Question about Whirlpool GD5SHAX Side by Side Refrigerator
Whirlpool gold icemaker has no water going to it. no plug line
Water line works. no blockage.
  • 37 Answers
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Posted on Jan 03, 2009
Ice maker is not working
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 05, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The icemaker whirlpool gold model GRZSHWPBOZ
either the water valve is bad if so replace it or the tube that delivers the water to the tray is frozen . ck both and replace the one that is bad . hopt this helps mm ..
Apr 06, 2010 | Refrigerators
Icemaker will not refill
if the water is on its probably time to change the water valve on the unit. They go bad quite often. Hope this helps.
Jan 23, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker quit working
Could be a couple of things.
It's not getting water due to (1) a blockage in the line; or (2) water valve in the bottom is not pumping water to the icemaker.
Or the icemaker control unit is not sending the signal to the water valve when water is needed in the ice-making cycle.
Oct 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker not working
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 21, 2009 | Whirlpool GD5SHAX Side by Side...
Whirlpool icemaker
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Check the water inlet located at the back of the fridge.
Jan 06, 2009 | Whirlpool GS6NBEXR Side by Side...
Jun 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker not making ice
The same thing happened to my Whirlpool gold. Defrost it for 24 hours and the ice maker now works.
Apr 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool GD5SHAX Side by Side Refrigerator Logo
80 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
