Question about Maytag Dishwashers
Will not clean
It fills up with water and runs through the cycle but dishes are not clean i think it does not spray what is wrong
  • 14 Answers
I had the same problem with my Kitchenaid dishwasher. It would fill with water, heat up, and sound like the motor was running just fine. However, the bottom dishes would be poorly cleaned and the upper dishes would not be touched. Fortunately, my repair did not require pulling the dishwasher out from under the counter. The repair was done within the wash cavity.
I completely drained the water out of the dishwasher (if it hasn't ran through it's cycle). Use a turkey baster if necessary. I Removed the lower wash arm, upper arm supply tube and then started removing plastic cover parts until I worked my way down to a part called the "Chopper assembly". Torex screwdriver bits were necessary in my case.
The chopper assembly is a small metal screen, a metal blade and a plastic drive rod that spins the metal blade.
will not clean - c9a1a9f.jpg Chopper assembly
In my case, the plastic part of the assembly was broken and the chopper was not spinning. The screen was plugged with food junk and water could not get past the screen to the wash arms. the spinning blade also ads a little pressure...when it spins.
the part is $21 online, but may run $30 at a local parts store.
Posted on Dec 27, 2008
Dishwashwer not cleaning dishes at all, though it runs through a complete cycle.
try removing spray spinner and clean out holes the spray heads get blocked and stop water flow, or you may be able to remove spray nozzles and clean out , i had this several times in the past also make sure the base drain filter is clean some times the small holes in the filter get smaller and smaller reducing water flow
hope this is of some help good luck
Aug 02, 2016 | Bosch SHE5AL06UC 24 in Builtin Dishwasher
Hello, our Whirlpool dishwasher is about 3 years old. It is not cleaning the dishes; I don't think the arms are turning because the door is always dirty, so no water is getting that far. Also, the cycle...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 26, 2011 | Whirlpool Dishwashers
It is just not cleaning the dishes. Runs - OK
Hi
Daniel
Mar 24, 2011 | Maytag Jetclean II MDBH945AWS Stainless...
Dishes are not coming clean. The detergent basket is not emptying out, after cycle has run, the detgergent is still partically in the dispencer
Hi
Jan 24, 2011 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishes not clean after running. Dishes and glasses have a white residue on them after drying. Water is turned on and seems to ok. When I open the washer after the wash cycle starts there are several...
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back if you need more informatiion.
Daniel
Nov 26, 2010 | Bosch SHU9925UC Built-in Dishwasher
Our dishwasher was cleaning just great...then the next washing...no clean dishes. We thought we forgot to run it, so reran, and the same thing...dirty dishes. Any ideas?
Hi
Daniel
Oct 03, 2010 | Amana Dishwashers
Dishes do not clean, whats wrong
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Please post back for any further assistance.
Daniel
Aug 21, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
If the lower and upper spray arms do not turn what could be the problem? I have a MDB4100AWB and I of course have hard water in our area and wondering what is causing the spray arms to turn.
could be the plastic shaft extension that screws onto the motor shaft to drive the pump. The threads on the plastic extension would sometimes get stripped out so that even though the motor is running, it isn't driving the pump mechanism. Assuming the dishwasher is filling with water and motor is running during the wash cycle. also check spray arm openings to make sure they aren't plugged up.
Jan 24, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwashers Logo
302 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
