Question about Sony Playstation 3 (PS3) Console
On my ps3 im tryna get online but it keeps sayin dns error
I typed all the correct info but it still wont work...any suggestions/ideas HELPPPP
This happened to me as well but u will have to disconect ur modem or whatever you are using for about 1 minute then connect it again try the connection again and it should work.
Posted on Dec 27, 2008
Can't get internet on ps3
Okay, i'll see if i know what we're talking about here. There are a couple of things you could try. For one, try logging into your router, (usually at 192.168.0.1 and looking in the Client or Address lists for a PS3, or whatever you have named it, and then see if you can either disconnect or renew it. Then, redo the whole WiFi setup on the PS3 setting all the settings as you would but leave the IP settings as they are (should be Auto). If that still doesn't work, go into the PS3's connection settings and manually set an IP address. My suggestion is to use the same address as an already connected (and working computer), but change the last number. Whatever you do, make sure there are not two of the same IP address on the router. Hope this helps...
Nov 08, 2009 | Sony Playstation 3 (PS3) Console
My ps3 keeps on sayin dns error
if your set to obtain setting automaticly try rebooting your router then go through the network setup again to refresh all the setting.
If you put in the ip address and dns setting in manually then double check the info that was given a good test is to use an alternative dns for dns #1 like 4.2.2.3 and see if that clears the error , if it does then the dns server that you were given is down or you were given the wrong info
Sep 23, 2009 | Sony Playstation 3 (PS3) Console
PLAYSTATION WONT SIGN IN KEEPS SAYIN DNS ERROR
You must change the wireless channel of your router and do a power cycle. Just turn off your router for 30 seconds then turn it back on.
Jun 09, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
DNS ERROR 80710102
have you tried opening some ports on your router for the ps3?
Jun 09, 2009 | Sony Playstation 3 (PS3) Console
PS3 says DNS error (80710102) when i try to connect to the internet with a wired connection
Goto the command prompt bar in the start menu type ' cmd ' then click o.k . A black dos screen will appear type in ' ipconfig/all ' and it will the the two servers you need under dns servers but if your doing a wired connection to your ps3 then you need to manually configure your dns on the custom method of setting up your internet connection on your ps3 as if this is auto config that will give you a dns error. Hope that helps ,I can go into more detail and guide you through it if need to .
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
DNS Problem On PS3
try setting up your network in auto.
go to internet connection setting an select easy, it should setup itself.
May 02, 2009 | Sony Playstation 3 (PS3) Console
Connecting to the internet.
Ask your ISP for the correct DNS address....sodeep
Mar 22, 2009 | Sony PlayStation® 3 (80GB) Console
Online
This is a common issue, do you have a thumb drive or aka flash usb drive? If you do use your computer to d/l the firmwareupdate
HERE then load the firware update from the thumb drive onto the ps3 via one of the usb ports on it, and hopefully this will fix your issue.
Sep 07, 2008 | Sony Playstation 3 (PS3) Console
Dns error 80710102
when it is a DNS error, this means that it is an internet problem on your internet service provider's end.
Apr 13, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
