Question about Philips Televison & Video
I have a philips CDR778 2 Disc recorder and the display comes on with scrambled symbols instead of english letters for everything. Can you tell me the correct voltages outof the power supply and what could be going wrong with the unit.
  • apfwelty Dec 28, 2008
    Dear sirs at FixYa
    I am not satisfied with your comments on the Philips CDR 778 2 Dics unit. Your comments covered only external voltages and operations. I service equipment and was inquiring about the internal switching power supply voltages controlling the main IC and the display. Are the voltages listed in my previous E-mail correct and the IC, 87CH74F bad thus causing the scrambled display?
    Paul
  • 15,935 Answers
Output
• 1 x Analogue line output CDR (+ CD) : 2 Vrms +/- 2 dB / 0.2 kOhm
• 1 x Analogue line output CD : 2 Vrms +/- 2 dB / 0.2 kOhm
• 1 x Digital coaxial output CDR (+CD) : 0.5 V (pp) / 75 Ohm
• 1 x Digital coaxial output CD : 0.5 V (pp) / 75 Ohm
Posted on Dec 27, 2008
  • blueextc3221
    blueextc3221 Dec 27, 2008
    Technical Specifications CDR778
    General
    • System : Compact disc digital Audio
    (Dual deck CD-recorder + CD-player)
    • Number of channels : 2 (stereo)
    • Applicable supply : 117V
    • Power consumption : 19W (<=6W in standby)
    • Operating temperature : 5-35°C
    • Weight : 11 lbs
    • Dimensions : 17.1" W x 12.2" D x 3.46" H
    Audio
    • Digital frequency range : 2 Hz - 22.05 kHz
    • Playback S/N (CDR & CD) : 100 dB (A - weighted)
    • Playback dynamic range (CDR & CD) : 95 dB 90 dB
    • Playback total harmonic distortion : 91 dB (0.0033%) & 85 dB (0.0056%)
    + noise (CDR & CD)
    • Recording S/N (Analogue) : 98 dB (A - weighted)
    • Recording S/N (Digital) : Recording quality equal to Source
    • Recording dynamic range : 92 dB
    • Recording total harmonic distortion + noise : 85 dB (0.0079%)
    • Headphones : 3Vrms / 8 - 2000W
    Output
    Input (level adjustment)
    • Direct line recording (bypass SRC) for : 44.1 kHz +/- 100 ppm
    • 1 x Digital coaxial input (SRC) : 12 - 56 kHz / 0.5 Vrms / 75 Ohm
    • 1 x Digital optical input (SRC) : 12 - 56 kHz
    • 1 x Analogue input : 500 mVrms / 50 kOhm = 0 dB
  • blueextc3221
    Technical data
    Subject to modification without notice.
    General
    Power consumption.....................................................................20 W
    Power consumption in Standby ...............................................6 W
    Operating temperature.......................................................41-95 °F
    Weight.............................................................................................9.92 lbs
    Dimensions.........................................................17.1” x 12.2” x 3.5”
Have a brand new wireless Belkin keyboard that is using only Spanish symbols can I get it to use English symbols ?
you need to install compatible drivers on your computer.
try doing that through device manager. if that does not help
then call 1-877-805-1027 for expert help.
Jul 30, 2015 | Belkin Computers & Internet
Phillips CDR 570
Let's start with an assumption... you're using ReWriteable discs.
What specific message do you get when you try to unfinalize it?
When finishing a recording, what does it display instead of "update" when you stop?
May 04, 2010 | Philips CDR796 2-Disc CD Recorder
I recently got a Philips DVD Recorder/VCR: Model No. DVDR3510V/05; Serial No. 0751 010790. I have recorded a VCR tape and would like to transfer this to a DVD±R disc. Can you tell me how to delete...
After you transfer the data to the DVD, you can use a DVD editing program like the DVD remake found on this link
http://www.afterdawn.com/guides/archive/dvdremake_tutorial.cfm
and you can edit out all of the commercials
let me know if you have further questions with this
Oct 07, 2008 | Philips Televison & Video
Philips DVDR615/69
Take, if good  batteris from the remote controller and recycel the unit, and by a better one. I have the  same problem, recordings will stay on the dvd only a short thime readable and later the disk is empty.
Sorry my english.
Sep 26, 2008 | Philips DVDR615 DVD Player
Language
Press Setup on the remote.
The third entry is Display. Go to it and press OK
The first entry is language. Press OK. The first entry in English. Press OK. You should now be in English.
Jul 08, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Scrambled keyboard
Is it giving you numbers and symbols? do this: Press and hold the function key fn while pressing the num lock key num lk . This will deactivate the integrated keyboard/numeric keypad, and the keys will respond normally.
Please remember to rate all users who assist you for free :)
Jun 30, 2008 | HP Compaq Presario V6000T Notebook
Problem Recording HDD to DVD-R
I had a few problems with my philips 3450 - I downloaded the latest software upgrade at www.philips.com/support , and my issues were resolved. Worth a shot...
Only other thing I can think of is you may have a faulty batch of DVD-Rs?
Best of luck!
Jan 16, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Recording to cd
Disc recover occurs when the power goes off and comes back on halfway through a disc being recorded. Try a new disc? You may have a faulty PCB on the record side.
Dec 02, 2007 | Philips CDR795 2-Disc CD Recorder
Philips CDR796 CD Recorder
You power off then power back on while holding down the fast forward and rewind buttons on the recording side simultaneously. The display moves through a sequence of numbers and the trays will then open.
Sep 18, 2007 | Philips CDR795 2-Disc CD Recorder
Televison & Video Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
