Question about Grundig S350 AM/FM/SW Radio
I replaced the batteries in my S350 and it started smoking.
I smelled a strange odor and when I took the batterie out they had melted the battery connectors. It no longer works. I has been working perfectly for 4 years.
    Problem Solver:
  • 6 Answers
There are any number of reasons for this to occur, but I would call Eton customer service in California. They're very helpfull and the number is located on the manual that came with the radio. If you no longer have that, just go to their web site.
Unfortunately, the limit on the warranty has run out, so their is probably nothing that can be done outside of buying a new one. ACT Electronics can fix Grundig radios, but the price will probably exceed the cost of this model.
Posted on Jan 10, 2009
Nissan Altima 95 won't start after dying when I was driving, at first it would turn over but not start now it won't even turn over, puff of smoke came off the ground wire when I tried to start it, got hot...
the alternator , battery , or starter has burnt out or has a short to earth , wire may be rubbing on chassis some where, trace the wire that you saw smoke from and make sure its not worn through etc , at the least i would say a new alternator and battery is required , without seeing the vehicle its hard to be specific, hope this helps , also will need to check the fuse box's for any blown fuses , make sure you've located that smoking wire
Jun 16, 2014 | Cars & Trucks
We replaced the alternator in our 2004 Kia Sedona. It started great at first. The next time I started it, it seemed to be idling low and then it cut off. I came out a few hours later started it up took a...
those cars are known for having over charging problems check to make sure the batteries not boiling over and also check the wiring to the alternator to make sure its not melting at the battery terminal
Nov 15, 2013 | 2004 Kia Sedona
Smokes and smells like gas at muffler
That has to be gas that is not being burned! No idea why blowing a fuse with the air compressor rashed your car like that - must be coincidental or collateral damage.
Sep 04, 2017 | 1994 Ford Mustang
Black and decker firestorm 12V charger has melted the battery
There are no parts available for these tools. The Firestorm line of tools were involved in a recall around 2002. It is extremely hard to find any Firestorm tool around anymore and ever rarer to find any that work. Most of the problems were centered around melting plastics and some involved smoke and fire.
Aug 26, 2012 | Black & Decker Black decker Firestorm...
After extended city driving, get strange burn odor.not rubber, not electrical smell. Then engine power start dropping, pull over and park for 15 mim.,Restartand power returns to normal.No elecctrical...
sounds like you may have a bad caytalatic convertor they will have a bad odor and put a lot of back pressure wich will cause bad fuel mixture and poor power but when you let it sit it will clear up ,pressure will reside and 02 mixture will coorect its self,hope you can use this.
Jul 05, 2011 | Chevrolet Tracker Cars & Trucks
Drill completely stopped working. Bad smell from battery. Charged up the second battery and plugged it in. In three seconds, it started smoking very badly. I removed it. The drill worked with second...
The only way to tell if you can fix it is to take the drill apart...
Look for two wires melted together...my guess is that they got too hot and melted together inside the drill... separate and insulate and you should be fine...
heatman101
May 21, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Not turning on and has strange smell
Powershot A640 Could Not Be Powered On, Burnt Smell
My Powershot A640 died during a picture shot, lens remaining open. I thought it may be due to the dead batteries. But after putting new batteries and pushing the on/off button, the on/off indicator blinked once then shut off by itself. After a while, a strange smell came from camera batteries area, and I could feel warm there too. Immediately I took out all the batteries from camera.
When checking the posts here the other day, I tried one solution and got the lens back to close: first took out the memory card from camera, then put the new batteries in; push the on/off button with no memory card. I found the lens retracted a little before camera shut off by itself. I pushed on/off button three times to get the lens fully close. However, the burnt smell came out again. I immediately took out the batteries.
Did I get a short circuit inside? Is there any ways to fix it?
Oct 31, 2008 | Cameras
Electrical Problems
Do not leave the car in the garage without the battery disconnected until you locate the source of the smoke, the best tool to find the smoke's source is your nose, smell the area around the source of the smoke, if you smell a really nauseating smell you found it, then look for signs of burnt wires or burnt components, also look for any oil that may have caused the smoke, but I doubt that was the source, this sounds electrical. I know of no problems for your car that would cause this, so most likely it is not a common problem.
Oct 19, 2008 | 2003 Mazda Tribute
Odd odor
Yes..... that odor you smell was a component burning out on the circuit board. if you were lucking it only burned out one thing. fixable....if you have the time. actually anything is fixable it usually boils down to the cost of fixing it vs replacing the item.
Robert
Sep 26, 2008 | Grundig S350 AM/FM/SW Radio
Flashing dash lights
if it runs ok leave well alone the smell will linger for long long time though ,open a window
Jul 22, 2008 | 1995 Isuzu Trooper
Grundig S350 AM/FM/SW Radio Logo
168 people viewed this question
Top Grundig Audio Players & Recorders Experts
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
