Question about Polaroid FLM-4201 42 in. LCD Television
How to get 1080p?
I bought the 1080p but its only show 720p on the hdmi? so how do i get it to 1080p?
  • 1 more comment
  • ctrevino2004 Jan 07, 2009
    thank everyone for helping me out!! it really help!!
  • Sean Kelly May 11, 2010
    Are you certain that you have a 1080p video source? Blu-Ray players are true 1080p, for example. Many cable companies only broadcast in 720p or 1080i. Also, if you are using cable, you'll need to be sure that your cable-box is an HD model. If not, you'll need to have it upgraded as well.
  • Anonymous Mar 26, 2014
    won't stay on 720
  • 4 Answers
In addition many TV service providers are unable to send a true HD signal. the max is 720p or 1080i as refered to above. some sattelite companies are beginning to dabble in it but nothing full swing as of yet.
Posted on Jan 05, 2009
I do have a lg BH6430P home theatre,when I connect the HDMI to the TV it gives me no signal
check that the hdmi lead is good, if it is check that its outputting a signal that is not too high for the tv. i.e. if the lg is outputting 1080p can your tv show 1080p just because the tv is HD ready, doesnt automatically mean it can show 1080p try setting the lg to 720p or lower to see if anything shows on the tv
Aug 02, 2017 | LG Audio Players & Recorders
How do I change the HDMI from 720 to 1080.
How do I get 1080 instead of 720. - Comcast Help and Support Forums
forums.xfinity.com/t5/XfinityTV-and.../How...1080...720/.../1152741
Jan 3, 2012 - I can switch one of them from one HDMI input to the other HDMI ... The YPbPr option might be set at 720p, and you can change that to 1080i.
How do I change the resolution on my LG tv to 1080p ? - Nvidia ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Apr 20, 2012 - 7 posts - ‎4 authors
Hello, I have recently bout a new LG tv, and I use a HDMI cable with my sky HD box, but ... only shows 1080i resolution, and i cannot find where to change it to 1080p. ...Forum; Optimizing blu-ray settings for 720p Plasma tv? 1080p TV outputs 1080i from desktop - Radeon ...
May 24, 2012
Bravia Full HD won't show pc via HDMI on 1080p but ...
Oct 30, 2011
More results from www.tomshardware.com
Change it: Your Comcast/Motorola HD Cable Box may be ...
www.darrowart.com/.../change-it-your-comcastmotorola-hd-cable-box-...
Oct 20, 2012 - Change it: Your Comcast/Motorola HD Cable Box may be outputting ...they set it to output a 720p signal via the HDMI out to my 1080p-capable ...
How To Change your PS3 from 720 to 1080p - YouTube
Jan 03, 2016 | Televison & Video
Shows 720p but should be 1080p seiki se24ft01
This will be ether the zoom button on the remote or If you go onto the menu screen settings
Jan 04, 2014 | Seiki 24" Class 1080p 60Hz LED HDTV...
I just bought a used ps3 i hook it up to my emerson hd tv and it shows format not supported , i then hooked it up to my poleroid hd tv and it works fine this all thru the hdmi cable
What are the specs on your emerson, does it support 1080p? Make sure you have the right settings on your ps3. If your emerson supports 720p and 1080i then it will not give you a 1080p picture and you might run into issues.
Mar 06, 2011 | Televison & Video
I bought an HDMI hookup to hook the blueray player I got to my Apex tv. I plugged it into HDMI and then turned the input on my tv to HDMI and after a few seconds it says mode not supported. What is wrong?
The DVD player is most likely outputting at 1080p, where as the TV can only input at 720p. What you can do is hook your dvd player up to another TV, and scale back the output from 1080p to 720p, then try it on your TV again.
Jan 11, 2011 | Apex Digital Televison & Video
I had ps3 hooked up to 720p tv then hooked it up to 1080p moniter now it won't show a picture on 720p tv
you have to switch it back to 720p mode before disconnecting it from the 1080p television. If you're using HDMI, and then switching back to the a/v connectors, then you have to switch the output settings of the ps3 from hdmi to a/v as well.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
Sony bravia klv-32t400a hdmi input through x-box and p.c gives error reading - unsupported signal! check device output. both are on 1080p using hdmi to hdmi cable v1.3 why no vidio, only audio
The problem is that, according to the specs for that TV, it doesn't support 1080p.
That's a 720p television you've got. (Specs here)
While the specs say that it supports 1080p, the resolution says it supports 1366 x 768, which is only 720p, not 1080p or even 1080i.
You may want to contact Sony for clarification, because their specs for that tv are contradicting each other.
Mar 19, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
LP 640 projector not able to display 1080p
The specs of the LP640 show that the maximum resolution it can handle is 720p. You are trying to make the projector do something it cannot handle
Oct 02, 2007 | InFocus LP640 Projector Multimedia...
Polaroid FLM-4201 42 in. LCD Television Logo
138 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
