Question about Philips SA920017 MP3 Player
When I plug my Philips SA3020/37 MP3 player into the port; it shuts down my computer
Why won't my mp3 player stay on?
Posted on Apr 27, 2009
I ran the battery on my MP3 player completely down and it shut off. I charged it and now all the songs are gone... is there a way to recover the lost songs?
Try this:
1)Perform a system reset, which won't erase your files, to attempt to correct playback. Locate a thin object, such as pen tip or unfolded paper clip and insert it into the small reset hole on the bottom of your GoGear. Hold the thin object in place until you see the unit shut down completely. Your system has been reset. Power the device back on to see if the corrupted files have been corrected. If the reset failed to correct the issue, perform a file recovery on your GoGear.
2)Initiate a file recovery by first connecting your GoGear to your computer. From your computer's "Start" menu, choose "Programs," "Philips Digital Audio Player," "Area Device Manager" and "Philips Device Manager." The Philips Device Manager software will be activated. Inspect your GoGear to confirm that it is turned off. Plug the small end of the supplied USB cord into the bottom of your GoGear while holding down the "Volume Up." Insert the larger end into a free USB port on your computer. Hold the key as the "Philips Device Manager" reads your GoGear and activates recovery mode. Click "Repair" and follow the onscreen prompts as given by the "Philips Device Manager" to complete the process of memory recovery. Disconnect your GoGear from your computer properly after the process is complete and restart your MP3 player.
3)Reload and replace the files onto your GoGear by first connecting your GoGear to your computer. Plug the supplied USB cord's small end into the bottom of your GoGear and the large end into your comptuer's USB port. Initiate Windows Media Player by clicking on its icon if it doesn't start upon connection with your GoGear. In the left pane of the WMP, click "Philips GoGear Aria." Click the arrow on the top left edge of the WMP window, followed by "Music." Highlight all files, and click "Delete." Click the "Sync" tab on WMP, and drag and drop the music files you would like to replace and reload into the "Sync List" panel. Click "Start Sync." The files will be freshly loaded onto your GoGear.
4)Properly disconnect your GoGear from your computer to avoid memory corruption by first closing all applications in use by the GoGear (WMP). Click the USB device icon in your system's tray (located on the bottom right corner of your screen). Follow the prompts in order to safely remove your GoGear from your computer. When your computer tells you it's safe to remove your GoGear, unplug the USB cord from your GoGear.
Hope this helps!
Apr 08, 2011 | Philips GoGear ViBE Digital Media Player
I connect my device(philips gogear Vibe 4g.)The device shows as "connected device"on "Media Converter for Philips" program , and when converting VIDEO files is "done" , report screen shows "NO DEVICE...
Hello :
1: Unplug your Mp3 player . 2: Restart system .
3: Plug the Mp3 player again . If the system didn't recognize Mp3 player this time , then :
1: Go to [ my computer ] icon on desktop .
2 : Mouse right click .
3 : Scroll down to properties .
4 : On properties click [ Hardware] .
5 : Click [ device manager ] .
6 : On device manager check if all [ USB ports ] are properly installed and working fine .
7: If there are [ question marks or wrong marks ] on the ports then they don't work properly .
This is what you need to do , if they don't work properly ;
1 : Right click on the none working ports .
2 : Scroll down to properties .
3 : On general click [ reinstall the previous program ] .
8f47b2d.png My computer icon .
Device manager
USB mass storage device problem [ not working properly ] . Here you should right click on the none working device then go to properties and then ,
f4d6255.jpg\
Troubleshoot .
I hope this will help .
rate please !
Mar 27, 2010 | Philips GoGear Flash MP3 Player
Mp3 won't charge or turn on and computer won't recognize it
the mp3 player might be going bad, might have to get a new one
Apr 22, 2009 | Philips GoGear HDD075/17 MP3 Player
Shutsoff, stays off problem...
Get the updated verison of the Philips Device Manager from Philips website, and then click on the Update button once you have installed the new Device Manager.
Several things to be wary of:
* a Philips player ending in "/02" is designed for use outside of the United States
* the SA5125 is incompatible with Windows Vista and Windows Media Player 11 without a firmware upgrade
Mar 04, 2009 | Philips GoGear SA3125/37 MP3 Player
Its keeps shutting down when i plug it into the usb
Here's your problem: there is no problem. Unless you can't access it from the computer like you do a normal thumb drive, this is normal. It doesn't let you listen to music while plugged into the computer. Sorry. It should work if you remove it from your computer correctly (Safely Remove).
Jan 28, 2009 | Philips GoGear SA3245/37 Digital Media...
Philips SA5125/37
First you should hold down the go back button on your mp3 while still holding this button, plug it into the usb port. While still holding the button open up the philip device manager, this should instantly start to repair your device. While it is repairing you can let go of the go back button
Oct 24, 2008 | Philips SA5125/37 MP3 Player
It hangs on the first screen!
when i plug it in to charge it just stays on the philips welcome screen and just stayz like that wen i reset it does the same thing
Sep 10, 2008 | Philips GoGear Flash MP3 Player
MP3 Shuts down when pluged in
try to turn it on before you charge it
Mar 22, 2008 | Audio Players & Recorders
Computer Freezes
Make sure you have installed Philips Device Manager from the product CD.
With the player powered off:
Press and hold VOL+ whilst connecting to the PC.
PC will show drive as Recovery Device (or similar) and device manager will start and show "Your device has an error...."
Click repair and follow the on-screen prompts.
When prompted, disconnect the player and power on.
Player will show "Loading" and then shut down.
Power on again.
Player will show "Updating" and then shut down again.
Player can now be powered up as normal.
Restart
Feb 24, 2008 | Philips GOGEAR SA6045 MP3 Player
Philips SA920017 MP3 Player Logo
48 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
