Question about Kenmore Microwave Ovens
Fire hazard On December 26, 2008 my daughter made a bag of microwave popcorn. She had some problems getting the oven to work right . the light would come on and the timer would work but the plate would not turn and the microwave did not hum. We opened it and reclosed it but to no avail. Finally my husband jiggled the door opener and it worked. No more problems. Until the smoke detectors went off 15 minutes later. The microwave was on fire. It burnt our counter and floor. The house was filled with smoke(we opened windows to air out). My husband was able to unplug it and sit it in the grass, the microwave burned for about another 20 minutes. We are lucky we did not lose our home because of this faulty product. I need to know who to get ahold of for this.
  • Kenmore Master
  • 9,098 Answers
I don't mean any offense in my solution, and I urge you not to "kill the messenger" when you rate my solution, but I need to give you the facts as I see them.
When the oven failed to work right, it should have been taken out of service until it was properly repaired. Just jiggling the door would not qualify.
I couldn't imagine Sears having been found to have any liability for this, since the oven was known to be failing and it was used anyway, and it was apparently left running unattended, which every manufacturer warns against in their owner's manuals.
This post will be the public record of those facts.
It was almost certainly failing due to a bad door switch or door switch mount.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
Maybe your insurance company will cover part of this damage, but as far as any liability goes, I'd say Sears is in the clear.
But I'm not an attorney, just for the record. I just work for them in liability cases in my capacity as an electronics expert witness.
If you do happen to file suit, I would be more than happy to give a statement on this, so feel free to contact me with the case numbers and court info.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 28, 2008
Have a kitchenaid microwave KHMS2040WSS brand new. Is there a way to set the popcorn sensor for a smaller bag? Right now it is set for 3.5oz and burns all the popcorn.
I have never seen a microwave that doesn't burn popcorn if you use the "popcorn" button. Why the manufacturers keep putting them on I'll never understand. There's nothing you can do change the presets on an oven since they are built into the controller. Instead of relying on the oven, you should follw the directions on the bag. These tell you to use high power, stay by the oven and stop the cooking when the time between pops drops to 1 or 2 seconds. Stored heat will continue to pop kernels for a bit, and you won't cremate your popcorn. You'll also avoid the possibility of the bag catching fire and damaging the oven, which I have seen several times. Finally, don't expect 100% of the kernels to pop. There wil always be a few duds, and extending the cooking time just results in burned popcorn.
Jun 05, 2011 | KitchenAid KHMS2040W Microwave Oven
Microwave sparks and makes noise only when fixing microwave popcorn. Otherwise, microwave works fine. The microwave previously worked fine with microwave popcorn. This happened with another brand of...
Hello bruton. As a microwave oven ages, the interior paint often deteriorates as does the internal part that creates the micro waves.
Using this is not a good idea as there is now a fire hazard. The best solution is to replace the microwave. There are sales now and you can get a nice new one for under $100.
Joe
Thanks for choosing Fixya!
Mar 23, 2011 | Microwave Ovens
Over heating and shuting off
I am not surprised! Cloth of anysort is not recommended to be placed in a microwave oven!
That includes undies and socks which many try to speed the drying time of.
Regarding the popcorn.. The oven is overheating due to a possible containment in a hutch, where insufficient airflow is available to lower the temperature. Pull the unit away from the wall to allow more airflow, clean the vents and help it breathe.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson MW8119SBM microwave. Use popcorn button.
Try clearing the microwave before pressing the popcorn button again.
Feb 21, 2010 | Microwave Ovens
Microwave burns popcorn. what part is defective?
If the microwave functions normally while cooking everything else, but is only burning popcorn, there is no component problem that will cause this. You cannot adjust or replace any internal component to make it not burn popcorn. All power levels and program options are contolled by the consumer at the control panel. Refer to your owner;s manual for their recommendations.
If the oven is equipped with a popcorn feature button, it is programmed for a recommended power level and time. This is an ESTIMATED program feature. The manufacturers of both the oven and the popcorn will also give directions that tell you to turn the oven off when the popping slows to about a pop every 2 seconds. Failure to do so can result in burning.
If the microwave does not come with a popcorn feature button, the manufacturers of the popcorn have directions on the outside of the box that tell you what POWER LEVEL and TIME to set the oven on for the desired result. Again, the you still have to listen as the bag pops to ensure it does not burn.
In addition, on some microwave ovens, there is a feature that allows you to select the SIZE of the popcorn bag. Some popcorn manufacturers have smaller snack size bags that don't take as long to pop. You have to select the appropriate size to get the correct program option.
In any case, you never are to place popcorn in a microwave oven and walk away from it. All these program features are ESTIMATIONS based on manufacturers testing and recommendations for the best results. All microwave ovens are different and operate at different power levels. Your best judge is to listen as it pops.
I hope this helps you.
Dec 23, 2009 | GE XL1800 1100 Watts Microwave Oven
My Dacor DCM24 microwave/convection oven is brand new and won't pop popcorn--old or new, large or small bag, with twice as much time as is on the bag, power on high. Doesn't work with the popcorn button...
Are you cooking it this way, as shown in the owner's manual?
"Use an overturned 9 or 10 inch oven proof glass pie plate on top of the
turntable when popping bagged microwave popcorn.
You can also use a paper plate in a pinch, but as always, never leave a microwave unattended while it's cooking, since some paper products can have impurities which will allow overheating and possibly fire.
This is a convection oven, so it has a metal turntable tray.
Microwaves cannot penetrate the metal from below like it would on a standard microwave's glass tray, allowing for even heating.
If you've lost your owner's manual, you can get it here.
Oct 21, 2009 | Dacor DCM24 Convection/Microwave Oven
I tried poping some popcorn in a brown paper bag and it caught on fire. I tried to the microwave again after i put the fire out and cleaned the mess up but nothing is working at all. No breakers were...
all microwaves have flame sensors that will cut the power in case of fire, this sensor will most likely have to be replaced. this will require you to drop the m/w and remove the case.
Jun 16, 2009 | Maytag MMV4205 Microwave Oven
Small 10 sec fire in microwave
it may be ok , but it should be checked for internal damage
Dec 10, 2008 | Whirlpool MH7140XF Microwave Oven
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
