Question about NetGear WG311T 802.11g/b Wireless Adapter
Computer Crashes When using this Netgear device
Basicly my computer crashes when i use the Netgear WPN311 Wireless PCI adapter. I've tried disabling the LAN, still it crashes. I thought it might be a hardware problem however i tried it out on a friends computer and it worked fine. The difference between our computers is that he has Intel P4 Proccessors and i have Duel Core Athlon. I thought this may be the problem, but if it was im sure there would be some kind of warning about the conflict. Please help me. It seems to crash when i use the internet alot. E.g downloads, msn, internet explorer etc. It appears to work ok if i slowly browse the internet. Thanks for you time.
  • Marcus Durkan Apr 20, 2007
    Me again. Just one more thing to add. I can use the linksys wireless PCI card and the Netgear USB adapter and the inter woks fine.
    Once again thank you. ;)
  • 385 Answers
Try downloading the latest drivers for this device and install. See the website below. http://kbserver.netgear.com/products/WPN311.asp
Posted on Apr 21, 2007
SOURCE:
I need a driver for Netgear WG311v3 802.11g Wireless PCI Adapter for Windows 7 32bit
You can try downloading from this link:
http://netgear-wg311v3-802-11g-wireless-pci-adapter.soft32.com/
Nov 14, 2012 | NetGear WG311v3 802.11g Wireless PCI...
Resource conflict-how do i resolve?
It appears you have a driver issue. What you can try is reinstalling them.. To do this just insert your main board cd and install the drivers of it..
If that fails remove the drivers and let windows axcess the generic drivers and then reinstall your drivers.
TO remove a driver , click start, right click computer
click properties then hardware then device manager
right click your devices to the let, the ones with the confilct, main board and wireless adapter , and choose uninstall..
another thing you can try
is downloading tune up utilities from www.phazeddl.com and running the registery scan..
If the above fails as a last resort , back up your data, format your harddrive and reinstall windows as well as your drivers and software. If after that the problem persist then a hardware device is defective ,, i'd say your wireless adapter thats why the system crashes when you run it.. Replace it..
let me know what happens
Jan 19, 2008 | Gateway MX6128 Notebook
Won't detect usb from cd instalation
Have you read the instructions.
Have you disconnected usb while installing disc,this is important.Wait till the installation tells you to plug in the usb adapter,then the driver will detect the adapter at the port because it is now searching for it.Good Luck.
Aug 10, 2010 | NetGear : WPN311 Wireless PCI Adapter...
How do i connect to my livebox c240 using a netgear wpn311
following steps can fix your issue(only for XP)
ENABLE WZC
Please perform the following steps on your wireless computer to enable WZC (Wireless Zero Configuration):
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Mar 14, 2010 | NetGear WPN311 108 Mbps 802.11g RangeMax...
Windows Vista crashes when I connect my Linksys wusb54g wireless adapter. It worked fine for about 3 months, then started crashing, now I can't have it connected, or it crashes instantly.
This is a software conflict of the linksys device to your system, so to correct this remove first the software from your computer and then after that restart the computer and then connect the adapter on different usb port , if still having the same problem i will suggest that you have the device replace.....
Oct 09, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
2wire 802.11g wireless adapter freezes/crashes vista
first: try using most recent drivers
second: if hat doesnt help, instruct vista not to power down that device to save energy. older drivers have trouble when the device goes down in vista
May 28, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Need to know where I can get driver download.
Possible causes:
1)The Operating System on the computer might not support the Plug & Play feature or need latest system updates.
2)The USB port or PCI slot on the computer might be faulty.
3)Extension cable (if being used) that connects the USB adapter and the computer might be faulty.
4)There is no driver support for the Operating system.
Symptoms:
1)LED will not light up on the adapter.
2)Found New Hardware Wizard does not come up.
Resolutions:
1) Make sure you meet the minimum system requirements for the adapter and have the latest updates on the computer.
2)Use the latest driver for the adapter. Latest drivers link is mentioned below.
3)Try a different USB port or PCI slot on the computer.
4)Try another device and check if it gets detected.
5)Try to connect the adapter directly to the computer without using an extension cable.
6)Try restarting the computer or try adapter on a different computer.
Open the below link and try to download the latest version of the driver http://kb.netgear.com/app/answers/detail/a_id/747
May 18, 2009 | NetGear WG311T 802.11g/b (wg311tge)...
Netgear wpn311 adapter
uninstalled the drivers from the computer.
unplug the adapter and restart the computer.
now install the driver which you download from the website.
i have send u the link where u can find the driver for this adapter that works with vista. use this driver.
http://kbserver.netgear.com/release_notes/d103109.asp
after installed the driver, restart the computer.
once the computer get restarted, plug in the adapter. and run the "new found hard ware wizard".
May 24, 2008 | NetGear RangeMax WPN824 Wireless Router...
NetGear WG311T 802.11g/b Wireless Adapter Logo
187 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
