SOURCE: 2000 ford excursion wont start
The venture runs without problems, but then off-key upside down but nothing works, even though the battery is full. you only hear something like relay switch and then dead
SOURCE: how to change fuel filter 2000 excursion
Yes it is the tool for fuel lines and ac lines. Your local autoparts store should have them, they are universal. You need to use the small end for the fuel filter.
SOURCE: 2004 ford excursion will not start
when the key is on without starting do you hear a whirring sound from the fuel tank , if no it's a fuel pump or fuel relay. Did you check it for spark from the plugs get back with me
SOURCE: 2000 Ford Excursion Diesel has check engine light of P1391
glow plugs preheat the fuel to help the engine start.....when its hot outside its not that bad...the colder it gets the harder it will be to start with bad glowplugs..
SOURCE: I have a 2000 Ford Excursion. I went to hook up a
If these lights still work on your excursion then it is probably not a fuse problem. It sounds like it is a loose pin(s) with the trailer plug or a loose electrical connection(s) on the trailer or maybe the bulbs on the trailer are burned out. This should help, if not then contact me again at FixYa and I will be glad to help.
