Question about Ariens Garden
My Ariens snowblower (model #924048) won't start
It won't start now. It ran for about an hour a week back. Spark plug and oil are okay. If I spray 'Gumout' into the carburetor after removing the cover it starts and runs for two seconds and then dies. Everytime I spray Gumout it does the same thing. Is this something I can fix it myself/
  • Dave Bisset
    Dave Bisset Nov 27, 2013
    Hi chennindirar, Check that your fuel has not been sitting so long it has deteriorated. Try draining it and replacing it with fresh issue. We had this with a chainsaw. Regards, Dave Bisset
    President:
  • 2,692 Answers
Dissamble carburator. Spray Carburator cleaner  through passages, and wash out bowl. Dump gasoilne if old.  Reassemble Carburator. PS count the turns on the two Jet (mixing) screws and place back into the same position after cleaning passages.
Posted on Dec 27, 2008
Why I have a toro snowblower model#38272 that started a couple weeks ago and now will not start
Check wires for insulation damage. Spray Carb Starter Fluid into manifold and see if that gets the machine to turn over.
Feb 03, 2015 | Toro Garden
How do I start and Ariens snowblower - model # 5524?
you can get manuals from ariens website easily
Jul 08, 2017 | Garden
Changing spark plug on model 921022
I have attached a link to an article and video that will help you be able to change your spark plug. It is very easy to do and a quick fix that solves many engine problems. I hope it will help you accomplish what you would like to do!
These step by step instructions will have your spark plug swap done in no time!
Best of luck!
Changing the Spark Plug on an Ariens Two Stage Snow Blower
Jan 24, 2013 | Ariens Deluxe 28 Model 921022 St28le 2...
Craftsman snowblower Model 536885214 plug in electric start, started, ran few minutes, now turns over but wont start ?
My 8 horse has an adjustment screw on the carburetor Turn it out a little at a time till it keeps running Just don't over do it If you turn out too far you will flood it.
Dec 26, 2012 | Craftsman Snow Blower / Snowblower Bottom...
Engine wont start
press the primer 5 or 6 times full choke and make sure idle lever is up a little when it starts take choke off one notch at a time then rev engine slowly
Dec 21, 2012 | Ariens Deluxe 28 Model 921022 St28le 2...
I have a 1984 ariens snowblower with a Tecumseh and no spark
Electronic Ignition was introduced on many engines about that time frame. I would need to have model and type numbers from the engine to fully determine that question. However, have spark is still the issue. If the unit has a switch installed on the operator's console, it should be disconnected at the engine so that any safety switches are not masking or causing a problem that is not engine related.
Let's investigate a few basics first.
a) How have you determined that there is no spark?
b) Have you used a type of spark tester?
c) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug, it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Nov 13, 2009 | Ariens 34 In. Zoom Series Riding Mower
Brand new Ariens ST624e seized after 15 minutes of operation?
if there is oil on the sparkplug, you have blown a cylinder seal. It will need repair.
Dec 24, 2008 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
917 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
