Question about Ace Hardware ML250TPA Infra-Red Wall Mounted Panel Heater
I was wondering where i could buy a replacement pressure regulator for a procom model ml250tpa
    Problem Solver:
  • 8 Answers
Try Procom Customer Service at 877-886-5989. Or call Kozy World at 800-776-9425 and tell them you have a KWP324 (same as ML250TPA).
Posted on Jun 12, 2009
Can you tell me where i can buy pressure regulator NRV81F1-8 at canada or usa
Contact Procom's Customer Support Dept 877-886-5989. They can help you out.
Jun 26, 2011 | Procom ML060HBA Heater
Thinking about buying a pro com -ML250TPA-BB from tractor supply for my garage can i use a 40 lbs. propane tank for gas supply?
I think what you have is a 100 Lb tank, that holds 40 gallons of propane. If that's,the case, it would be acceptable. IF the tank is placed Outside the garage 3 ft from any doors or windows: The gas line is a minimum of 1/2" diameter; the heater is permanently mounted to the wall (at least 18" off the floor); there is an accessible, inline gas shutoff valve within 2 feet of the heater and you have a properly sized tank regulator. You do all that, and you'll reach the minimum code standards that are required.
Hope this helps you make the right decision.
Rich
Mar 03, 2011 | Procom MN100HPA Heater
Where can i find a downloadable user guide,and a service manual for this model..also im tryig to find the right regulator for this model..does anyone know where i can find it??thanks!!
Here's a link to the Procom Owner's Manual website. However, the Model Number you listed doe not sound like a Procom Model #.
http://www.worldmkting.com/owners_manuals.htm
Also, all vent-free heaters, fireplaces, gas log sets, etc come with the regulator built-in. Are you trying to replace one you think doesn't work? Or are you trying to convert it from one gas type to another?
If it's the latter, there is no conversion approved for vent-free gas appliances. Plus, if you could, it would take more than just the regulator to do it. Totally unsafe to do.. Please don't attempt it.
Feb 25, 2011 | Procom SN400TYL Heater
I have purchased a Procom ventless heater (ML250TPA) and need to know if I have to put a low pressurer reg. on the system outside or will this model heater reduce the propane pressurer coming from my 500...
This heater is designed to work with LP gas. You will need a regulator from the tank to the heater set at 11"wc .that's standard for any LP gas system. Your existing piping system should have a regulator already outside of your house before the gas inters your home .If it does not then you will have to install one. The regulator can be inside but you will have to run a vent line in copper from the regulators vent to the outside of your house.
Hope this helps ......
Nov 23, 2010 | Heating & Cooling
I Need to know whaat type of regulator is need for model ssu320rhl-gb Please
Here is a link to the owners manual and page 8 and 9 tell you about the regulator.
http://www.northerntool.com/downloads/manuals/177883.pdf
You need to a 8-11WC regulator for propane and if you are using natural gas you will want to keep the pressure between 3-10WC
If this is connected to a propane bottle you want o use at least a 100lb bottle.
Thanks
Oct 15, 2010 | Procom SSU320RHN-GB Heater
Where can I get a Charmglow gas heater pressure regulator Procom NRV81F-10? The regulator is leaking propane badly. Thanks.
There will be a number printed on the side of the regulator, contact Procom direct or just put the number into google search and something will come up.
Mar 14, 2010 | Procom QL300TYLA Heater
Getting fumes in home while heater is running
The pressure regulator can very well be the problem if you had the device three years with out a problem.
Is the devise vented? if so then maybe there is not enought draft to completely combust the fuel, if it is NOT vented then it very well could be the regulator sending more fuel to the devise that it is able to combust properly.
Jan 29, 2009 | Procom Heating & Cooling
New heater pilot will not stay lit
gas and fire, I would return it before you blow something up.
Oct 03, 2017 | Ace Hardware ML250TPA Infra-Red Wall...
Procom blue flame heater
Call 1-877-886-5989, Have model number handy
Nov 23, 2008 | Procom ML300HGA Heater
Ace Hardware ML250TPA Infra-Red Wall Mounted Panel Heater Logo
120 people viewed this question
Top Ace Hardware Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you an Ace Hardware Heating and Cooling Expert? Answer questions, earn points and help others
