Question about KitchenAid KCM511 Coffee Maker
TIME AND TIMER PROBLEMs
I recently asked a question about how to set my time and timer on my Kitchen Aid coffee maker
The model number is 543OB
The SKU number is 82524
Can you help now?
  • 231 Answers
Http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KCM511&siteCd=KAD
If not that model, you should be able to navigate to your particular model. =>
http://www.kitchenaid.com/custserv/service.jsp
Good Luck!
Posted on Dec 27, 2008
Kitchen-Aid Electric control panel buttons stopped working
This may sound facetious, so don't get offended.
Did you set your clock to the correct time?
Did you clear any and all preset timers?
If none of that helps you can usually find roaches in the strangest places. If you have no roaches, then moisture and heat are the likely culprits which means that your blister pads are simply worn out. Unfortunately these are coated with graphite and don't last forever, so a timer replacement would be your only option unless your touchpad is separate from your timer.
Mar 05, 2010 | KitchenAid KERC507 Electric Kitchen Range
I need an instruction booklet to set the timer for the coffee.
Go to Hamilton Beach dot com, pull down customer suppot menu, click on use and care guides, type in product and model number, click send and your manual will load. Print it out so you have it. Setting the timer is a piece of cake, Hold down the program button until the clock flashes. While still holding the program button down, set the timer for whatever time you want the pot to perk. Let go of the program button. To check if the timer is set right right, puch the prigram button just long enough to see what time it is set for. If it's right, prepare the pot the night before, push the program button to set and forget about it. It will perk at the time you set every morning. Katherine
Jul 11, 2009 | Hamilton Beach BrewStation 47214 Coffee...
How do i set the timer for the coffee maker and set the time too?
The on-timer is a little weird--you need to set the turn-on time and then enable automatic turning on (two separate menu items).
Apr 06, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Need help on using Timer feature on Melitta Mill & Brew
My second one just died, and I am very sad, but I can help you with your question.
First you have to set the time. Do that by pressing the hour or minute buttons until the time blinks. Then you can press the buttons to set the time. AM/PM are differiented by a red dot coming on in the time display. You can set that as preferred.
To set the timer feature, press the time button until the time blinks. Then use the hr and min button to set your timer setting. Pay careful attention to match the am/pm button with what you want.- if you don't you will be 12 hour off. To use the delay, set up the coffee pot, then push time. The red time indicator will light. If you are using ground coffee press the mill button. If it is lit, the mill will not turn on. This goes for either timed brewing or present tense brewing.
THe coffee pot has a timer - it will shut itself off after 1 hour. If you want to restart it, just push the mill button and press the on/off button.
Mar 15, 2009 | Salton Melitta Coffee Maker 10 Cup - white...
Mr. Coffee won't brew - Mod. #ECX30118
IF YOUR HAVING ISSUES WITH THE ACTUAL BREW OR CLEANING CYCLE AND IT WILL NOT WORK, THERE IS NO TROUBLE SHOOTING THAT CAN BE DONE. MR COFFEE CARRIES A YEAR WARRANTY SO YOU SHOULD CALL THEM TO HAVE THEM REPLACE THE UNIT.
Jan 14, 2009 | Mr. Coffee FTX24 12-Cup Coffee Maker
SHUTS OFF AFTER 1 HOUR
Here ya go!
Setting Auto Off (units with timer only)
On models with a glass carafe, the auto off can be set to shut the coffee machine off from 1 - 5
hours after the brew cycle is complete. The factory setting is 2 hours. On models with a thermal
carafe, the coffee machine shuts off after 20 minutes.
Note : On models without a timer the coffee machine must be turned off manually. It
will not automatically shut off.
• Press the prog button (o), immediately followed by the h/min button (n).
• The display will show the time setting.
• Press the h/min button in steps to set the auto off time.
• Press the prog button to confirm the setting.
Dec 30, 2008 | Krups FME2 Coffee Maker
I dont have a manual for my Kitchen Aid Coffee makers. Im not sure how to set the time and how to set an auto timer to go off. Help?
If it's KCM511, follow this link =>
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KCM511&siteCd=KAD
Good Luck!
Dec 27, 2008 | KitchenAid KCM511 Coffee Maker
Black and decker coffee maker
what type of coffee maker? does it have a model number?
Dec 11, 2007 | Coffee Makers & Espresso Machines
KitchenAid KCM511 Coffee Maker Logo
116 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
