Back to:
Tags:
iLO DVDRH04 DVD Recorder
NONFINALIZED DVD'S THAT ONCE PLAYED WILL NO LONGER...
posted by goatman100 on May 09, 2007
My nonfinalized DVD home movies that once played, no longer play on my iLO DVDRH04 DVD Recorder. Why?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 09, 2007
Helpful (85)
servis
Rank:Wiz Wiz
Rating: 81%, 124 votes
This seems to happen with alot of dvd recorders especially if discs left unfinalised for long periods of time.This happens on all makes of recorders not just your model.Also the quality of the dvds being used can be the problem.How old is your recorder as the only other problem which could cause this is the laser losing power
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on NONFINALIZED DVD'S THAT ONCE PLAYED WILL NO LONGER PLAY:
I don't want to Accept this solution
Solution #2
posted on May 29, 2007
Not Rated (0)
ffarkle
Rank:Apprentice Apprentice
Rating: 60%, 3 votes
Dsics should be finalized shortly after recording is completed. Disc errors and anomalies wll occur in every recording after time, exposure to solar radiation, scratches, and as a consequence of "DVD rot". If the errors occur in a critical area of the disc, the recorder will no longer be able to recognize it and finalization will no longer be available.
Thank You!
Can you Help with these DVD Players problems?
I can still record but when I try to finalize it says to...
code error 0x81060b0d
i dont have the remote infrared how cant finalize the...
How do I clear a timer setting when I make a mistake ?
recorded movies off of the tv .when i play them back...
Loading problems.
Repair Service
Find DVD Player Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
