a year now and there was no...
Go to the Belkin support section at their website: http://www.belkin.com/support/
Look for your model router and download the "firmware" upgrade for it. Once you go install the up to date firmware try to give the router a reset. Hopefully doing all that will get the router working again and you connecting to the Internet.
Aug 16, 2008 | Belkin Computers & Internet
Router
check you cable connections, try to check if you can go online wired to the router if you are connecting wirelessly. You can also bypass the router and connect directly to the modem to make sure its working.
Jun 15, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin N1 Wireless USB 2.0 Network Adapter (S6359026) Logo
83 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
