Question about Microsoft Xbox Console
Just bought an XBox at the Pawn shop. Have it hooked up to an old TV (no plug in available for the red jack), can go through menus, etc. But not sure how to access the game I have in the console.
    Problem Solver:
  • 6 Answers
Sorry but I think i have some bad news... You said you have the game in the console so it should automaticly load. If it dosnt you should try for a refund because the lens is messed up and cant read discs.
Posted on Dec 31, 2008
I have a phillips mx 3900d five disk surround sound system, however I cannot figure out for the life of me how to hook it up to my xbox 360.
Well if hooking Xbox with rca jacks it came with..plug in the red and white one to the sterio.. or run rca jacks from back of TV..red and white from TV out..or audio out..to sterio..
Aug 15, 2014 | Video Game Consoles & Games
WE JUST BOUGHT ROKU , HOOKED IT UP , CAN'T GET ANYTHING ELSE TO COME UP
You must match the TV's input connections and the Roku output on your remote. This means if the Roku's output is connected to your TV's "HDMI 2" (or A/V 2, etc.), you must be able to select HDMI 2 (or A/V 2, etc) on the TV - either with your remote or pressing a button on the TV itself.
Sometimes, the TV will skip over unused inputs when it was first set up. This is done to reduce the number of button presses to go from say "HDMI 1" to "HDMI 4" by programming OUT the HDMI 2 & HDMI 3 choices.
You'll need to program IN the input that your TV uses to connect the Roku if it isn't already available. You MUST connect cables properly if not using HDMI. RGB is Red-Green-Blue and must be connected to RGB jacks at the Roku and TV for a picture and the the White & Red (left and right) audio must connect the the corresponding Red / White audio jacks - or it will provide strange results.
Make sure the power plug is connected to an outlet that is ON and connected to the power jack on the Roku box itself. Unless you have a defective Roku box or TV, it SHOULD work. You can try using a different HDMI or A/V jacks on the TV to determine if it is the TV jacks or not.
Sep 10, 2013 | Televison & Video
I bought a brand new xbox 369 last night. i also bought a brand new 32" flatscreen emerson le320em3. is this tv not compatible with an xbox 360? i was able to get the tv hooked up to cable and the...
Your problem is in the TV. I'm not familiar with your TV, but you should look for an option to turn it to normal or to try and scan for channels with xbox plugged in and running. I'm pretty sure that if you get HDMI cable, your problem should be solved.
Feb 06, 2013 | Video Game Consoles & Games
Hi, I bought an aquos lc-30hv4u and it has no rca jack etc, only two plug ins labled display input 1 and 2. I am guessing its just a pc monitor. How would I use it for cable tv video games etc
There are lots of inputs on the back behind the cover. Three inputs (1, 2, 3) have an S-video, composite video (A/V) and component video jacks. The cover will come off if you press the two top hook at the top of the cover. Then rotate the cover towards you. There are also a DVI-D port and 2 coax (antenna in) jack. The tuners included are for NTSC (analog OTA) and CATV (analog cable). The front of the PC (VGA) and a S-video or composite (A/V) video input (called Input 4).
Composite and component video jacks are all RCA jacks (as are the associated audio jacks for the input). Composite cables uses three RCA plugs on each end - yellow for video, red and white for Right and Left audio. Component video cables have three plugs on each end that just carry video (red, blue and green); the audio is wired separately with just 2 RCA red/white plugs. Match your colors from the device out to the TV input.
Changing inputs can be done with the remote or the input button on the top of the TV. The input button is to the left of the power and Main Power buttons.
Connecting your game system, cable system and all will depend on the units. For the best picture, use component video cables for mose set top box. Some cable boxes have a DVI port - use that if the box has that option. If they do not have component video out, then use composite or S-video cables.
The owner's manual is available from Sharp as a pdf: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx?downloadtype=ownersmanual . Use the drop down menus as follows > LCD TV, Model not listed, LC-30HV4U then click Search. The picture of the inputs are on page 10.
I hope this helps.
Dec 15, 2010 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
I've plugged in the red, white, and yellow cables to my TV, and I'm getting sound but no picture. I've plugged in the cables the same way I successfully do for my Wii, but still get no picture. PLEASE...
There is probably a short in your av jacks somewhere, try going to a pawn shop or resale shop and getting some used av jacks off of another N64.
Nov 21, 2010 | Nintendo 64 Console
I need a small speaker to hook to the red and white jacks that normally connect to a TV
Cheapest ones are at Ross, the discount clothing, etc. store. They're made just for MP3 players and have a built in amplifier. About $20.
May 28, 2009 | Audio Players & Recorders
Game access
Once you put the game in... just wait patiently... if the game doesn't load up within a minute, then something is definitely wrong with your xbox. back to the old adage.. "you get what you pay for" ... good luck... i really hope that it works.
Dec 27, 2008 | Microsoft Xbox Console
Using the device from the cable outlet
Not a stupid question. You should have received all the cables you need with the Leap Frog. To hook up your tv, take your transmitter and one set of a/v cables, usually red, white and yellow. Do one cable at a time. Your tv outputs should be color coded. You should have one set of three jacks completly open on the back or side of your tv, i.e. labeled component 1, component 2, aux 1, etc. First plug select one set of jacks. Plug a yellow plug into the yellow jack on your tv labeled video out. Plug the white plug into the white jack labeled audio L out. Plug the red plug into the red jack labeled audio R out. Now do the same on the transmitter but the jacks should say in. Yellow, white and red to video, audio L and audio R. Now take your receiver into the other room and do the same thing with the other tv. The cables go from the receiver out jacks to one set of jacks labeled Aux, component, etc like before. Pick a set that has all three open. Red to red, white to white, yellow to yellow. Make sure you then have the transmitter and receiver plugged in. Your remote is supposed to work from your other room. If this solved your problem please rate this as fixed. If you need more help with this just add a comment and I'll be glad to help you. Thanks.
Apr 13, 2008 | Terk LeapFrog LF30S
Xbox 360
Depending on the type of Tv you have look for the Red Blue and Green RCA Compsite jacks on the back and the Left and Right Audio Which are Red & White Plug them in and Check the connection by turning th 360 plug to HD (near the console) and turn it the Tv and 360 on (make sure the Tv is on the right input) and that should do it.
Feb 14, 2008 | Microsoft Xbox 360 Console
Canon ES55 camcorder
The camcorder has a port called "Audio Video Out". You need an adapter cable (Canon's cable is the C-250) to connect from this port to a television or VCR. Use the white RCA plug on the cable with the "Audio In" jack and the yellow RCA plug with the "Video In" jack on the television or VCR.
Canon's cable is available from their online store at
http://estore.usa.canon.com/SearchResults.asp?PARENTOID=4764
Feb 13, 2008 | Canon ES55 Camcorder
Microsoft Xbox Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
