Question about Panasonic NN-C994S Convection/Microwave Oven
Microwave oven runs when door is open, and does not always run.
We have a Panasonic microwave oven which we bought a few years ago. It has begun running when we open the door (DANGEROUS!). It also does not run consistently when we program it. It is about three years ago. What can you do to correct this problem, please?
  • nanaval43 Dec 27, 2008
    I meant to say that it is about THREE YEARS OLD.
    Thank you.
  • Panasonic Master
  • 9,098 Answers
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Dec 28, 2008
Bought Panasonic NN-S766 microwave in 1997. Been great. Has begun to run 2-4seconds, blows fuse. Also makes a louder(different) hum while running. All switches look good, magnatron magnets look good. Need...
With the prices of microwave's & since you've had it since '97 that's almost 18 yrs. don't you think you can put it out of it's misery & get a new one? Check Craig's list, the penny saver or yard sales, you'd be surprised how inexpensive they are now. I use to sell Panasonic when they first came out, so many yrs. ago,. I've always had great results with Panasonic microwaves.
Nov 06, 2014 | Microwave Ovens
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
Fan runs when microwave door opened
-You're already answer yourself.
Good luck
Mai
Jan 22, 2018 | GE JVM1650 1000 Watts Microwave Oven
I have a JVM1850 that was installed 4 years ago. The unit was working fine, then a day ago I received an error display requesting a charcoal filet replacement. No filter is needed since it is vented...
I have a JVM1850 White microwave-over the oven-installed 3 years ago. Last evening the unit would not turn off. The inside light and fan continued to run, however, the microwave was not working.
All the controls and functions seem to operate, but when completed, the unit remained working, as stated above, with the door opened or closed.
Sep 18, 2011 | GE JVM1850 1000 Watts Microwave Oven
Panasonic Counter top Microwave model # NNT695SF Often when I push the start button, the microwave will go for a few seconds and then cut out. I then open the door and then shut the door and push the...
Issue with your Main Panel Power Fail to innitiate ..Du to Component mal-functioning inside the unit ...Possibility Magnetron defect, Or main Transformer Over heat, Also check for safety swich on the door for bad connection...
Sep 30, 2010 | Panasonic NN-T695SF Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Microwave is still running when the door is open
The cooling fans run for a time after the magnatrons have stopped, The magnatrons are the heating components so I dont think you are in any danger as the microwave doors are double locked so the magnatrons cant run once the door is open
Sep 27, 2009 | Panasonic Microwave Ovens
My microwave continues to run, (turntable and exhaust), when the door is opened.
all microwaves have 2 safety switches at least... but these are tied to a set of relays that turn it on, my bet is a sticking or stuck relay because you unplug it right and plug back in its not running?-relay ... if always runs driver transitors.
Dec 27, 2007 | Panasonic NN-T990SA Microwave Oven
Unit does not turn off
open the control push boton and clean it one of the boton stoct.
Sep 19, 2007 | Panasonic NN-S254WF Microwave Oven
Panasonic NN-C994S Convection/Microwave Oven Logo
139 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
