Question about Sharp AL 1631 Copier
Sharp AL-1631 the copies have a black toner edge on the right side.
  • 62 Answers
Several things can cause this problem; The drum cartridge is not being cleaned properly or there is a problem with the toner cartridge . Take out the drum cartridge and inspect it for any signs of the defective image. If that doesnot solve the problem, then Call a tech.
Posted on Apr 26, 2007
A copy has toner all over the right side on the paper.
Are you mean that toner isnt baked enough? If yes then you have problem with fixing roller bushings.
But if the toner is like printed, change blade and drum.
If the toner is like spiled on copy, vacume and clean the machine
Jul 01, 2010 | Sharp AL 1631 Copier
A thick black line of toner accumulates on the right edge of the paper
This is most likely caused by the drum unit. This unit is located just to the right of your toner cartridge. Just remove the toner cartridge first. Now remove the drum unit. Turn it over and look at the blue/green colored cylinder which is the drum. It should be clean. If you see a band of toner on one edge of the drum then this is where your toner on the copy is coming from. You will need the drum unit rebuilt or replaced. While it is out also check the front side of your toner cartridge. Just visually inspect the toner "brush" that runs all along the front side and make sure there are no piles of toner on it. Do not touch the brush or turn the roller.
Good Luck and Thank You for using Fixya.
Jun 30, 2010 | Sharp AL 1631 Copier
I have a sharp copier AL 1631- it's making a noise
Hello sir; Bring back the toner cartridge to the store where you bought for exchange.
Feb 08, 2010 | Sharp AL 1631 Copier
Sharp AL 1631 ---- Getting blank copies
Hi, you can stop a copy half way to see if it image is on the on the drum if not check and make sure toner unit is turning. if not main charge. thanks dale.
Jan 22, 2009 | Sharp AL 1631 Copier
Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Nov 05, 2008 | Sharp AL 1631 Copier
Al 1631
Simple you get a PM, new developer.. call an authorized Sharp Tech...
Oct 21, 2008 | Sharp AL 1631 Copier
Won't copy anything now.
the "screen" is actually called a grid, it is supposed to be on a unnit called the "primary" which sits on top of the drum (long silver unit) it may have a screw holding it. It must have been serviced or someone touched it, does not come off by-itself, anyway, it distributes the charge of the primary to the drum.
So look for a unit that sits directly on top of the drum unit and is the same lenght as the drum
Hope this helps (please rate. TNX)
Oct 02, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
111 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
