Question about Fujitsu Siemens LIFEBOOK C6387 (FKR-C6387-005) PC Notebook
Fujitsu C6387 slow to start
I have a fujitsu Siemens C6387 laptop which takes an age to start up. I dont mean the windows part of it, the first screen loads and has prompts at the bottom for boot list and bios settings etc, and then it does nothing for 5 minutes or more, then it loads windows in a reasonable time. the problem must be something to do with the motherboard or the bios but i cant think what!! I have never come across a computer which takes this long to get to the point of loading and my first computer was an ibm XT 20 yrs ago. Can anyone help please?
  • paul leach Apr 20, 2007
    surely safe mode (f8) is part of the windows thing? it loads windows fine, its the 5 minutes it takes to get there thats the problem. the situation is exactly the same when booting up to floppy or cd, including booting from linux
    any other suggestions?
  • paul leach Apr 24, 2007
    thanks but there ias little difference in the speed with which windows loads eithr normally or in safemode so i guess it must be hardware, but which bit? i have tried disabling things in the bios but it makes no difference.
    What exactly does windows check once it has checked the memory, the hard drive, and the mouse?
    President:
  • 2,961 Answers
What may well be happening is that a peice of hardware, eg usb ports, network adapter, graphics driver or similair is struggling to find the driver for it and is hanging the boot up. It could also be a memory failure or a bios failure as the memory used by your system takes over after the first 64KB of built in bios memory. Start your laptop in safe mode (press F8) on start up, as this will load up with only the needed drivers, if it boots up quicker it may well a driver fault, it is then a process of illimination.
Posted on Apr 20, 2007
  • andrew pester
    andrew pester Apr 21, 2007
    the point i was trying to get across is that when the bios has finished the initial checks, Windows takes over and loads all the drivers for all devices before you get to the windows screen, so if you start in safe mode, only the minimum amount of drivers to get windows running start up and if it gets from bios check to windows faster, then you know it is a driver slowing it uo, if not then it is a peice of hardware the bios is looking for before the windows log on screen.
Fujitsu siemens scenicview b19-3
hi you must disable the main screen in properties section of the display panel then when you start up the computer the screen will not activate until windows has loaded and found and installed the screen drivers after that all should be good to go if you need any further help don't hesitate to contact me :)
Feb 07, 2013 | Fujitsu Siemens Premium Line P19-1 19" LCD...
My System Fujitsu Siemens Scaleo P cannot boot windows and doesn't proceed after display of Fujitsu Siemens Logo (Where it says Press F2 to Enter Setup).
I would take it back to the place of purchase, it is clear the window installation was not completed, a manufacture oversight.
Jun 18, 2012 | Fujitsu LifeBook AH531
My son put a fujitsu siemens recovery disc into his emachines d620 laptop now when i log on it asks for a fujitsu siemens activation key which i dont have or want so i have to use laptop with reduced...
Do you have the eMachines recovery disc? If so, then you need to enter the bios of the laptop by pressing a speciffic key at the start of the boot process. It should tell you what key to press in the POST. Most likely across the bottom of the screen somewhere. The F2 and F10 keys are popular as well as the Delete key. Once you get into the BIOS, Locate the menu containing the boot sequence. Make sure to set the CD/DVD drive as the first boot device. Save the changes and exit the BIOS. Put the Recovery or Windows CD/DVD in the drive and follow the on-screen instructions.
Mar 17, 2011 | Computers & Internet
I have a Fujitsu Siemens M1450G and when I start it can not access the BIOS. When I switch ON the PC on the screen say (FUJITSU computers SIEMENS) and then this sign freeze and then noting happen. What...
Hi
It may be worth trying this
switch on and same time keep pressing the F8 key
hopefully it will take you to the options for repair
try last know good configuration or system restore back to when it was ok
or try to ask windows to repair
good luck
hope you can get sorted
Feb 25, 2011 | Fujitsu Siemens AMILO Pro V2010 Notebook
I have got a problem,when i wanna run the wireless on laptop,it doesnt allow me to connect,it keeps saying "turn on your wireless compability" and it says that you can do this by switching on a...
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Thanks for using Fixya.
Jan 27, 2011 | Computers & Internet
My fujitsu siemens amilo pro v2000 has no display, no beep codes too.. need help. tnx
does it display on startup? i mean before it loads windows. if it doesn'y display on start up, then you could be having a faulty flex or display unit. LCD. replace.regards
Feb 23, 2010 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu siemens amilo L1300 LAPTOP wont load up
sounds life the start up files have been corupted you may need to reinstall windows. the only thing is it will delete and data you have on the labtop. if you dont mind about that reinstall windows of the reinstalltion cd.
Mar 25, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Amilo pro 2030v faan
We did not find any results for Fujitsu > AMILO Pro V1000 (FAP:GBR-147150-H01 ) needing a fan for my laptop computer. Other searches you may want to try: Related searches Click on the Link above, Good Luck.........Please dont for get to Vote, Thank You.
Dec 15, 2007 | Fujitsu AMILO Pro V1000 Notebook
Fujitsu Siemens LIFEBOOK C6387 (FKR-C6387-005) PC Notebook Logo
297 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
