I cant find my imei on my htc p3450 so i need a picture to help me
Most phones display their IMEI by lauching their dialers and dialling *#06#. It is highly probable that your phone will show its IMEI number right after the last # is entered, Nevertheless, some of them will require you to press the green call button afterwards.
Hope it works for you.
Anyway, please, let me know if you need further informations.
Regards,
Carlos
SOURCE: GPRS with AIRTEL on HTC P 3450
GPRS service is there in airtel but there is no wap service for the htc mobile 3450... as i am using the phone i will browse the sites through GPRS by Internet Mobile Office
SOURCE: wifi in htc p3450
ok look frist you have to turn off the bluetooth and the phone and activate the wifi if not it will not work
SOURCE: ho can do reset my htc touch p3450?
if u are talking about soft reset without wiping the data u just want to restart the PDA just press the standby power button up side for like 5 seconds it will switch it off then press again for the 5 seconds it will come on and boot and if u are taking about hard reset it will format all data take out ur memory card if u want to save it press the both call and end key together and then press the power button on the up side of PDA for like 5 seconds then screen will come up asking u to confirm just press the centre button of the 4 way joystick and go
SOURCE: Free virus download for my HTC Touch P3450 Smartphone
hello
kindly go through this link and over here you will get all the anti virus software and other software as well
SOURCE: Cannot Install .jad/.jar files on my htc touch p3450
Originally, Windows Mobile is not compatible with java files (.jar/.jad). But IBM has a software for Windows Mobile users that solves this issue. (An emulator called WebSphere Everyplace Micro Environment)
1) Go to the downloads section for WebSphere Everyplace Micro Environment
2) Depending on your version of Windows Mobile 5, download the installer (ibm-weme-
wm50-arm.xxxxx.exe):
CLDC 1.1/MIDP 2.0 for Windows Mobile 5.0 Smartphone Edition/ARM
CLDC 1.1/MIDP 2.0 for Windows Mobile 5.0/ARM
CLDC 1.1/MIDP 2.0 VGA (Hi-Res) for Windows Mobile 5.0/ARM
3) Extract and then copy the folders [bin, lib and examples] extracted from weme-wm50-arm-midp20_6.1.0.20060727-102926.zip to a folder in the root of your mobile device
4) On the mobile device, run the emulator exe from the Bin folder and give the direct path of the Jar or Jad file (whether local or on a website)
5) After the Midlet is installed, tap on the Midlet to run it
You should be able to run any Java based Application/Game on your Windows mobile device
