Question about Holga Flash, 120 Medium Format Camera Starter Kit. Medium Format Camera
My Kodak EasyShare C315 needs formatting.
When I inserted my memory card it said "Memory card requires formatting." So I clicked continue, and then it said "Formatting will delete everything on memory card.(But I just got the memory card.) I click continue and it says "Formatting...FILESYS ERROR e00100." Then it just goes back to the screen, "Memory card requires formatting." I don't know what to do. I really would like to use my camera and get new picture's on my computer. Please help me. Thank you.
For all the camera users whose cameras won't format...they can't accept all the info on a 2 gb memory card... install a 1 gb card...worked like a charm for me! C315 and others were made before the 2 gb card. Only 1 gb cards work in the older cameras.
Tami
Posted on May 25, 2009
Whenever i put a new memory card in the camera it tells me to format the memory card. whenever i press continue it goes back to the format memory card statement. how do i format the memory card
First, be sure the card slide switch is in the unlocked position. Then, insert the card,ignore the message on the screen and go into the camera menu to find "format"...then, follow the on-screen instructions.
Aug 18, 2010 | Kodak EasyShare C315 Digital Camera
Memory card will not format in Kodak Z760
Hi There
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jul 22, 2010 | Kodak EasyShare Z760 Digital Camera
    FORMAT MEMORY CARD
    After downloading any pics from the card using a card reader if necessary, go ahead and format it in the camera.
    Jun 21, 2010 | Kodak EasyShare C315 Digital Camera
    I have a kodak easy share c530.ihave inserted a new memory card and it keeps say Memory card requiers formatting,ipresse continue to start the formatting but it keeps giving the same message how do iformat...
    The lever on your card might be turned the wrong way. Pls. readjust and try again.
    The card might not be supported:
    You camera Memory card support : SD/MMC up to 1 Gigabyte
    Good luck pls. rate me and/or recommend me if helpful
    TXS
    Nov 28, 2009 | Kodak EasyShare C315 Digital Camera
    I have a Kodak EasyShare C633. I have inserted a new memory card & it keeps say "Memory card requires formatting". I pressed "continue" to start the format, but it keeps giving the same message. How do...
    This camera requires either a sd or a mmc card, and must be put in with the front of the card (the card with the label on) to the front of the camera. If installed backwards or with the label facing the back, the camera internal parts can be damaged beyond repair.
    Make sure you can read pictures on another sd or mmc card from another camera. If it can read, make sure you have the right kind of card. This camera came with a 16meg card, so make sure that it can read larger cards, most should, since this camera was made in about 2006. However some cameras may have problems with large cards such as over 2 GB. Just a thought, and try it.
    Oct 25, 2009 | Kodak EasyShare C315 Digital Camera
    Memory Card
    Hi...
    The way to format is just follow this, you just plug you camera to the computer then turn it on, after that, the camera will detected, you open my computer, you can see the removable disk, just right click then format then check quick, then ok
    Good luck !!!
    Regards
    PCmania
    Jul 06, 2009 | Kodak EasyShare C875 Digital Camera
    Kodak C530 Digital Cameras
    No the Brand would not make any diffrence if the memory card doesnt get formatted on the camera itself u can try to format it on the computer............ Just insert the memory card into the camera connect the camera to the computer goto my computers there u will see the camera removable disk which is the memory card...... Right click on that click on format and format it........Then try to use it on ur camera i am sure it will work fine..............
    Jun 27, 2008 | Kodak EasyShare C315 Digital Camera
    Memory Card Requires Formatting
    Hey B418,
    Formatting will delete all your pictures on your camera or memory card. The camera might be prompting you to format because the the camera's memory is full. To avoid losing your pictures I would connect your camera to a computer, download your images to your computer first, and then format the memory.
    Sincerely,
    Allan
    Go Ahead. Use Us.
    Apr 27, 2008 | Kodak EasyShare C315 Digital Camera
    Photography Logo
    205 people viewed this question
    Top Holga Photography Experts
    pontelemon
    pontelemon
    TC CAMERA REPAIR.Com...
    Are you a Holga Photography Expert? Answer questions, earn points and help others
